Old 05-20-2019, 11:16 PM #1
blarblarjosh blarblarjosh is offline
blarblarjosh is on a distinguished road
1999 4runner Passenger Side Valve Cover Stuck
So trying to do the valve cover gasket replacement and have all 8 bolts removed on the the valve cover but I can't seem to be able to pull it off. I know there's a bracket near the firewall but I don't believe it is attached to the cover. I can't see anything else that needs to be removed and when looking at the other guides I don't see anything else to be removed. Do I just need to pry harder or is there something other than the 8 bolts that need to be removed?
Thank you.
blarblarjosh is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 11:19 PM #2
DaMonkey's Avatar
DaMonkey DaMonkey is offline
DaMonkey will become famous soon enough
DaMonkey's Avatar
Well I would like to be the first one to say bravo for not prying harder and getting into real trouble before asking the question.
I don’t know the answer, but I have a feeling you will be told to pry harder.
rock beats scissors. zip ties beat clips.
www.maluna.com - Scott
DaMonkey is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 12:49 AM #3
HiLife HiLife is offline
HiLife is on a distinguished road
The bind could be between the 3 spark plug tubes gasket meets the spark plug tube gaskets.
Old 05-21-2019, 08:30 AM #4
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar will become famous soon enough LittleCaesar will become famous soon enough
A big rubber mallet should do the trick.
I have seen one tack welded onto a head before but it wasn’t on a 4runner. A dish of revenge best served cold, so to speak.....
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 10:38 AM #5
pokeyman pokeyman is offline
pokeyman is on a distinguished road
just tap it on the side with a rubber hammer
pokeyman is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 10:57 AM #6
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy will become famous soon enough Joelzy will become famous soon enough
MY GARAGE
Joelzy's Avatar
MY GARAGE
I had some stubborn spark plug tube seals that were hardened and stuck as well as someone adding RTV all the way around instead of just those corners.
just pried on it little by little all the way around and it eventually started easing up. If everything is out of the way there shouldn't be anything else holding it down i dont think.
–96 SR5 4WD 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 11:26 AM #7
Joelzy, did you pry with any tools or just pulling by hand? I have a feeling the PO applied RTV all the way around.
I've attempted lightly tapping with a rubber mallet as I've seen that mentioned for other vehicles that have valve covers stuck on to no avail. Maybe I just need to put in a bit more elbow grease.
Old 05-21-2019, 11:37 AM #8
Joelzy's Avatar
MY GARAGE
Joelzy's Avatar
MY GARAGE
I used a big flathead but be sure to only pry on the outer tabs, never into anything that could scar the seal area. this kind of gives you an idea if you're not sure where is safe.
–02 bmw 540i6
–19 Highlander SE
Old 05-21-2019, 11:40 AM #9
Awesome, thanks Joelzy! I'll give that a whirl after work. Hopefully I can get mine off and make it look remotely as clean as yours.
Old 05-21-2019, 12:31 PM #10
Joelzy's Avatar
MY GARAGE
Joelzy's Avatar
MY GARAGE
I wish that was mine! just a pic i pulled from the web for reference. Even after a hot tank mine weren't that clean.
–02 bmw 540i6
–19 Highlander SE
attached , bolts , cover , removed , valve
FS: 3rd Gen 1999 Toyota 4Runner Limited Fog Light assembly Passenger side niadh0 For Sale: T4R Items 1 12-20-2016 12:46 PM
Passenger side valve cover Ahlem Classic T4Rs 3 02-09-2015 10:42 AM
WTB: 5VZ FE (3rd gen v6) Valve cover and head (passenger side) funnymeatball For Sale: T4R Items 0 07-03-2013 12:36 AM
WTB:Roof Rack Passenger side Rear bolts Cover for 2007 4runner sc40094 Want to Buy/Trade 0 10-17-2012 07:16 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
