Originally Posted by Mark_BC
Yes fluid is fine. New to me truck so never dropped the pan. One theory is that maybe a hose on the cooler I put in isn't snug and being on an incline it was a high point and some air got in there. On startup this air went to the torque converter so there was no fluid coupling until fluid went back in? IDK, I have no idea how the torque converter works.
1) You would be leaking transmission fluid if your cooler lines were not "snug".
2) Your transmission cooler is after the transmission. Fluid gets picked up through the pan, pressurized by the pump, routed through the valve body and pistons, sent to the torque converter, exits the transmission to your transmission cooler, then returns from the cooler to the transmission pan.
