05-22-2019, 10:42 AM
1997 rear LCA bushing question
I have a set of energy suspension poly bushings for the rear upper and lower control arms, I know the uppers are captive but can still be replaced, my question is since mine is a 97 the lower bushings are also captive unlike the 98+, is there any reason I can’t replace them just like the uppers? Is the inside diameter different on these arms? Just wanting to make sure before I order a set of used 98+ Lower control arms
05-22-2019, 11:21 AM
The aftermarket bushings will fit either.
The control arms are all the same, the factory bushings are different.
I just replaced my bushings in my 97 with Whiteline bushings.
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
05-22-2019, 12:16 PM
I just ordered a rear lower this morning 48061-35050 says compatable 95-2004
05-22-2019, 01:22 PM
I'm thinking of doing the same? How has it been? Noticeable improvement?
1997 Limited 4x4 3.4l 199k E-locker Blue Wire Mod | 255/85 r16 Maxxis Bighorn MT - LX450 9 wrap + Tokico black rear | Front: 2.5" King Coilover set @ 2" lift | True North Fab Front Bumper + Warn m8000 + Baja Designs Squadron Sport | Custom Sliders | NguyenWorks Rear Bumper + Tire Swingout
05-22-2019, 01:36 PM
My stock bushings still had life in them, the rubber was pretty hard though.
I felt a little less road vibrations after changing all of them out.
2011 BMW 135I 6spd
2009 Lexus LX570
05-22-2019, 08:41 PM
Thanks for the help everyone, I’m working on it this evening and tomorrow morning and I’ll post an update after I test them out, I’m taking my time because the control arms are pretty rusty so I’m sanding that off and repainting
05-23-2019, 02:20 PM
Has anyone ever seen an LCA like this one? This is the side that attaches to the frame
What is the purpose of this extra metal wedge welded on to it
05-23-2019, 02:54 PM
Real Name: Sean
Real Name: Sean
That control arms looks unique. I havnt see one that looks like that before. I just recently changed all upper and lower rears on my 96, 2 weeks ago. It had original bushings on, and my truck has 300k mi. I definitely noticed a big improvement, especially going over imperfections in the road.
05-23-2019, 03:23 PM
Real Name: Scott
Real Name: Scott
The one on the bottom here is a stock rear LCA:
05-23-2019, 04:04 PM
That's what mine looked like.
2011 BMW 135I 6spd
2009 Lexus LX570
05-23-2019, 04:06 PM
Real Name: Scott
Real Name: Scott
Both of these do not look stock to me. The bushing in both of these look to be poly bushings, rather than the stock rubber bushings.
05-23-2019, 04:17 PM
The bushings were rubber in mine. I had to cut the lip off one side and press them out.
2011 BMW 135I 6spd
2009 Lexus LX570
05-23-2019, 04:24 PM
Real Name: Scott
Real Name: Scott
I very well could be wrong on this. Maybe there was a redesign? The picture I posted was off of a 99, and I know they did some redesigns on that year.
05-23-2019, 04:43 PM
The picture I posted was after I put my poly bushings in, it definitely had the stock captive rubber bushings in it before
05-23-2019, 04:46 PM
Real Name: Scott
Real Name: Scott
Aw, I see. Maybe the picture of the ones I posted are of the opposite side of the bushing of what
@ turbo8
posted? I can't quite remember, but can look tonight. Still doesn't answer the question of what that bump is. Was the side with the "mystery hump" located on the frame or on the axle?
