Old 05-22-2019, 09:25 PM #1
silver4est silver4est is offline
silver4est is on a distinguished road
Cylinder 4 at 60psi on compression test :(
Engine was warm, did not unplug coil packs. Removed #4 plug, screwed in gauge, started car and it came out to 60. Have not checked other cylinders yet, checking again tomorrow and taking a look at valves with a borescope?
Time with my mechanical friend was very limited and rushed, leaves me with questions. What’s next?
It feels like it drives fine aside from the misfire, shake when not moving.
silver4est is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 09:41 PM #2
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Soak the cylinder in marvel mystery oil. May free up a sticking ring. If nothing happens then just drive it.
Old 05-22-2019, 10:58 PM #3
pokeyman pokeyman is offline
pokeyman is on a distinguished road
Pour a little oil into the cylinder and due to compression test again if the compression goes up that means the Rings are worn out if not you might have a bad valve or a blown head gasket
pokeyman is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 11:13 PM #4
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
See if your mechanical amigo has a leak down tester to verify just how bad that cylinder is for lacking compression.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 05-23-2019, 09:26 AM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
When you say you started the car, you mean the engine was running during the compression test? If so, that is a running compression test and will be much lower than a static (engine not running) compression test.
Old 05-23-2019, 10:17 AM #6
Yes he needs to remove all the spark plugs and wedge the throttle wide open for the test to be accurate.
Old 05-23-2019, 11:11 AM #7
Yes the engine was started and running.
Will redo it and test each cylinder
Old 05-23-2019, 02:12 PM #8
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Others have said it but that's not how you test compression. Needs to be done one at a time with the engine off, just cranking only. I usually unplug the MAF so it won't start.
If you really are at 60, a leakdown test will tell you where the compression leak is at.
326WHP 347TQ
Old 05-24-2019, 12:51 AM #9
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
well I have 2 cents. Make sure the battery is fully charged I do compression test with the engine cold just because its easier.
Remove all the spark plugs keeping track of where the wire go and inspect the plugs they tell you alot.
I would unplug each of the coil packs or find another way to disable the ignition system and pull the fuel pump relay.
I will block open the throttle with something like a screw driver handle keeping the throttle open at least 25% and make sure it won't hurt the throttle plates or if you have a buddy working the key he can hold the throttle down. (I use a remote starter button so I can see the gauge.)
Now how many rotations some will keep pumping till it gets to the highest number. I usually go about 7 rotations what I look for is the major peak on the first cylinder I test and then go 2 more revolutions then do all the cylinder the same amount of revolutions.
Write down each results for each cylinder when your done take a oil can with motor oil in it and squirt 2 squirts in the first cylinder and retest. Do this for each cylinder.
So now you have a dry test number and a wet test number it will not tell you quite as much as a leak down test but for me its enough. If you have a low cylinder and it comes up after the second test then the problems rings if it changes only a little then it's valves. If it's just valves the job is easier, if it needs rings it depends on how bad the cylinders and pistons. ( Time money knowledge.) So do the test post the results i'm sure you will get responses.
plcfcng is offline   Reply With QuoteReply With Quote
Old 05-24-2019, 03:51 PM #10
thank you, I will get on this and post back
cylinder , friend , mechanical , rushed , time
compression test and a leak down test cost? judoant 3rd gen T4Rs 23 05-24-2018 04:34 PM
3.4 Compression test CCr323 3rd gen T4Rs 16 04-27-2018 11:13 AM
5VZ-FE 3.4L V6 Compression Test mtbtim 3rd gen T4Rs 3 01-02-2018 04:29 PM
How to run a compression test? a216vcti 3rd gen T4Rs 8 02-07-2014 07:14 AM
