Old 05-25-2019, 04:05 PM #1
Capnemo Capnemo is offline
Capnemo will become famous soon enough
Question for a 1997 Limited owner: Seatback switch?
I ordered a new seatcover bottom and back from Hotrodupholstery.com.
While it is on the way I noticed a hole in the side of my seatback, with a missing switch. I looked up a part number from a switch on eBay and it is for 2000-2002
or 2001-2002. I looked up my '97 and there is no switch on the seatback diagram so I am thinking at some point a later seat was swapped in but my seat cover should still
fit the later years thru 2002.
Just wondering if anyone with a '97 can confirm that all their switches are at the bottom sideband none on the seatback. Maybe the later Limited had an inflatable lumbar support, the seatback angle is controlled on the botton side upper button.
Thanks
Capnemo is offline   Reply With QuoteReply With Quote
Old 05-25-2019, 04:29 PM #2
missing switch
not a 1997 Limited seatback?
Question for a 1997 Limited owner: Seatback switch?-4c78a55a-4ab8-47f7-9880-90ca9aee6fff-jpg
Old 05-25-2019, 06:28 PM #3
wemslie97's Avatar
wemslie97 wemslie97 is offline
Real Name: Bill
wemslie97 is on a distinguished road
wemslie97's Avatar
Real Name: Bill
I can confirm that there is a lumbar switch Midway up the seat back only on the outside drivers side.
'97 T4R LTD 4WD desert dune, bone stock, factory E-locker, RS3000, Scangauge II, Hella 450's, 191k
wemslie97 is offline   Reply With QuoteReply With Quote
Old 05-25-2019, 06:29 PM #4
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
The connector sticking out the side of the seatback is for the lumbar switch. The '96-00 Limiteds had the switch in that location. I'm guessing that there is not a single 4Runner in the world with that switch still intact, the tabs break off and the switch just hangs there, with the seatbelt catching on it occasionally. So some folks glue it to the seatback, while others take it off, like apparently was done on yours. Here is what it looked like on my '97:
The later, -01-02 Limiteds, had the switch smartly relocated to the lower plastic trim piece along the side of the lower seat cushion. I modified my '97 to that setup when redoing the upholstery recently. Here is what that looks like:
If you want to go that route, you'll need the '01-02 Limited trim piece for the bottom seat cushion, and an '01-02 Limited lumbar switch (it's different from the '96-00 switch). And you'll want to get the leather kit without the cutout for the switch in the seatback, though I think they all come without that cutout.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 05-25-2019, 07:24 PM #5
Yes the seat cover comes without a cutout, you just slice one in.
Does anyone have the part number for the '97 switch". When I looked online for the '97 the diagram did not have one.
So, the seat angle is controlled by the upper small button down on the side, this switch was a lumbar support inflator?
Old 05-25-2019, 07:26 PM #6
And I guess one would just relocate the socket and wiring from the setback to route to the side mounted '01-'02.
Does anyone have the part number for the '97 lumbar setback switch? Maybe if I plug my VIN into the parts diagram it will pop up, I was searching on 1997 + Limited etc.
Old 05-25-2019, 08:29 PM #7
Real Name: Leon
Real Name: Leon
The '96-00 Lumbar Switch is 84750-22060-E0:
Yes, but like I said above, you'd need to use a different switch, the '96-00 switch won't work with the '01-02 trim piece. You'll need to get the later model switch - 84922-50010-E1.
Old 05-25-2019, 11:03 PM #8
Awesome, thank you sir!
Old 10-15-2023, 08:26 AM #9
sdb999 sdb999 is offline
sdb999 is on a distinguished road
Bump. @4Runner4Leon has showed the ultimate oem solution, well done. I've taken the same path but one thing that wasn't addressed originally.
Does the later switch have the same connector? Wires have to be lengthed for sure but if a new connector is needed any known source?
Thanks, S.
sdb999 is offline   Reply With QuoteReply With Quote
Old 10-15-2023, 08:45 AM #10
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Thanks, S.
Same connector for both switches. And the harness was long enough to reroute it to the new location, no extension needed.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
bottom , buttons , seat , setback , switch
FS: Parting out 1 Owner 1997 Limited 4runner Winston-Salem NC wingnut25xp For Sale: T4R Items 25 11-16-2020 06:00 PM
New owner 1997 Limited!! Woo Hoo!! Suncoast New Members 3 01-20-2014 07:13 PM
Another proud New Owner of a 1997 Limited 4Runner l3igl3ang 3rd gen T4Rs 8 01-14-2012 03:36 PM
Proud New Owner of a 1997 Limited 4Runner MattDyer94 3rd gen T4Rs 24 01-14-2012 12:19 AM
1997 Limited SecuriKey Alarm Programming Question mrod727 3rd gen T4Rs 0 11-26-2011 03:32 PM
