Old 05-26-2019, 06:49 PM #1
Dezerts10 Dezerts10 is offline
Dezerts10 is on a distinguished road
Remote oil filter and oil pressure gauge port
Anyone running a remote oil filter adapter and have their oil filter somewhere other than stock?
Also, is there a location to add an oil pressure sender on our 3.4l? I have a 1996 and have been thinking about adding some gauges
Dezerts10 is offline   Reply With QuoteReply With Quote
Old 05-26-2019, 08:53 PM #2
turbodudey2's Avatar
turbodudey2 turbodudey2 is offline
turbodudey2 will become famous soon enough
I relocated the filter to the driver side frame rail. There is a lot of room for a big filter there: I use a M1-301.
If you want an oil pressure gauge, the stock sender is right by the oil filter. You could tee off there or use a remote mount with a sender port.
'96 Toyota 4Runner Limited 4x4, Supercharged
turbodudey2 is offline   Reply With QuoteReply With Quote
Old 05-27-2019, 05:55 PM #3
What did you use to block off the stock oil filter? I saw the the LCE block off plate they have but not sure if it’s worth all that hassle.
I just hate the location of the oil filter
Old 05-27-2019, 11:31 PM #4
Just a regular spin-on adapter from Jegs. Like this one: Derale 15703: Spin-On Adapter Dual 1/2" NPT ports | JEGS
I used an adapter with side ports, but the top ports would be easier to install.
Some of the filter mounts have 1/8 NPT ports for sensors. The one I used from Jegs does not, but they are easy to drill and tap to add one. Derale 25709: Standard Series Remote Filter Mount Only Single Filter Mount | JEGS
Old 05-28-2019, 12:00 AM #5
fixxor fixxor is offline
fixxor will become famous soon enough
I would really like to relocate my oil filter like that. Any down sides to doing this?
fixxor is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 10:11 AM #6
Follow up question.... what is normal oil pressure for our engines?
Old 05-28-2019, 10:47 AM #7
Per the FSM:
4.3 psi or more at idle
36 - 75 psi at 3,000 rpm depending on temperature/viscosity
Remote oil filter and oil pressure gauge port-oil-pressure-jpg
Old 05-28-2019, 12:25 PM #8
Higher potential for leaks. Otherwise, not much. It would be nice to have an easier to get to filter location and a vertical filter than can be pre-filled when installed.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-28-2019, 12:31 PM #9
metallitera metallitera is offline
Real Name: Red
metallitera will become famous soon enough
Real Name: Red
Some have reported pressure loss with remote mounted filters. It makes sense with friction loss from the hose and adapters. I don't remember how much pressure loss there was, but I remember reading posts from 1 or 2 folks that went back to the stock setup after seeing the pressure loss.
-ReD
Firefighter/Licensed Paramedic
*SOLD* 2000 4Runner Limited 4x4
2020 Ford F-150 3.5L EB
Build Thread
metallitera is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 12:40 PM #10
Agreed. No significant down sides in my opinion.
To mitigate any possibility of leaks, I would recommend using a high quality braided stainless hose and AN fittings. (I would never use rubber hose and worm drive clamps for this application)
If installed correctly, there should be no more chance of a leak versus having the oil filter directly on the engine block.
Having the filter right side up was the main reason I added the remote mount. Can pre-fill with oil when changing the filter, and no mess when removing. I like using the M1-301 filter too.
I have two M1-301 filters on the inside of the front frame rails now. One for engine oil, and one for trans fluid.
Old 05-28-2019, 01:03 PM #11
I had trouble getting stainless hose fittings assembled leak free. I settled on the Aeroquip push-lock stuff. 300psi rated... This was for a different car, but it is still leak free >10 years later.
Old 05-28-2019, 02:04 PM #12
I've heard good things about the Aeroquip fittings, but never tried them myself.
Of the several dozen AN hose end fitting I've installed over the years, I don't think I've ever had one leak. A liberal application of WD-40 or similar lubricant makes assembly much easier, but even then they can be difficult to get started.
Maybe i need to work out like this guy:
Summit Racing - Braided Hose Assembly
filter , iphone , oil , pressure , remote
Toyota Remote Start / port installed option 05Rrunner 5th gen T4Rs 19 10-25-2015 05:23 PM
Specific Question re: Port Installed Remote Start john150 5th gen T4Rs 1 06-24-2014 03:55 PM
Tach, Fuel Gauge, Temp Gauge, Oil Pressure Gauge, Alternator Quit Working silentrunner Classic T4Rs 3 10-05-2013 12:51 PM
Couple 2004 4R issues - tire pressure gauge and remote key lock not working amheck 4th Gen T4Rs 6 09-04-2007 09:21 AM
Adding Tranny gauge - what size lines or port? TeryT Maintenance/Detailing 0 03-14-2005 07:44 PM
