Old 06-06-2019, 11:16 AM #31
96RedRunner will become famous soon enough 96RedRunner will become famous soon enough
Originally Posted by sam.basye View Post
Update 5: Did I miss anything??...
PAG 46 oil, look at FSM for the amount to add for the parts your changing.
The O-rings do not come with the parts you ordered such as condensor and drier connections,
best to replace all with new ones. not sure if Comp comes with them or not.
Old 06-06-2019, 04:03 PM #32
sam.basye's Avatar
sam.basye sam.basye is offline
sam.basye is on a distinguished road
sam.basye's Avatar
Update... Gauge, AC Compressor, and Alternator Regulator Failure
Originally Posted by Bad Luck View Post
Does the dash fuse still blow with the underhood as fuse removed?
If your dash fuse is still blowing with the engine bay ac fuse removed then the compressor is not your problem. With the engine bay ac fuse out your ac compressor cannot engage at all. You most likely have a wiring issue in your instrument panel wiring harness.
Assuming the A.C. fuse is the A/C compressor fuse, yeah. I donít recall if the A/C unit displayed anything or not though before it blew. It did make the awful bad bearing noise right after startup and blowing the fuse.
Drove 10 min this morning to work with the A/C still off without issue. Iím down to one 10a fuse left so I donít want to test that A.C. fuse again until I make it home. Lol
I have a 3hr drive back home tonight so hopefully itíll hold on until then!
Not sure what it could be in the cluster or wiring though. No recent changes, other than getting my seats redone.
Just seems like quite the coincidence the A/C went at the same time and they are somehow connected.
Thanks!
According to Rock Auto, the compressor comes with oil and o-rings, the drier comes with o-rings, and the expansion valve comes with o-rings. Do I need another o-ring or the Ďgrommetí for the condenser?
Update 6:
Drove 3hrs home with the A/C off without the fuse blowing. The pulley sounded awful when I parked it in the driveway. Lol
Looking like parts will be here tomorrow and the next day, but weather is going to suck and I gotta be back at work Sunday for the next 5 days. Hope the weather is decent for driving with the windows down till I can do it all the following week...
sam.basye is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 11:26 PM #33
Do I need another o-ring or the Ďgrommetí for the condensor...
The condensor I purchased from Rock did not come with O-ring nor did drier, went to auto parts store found one that worked.
Old 06-08-2019, 12:42 AM #34
sam.basye's Avatar
sam.basye's Avatar
Interesting, thanks.
I now have at least 3 o-rings for the 2 driers Iíve bought lol
Stopped by Toyota today to pick up the drier and o-ring. The aftermarket drier (cheaper option ordered through Toyota) came with 2 green o-rings. I bought a denso drier from Rock Auto after the fact that was out for delivery today, but never delivered... hopefully it gets delivered tomorrow.
While there, I ordered the grommet and other rubber things associated with the condenser just in case.
Update 7:
Drove all over town with the dog running errands today and no issues since turning the A/C off other than the Ďshot bearingí noise.
Cooper
Old 06-08-2019, 03:51 PM #35
sam.basye's Avatar
sam.basye's Avatar
New parts!
Compressor appears to have come with all o-rings.
Condenser came with nothing
Drier came with two o-rings
Evaporator core came with two o-rings already attached
Expansion valve came with 4 green o-rings.
Anyone know why the new compressor clutch doesnít look like the one I have? Iíve got a rounded Ďflywheel likeí cover with holes on the front.
Part number is correct. Might be a newer updated version from the one produced in Ď99? Or do I need to remove it and install it on the new one?
Old 06-10-2019, 01:38 PM #36
phattyduck is just really nice phattyduck is just really nice phattyduck is just really nice phattyduck is just really nice phattyduck is just really nice
Looks like they just changed the style of mass attached to the front. You should probably just run the replacement as-is.
'16 Honda Odyssey
Old 06-11-2019, 01:15 AM #37
sam.basye's Avatar
sam.basye's Avatar
I think youíre probably right, Charlie.
Toyota called earlier and my extra grommets, whatever they are for the condenser are in. $5 worth of potential parts just in case.
Going to be a fun Friday!
They also replaced my remote battery for free last time. They give out free oil drain plug washers too!
It made another 3 hr drive to work on Saturday night without issue.
I can push the recycle / fresh air button and use the rear heater without issue. Lol. No defroster or A/C though.
I can probably even get the display and front heat back if I push auto, then push the A/C button real fast to turn the A/C off, but I donít want to screw with it too much and itís not cold in VA anymore. Lol
Old 06-15-2019, 05:07 PM #38
sam.basye's Avatar
sam.basye's Avatar
Got everything installed yesterday!
If you notice the temperature go up a couple degrees yesterday where you live around 4pm, sorry. Lol My contribution to global warming was quite the unexpected experience. Haha
Much more difficult than I was anticipating. Lol
Just need to order a new evaporator resistor and determine when I can have the system vacuumed and recharged.
The compressor bearing was non existent on the old one.
Can I safely turn on the A/C with no Freon in the lines, just the oil in the compressor, or should I wait until itís been recharged?
I wanna know if the fuse pops, but not if itíll screw something up...
As of lately Iíve apparently done something to the car gods.. a rock cracked the wifeís windshield today and the A/C in her car is now on the fritz. Lol
Old 06-17-2019, 01:35 PM #39
sam.basye's Avatar
sam.basye's Avatar
Dropped it off at the dealer near work to have the A/C system evacuated, leak tested, and recharged this morning. Hopefully they donít find anything else wrong with it, or my work. Lol
Quoted me $298 to do the job...
Old 06-17-2019, 01:45 PM #40
Hopefully you didn't get any oil in your face...
The AC system probably won't even turn on with no refrigerant in there, so you wouldn't have been able to test.
Good luck!
'16 Honda Odyssey
Old 06-17-2019, 10:51 PM #41
sam.basye's Avatar
sam.basye's Avatar
Good luck!
Crossing my fingers! No call today.
I backed out two of the bolts in the compressor manifold halfway and it started hissing, so I waited about 30 sec until it stopped and thought it was done. Backed out the third bolt halfway and it apparently wasnít done. Lol. Giant cloud of oil for about 15 sec shooting out of the wheel well! Luckily I was using a drill extension on them and the wind was blowing the other direction away from me, the car, the wifeís car, and the house. Got oil all over the wheel/wheel well. Hosed most of it off. My oil pan was of little use. lol
Old 06-20-2019, 09:10 PM #42
sam.basye's Avatar
sam.basye's Avatar
Update:
Found the balls to call Toyota to see how things were going, no word from them, and was told they charged it and everything works with no leaks! I didnít bother telling them it was blowing fuses. Iím thrilled that I put it all together and it didnít leak!! Haha.
Iíll be picking it up tomorrow afternoon when I get back from work and driving 3hrs home, then another 4.5 hour drive on Saturday morning and will update again!
Old 06-22-2019, 04:42 PM #43
sam.basye's Avatar
sam.basye's Avatar
Calling it fixed!
AC blows cold, not ice cold like I was expecting, but itís consistent and not blowing the gauge fuse.
Drive 4.5 hours today without issue. Fixed... Gauge, AC Compressor, and Alternator Regulator Failure
Old 10-10-2019, 12:42 AM #44
sam.basye's Avatar
sam.basye's Avatar
Update:
Still no issues.
For those interested in what my alternator brush looks like at 315k.
I was getting the battery light off and on from my cracked valve cover leaking directly on the alternator. Replaced the brush assembly and replaced valve cover and gaskets while I was at it.
alternator , assume , charging , compressor , drive
Alternator not charging at idle Drunner97 4th Gen T4Rs 44 01-30-2019 06:01 PM
Changed alternator, still not charging. meekie4 3rd gen T4Rs 21 11-05-2015 02:16 PM
What Volts does your Alternator show while charging?? ejason 5th gen T4Rs 6 05-14-2015 02:18 PM
4.7 Alternator not charging help PLZ! Need ideas. swapmeet 4th Gen T4Rs 17 03-31-2015 11:34 AM
Alternator charging post snapped(hopefully that is the right name.) thejonnyjones 3rd gen T4Rs 2 02-18-2014 07:20 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
