05-15-2019, 06:07 AM
Anyone using Toyota 90915-YZZD3 larger oil filter?
Just curious if anyone is using the Toyota 90915-YZZD3 on their 3.4? If so, what is the increased oil capacity/refill? Thinking of trying this larger filter on my 2000 T4R.
05-15-2019, 08:35 AM
I use the taller Motorcraft FL400s Been using them for years in my Saturn and 4Runner. I like only stocking 1 oil filter.
05-15-2019, 10:52 AM
I have been using the D3 on my 3rz pretty much since I bought it 5 ish years back. A little more oil in the system, a little more filter media, lots of room for it. No reason not to.
I haven't measured the difference in volume but I would guess it to be about 200 ml more. It doesn't change the number of quarts I have to buy for an oil change anyhow, just a little less left over.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
05-15-2019, 10:54 AM
I use the oversized and all-synthetic NAPA Pl.41516. Expensive, but I use Supertech oil and run it 7500 miles. 200k and going strong and great Blackstones. Been doing it this way since 100k
My Backyard Frame Swap
05-15-2019, 11:36 AM
I'm using the oversized Napa Gold (Wix) 1516 filter. It's equivalent to the Motorcraft FL400. Works great and I like stocking only 1 filter because I have two other Fords in the family that use this filter.
05-15-2019, 12:23 PM
Is the supertech synthetic or regular? I’ve been using the Motorcraft semi-syn lately.
05-15-2019, 12:54 PM
Full syn 5w-30
05-15-2019, 12:59 PM
I used it. You won't notice anything other than a piece of mind.
05-15-2019, 01:06 PM
Fits just fine, I got a 10-pack for cheap last year...
Best thing about the OEM filters: pre-lubed real o-rings!
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
05-15-2019, 08:45 PM
Real Name: Ron
Real Name: Ron
Yes, I switched my 3.4 Highlander over to it so only have to stock one filter.
Make sure you fill your filter with oil before you install it, takes about 3 fills to the threads before filter quits absorbing all the oil, this way you don't have to worry about how much more oil, just add the 4 Q's and you're good to go.
Also the filter doesn't have to fill on initial startup, it's already full.
05-16-2019, 12:45 AM
Real Name: Red
Real Name: Red
Difficult to do when you have to invert the filter to install it....
-ReD
Firefighter/Licensed Paramedic
*SOLD* 2000 4Runner Limited 4x4
2020 Ford F-150 3.5L EB
Build Thread
05-16-2019, 02:34 AM
I use a wix synthetic oversized filter too. I change it every other oil change. Filters get more effective as they load up, until they are stuffed!
05-16-2019, 10:13 AM
Interesting. Have you ever run a Blackstone doing that? I may try it and then run one, those filters aren't cheap.
05-16-2019, 11:31 AM
Still building a dataset, have only run 3 so far. Wear metals look good and don't seem to be affected by when the filter is changed.
05-16-2019, 12:06 PM
Real Name: Ed
Real Name: Ed
I already had the V8 filters for my 1st-gen Tundra and parents' GX470 when I bought the 3rd-gen.
