Old 05-27-2019, 03:06 PM #1
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
OBD-II reader that doesn't drain battery if permanently connected?
I have a bluetooth one but the light stays on all the time. I think Scangauges can be connected permanently correct? Does anyone know of a bluetooth reader that can be left plugged in and comes on with the ignition?
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 05-27-2019, 03:27 PM #2
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Ultraguage. Mine has been in for several years now. Truck can sit 2 to 3 weeks with no issues. If I’m leaving it longer I’ll pull the negative battery terminal.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 05-27-2019, 03:55 PM #3
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
ScangaugeII turns off with the truck. I leave my connected all the time.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 05-27-2019, 04:02 PM #4
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
The "power pin" in the OBD port is full time hot, battery hot. If you plug a BT reader directly in it will be powered full time. I plugged my BAFX in and forgot about it. Not significant enough battery drain to be concerned with.
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 05-27-2019, 04:10 PM #5
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
CK with manufacturer of your scanner..the draw should be quite low ..but...that depends on the chip in the dongle. The cheap ones will not feature a "sleep" mode.
Some will register as high as 32mA but taper off after 20 min to 2mA. The cheap e bay stuff can run high teens constantly.
SaulG is offline   Reply With QuoteReply With Quote
Old 05-27-2019, 06:56 PM #6
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
This is what I use in both my 3rd Gens. It works well as long as you remember to turn it off. No more battery drain.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
When people say it's not a big deal because it draws very little power, i guess it depends how long your vehicle sits between starts. If you use your rig everyday, probably not a big deal. If you let your rig sometimes sit for a week or two, maybe it is a big deal. The other thing I like about the on/off switch is it gets the ODB II reader to a different more secure location. I have mine velcroed in the cubby under the ashtray. The OBD II port points downward so gravity is working against you. On a bumpy fire road, my reader fell out before I had the switch installed. Also, with it dangling there in the reader port, I accidentally bumped it with my foot a few times making me think one day I'm going to end up braking my OBD II and/or the reader. So, the switch does more for you than just preventing you draining your battery.
Old 05-27-2019, 06:59 PM #7
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
Another for ultragauge, plugged in a month or so now with no issue, comes on with ignition
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 05-27-2019, 08:13 PM #8
My scangauge stays plugged into my Saturn SL all the time. No issues with battery drain. When I find a 99+ wreck to cut the overhead console cable from I’m putting a scangauge in my 97 4Runner also.
bluetooth , connected , permanently , plugged , reader
Battery draining constantly + wipers permanently running Maui Cruiser Classic T4Rs 2 03-28-2016 06:26 PM
Battery drain! Help! gbrunin 3rd gen T4Rs 8 04-10-2015 09:28 PM
Battery drain vicar 3rd gen T4Rs 2 08-09-2014 11:18 PM
engine cranks over and alarm sounds by itself when battery is connected--help! scarbajal Problems & Warranty Issues 1 01-14-2011 11:29 PM
'98 Battery Drain jranger35 3rd gen T4Rs 12 03-11-2008 08:10 PM
