Old 09-22-2022, 01:53 PM #226
rickashay's Avatar
rickashay rickashay is offline
Real Name: Addison
rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold
rickashay's Avatar
Real Name: Addison
Currently hunting for a 1UZ myself. Just missed a 95' last week. Curious if yours is VVTI or not?
Keep it!
rickashay is offline   Reply With QuoteReply With Quote
Old 09-25-2022, 01:21 PM #227
T4Rchadly's Avatar
T4Rchadly T4Rchadly is offline
Real Name: chad morrison
T4Rchadly is just really nice T4Rchadly is just really nice T4Rchadly is just really nice T4Rchadly is just really nice
T4Rchadly's Avatar
Keep it!
mine if not the VVTI just because of my intentions and availability as well.. i plan on boosting it down the road and i wanted the thicker rods (89-94) because i think you know how i ride.. i wanted to run bigger boost and be able to bump the rpm higher with the standalone, i planned on putting in bigger valve springs and ARP bolts/MLS gasket so i can get the rpm to above 8400 reliably.. i also got the engine from a junkyard for $300 and you see 90-97 ls400's around me all the time so i figured it would be the safer play if something catastrophic happens..
the VVTI wouldve been the best route and more fuel efficient but theyre harder to find around me, and you basically need an entire donor car for the immobilizer, transponder, the key to the transponder, the VVTI harness & the ecu itself.. the wiring is a little more tricky but if you get to that point DM me on instagram and i have an abundance of gathered info on making the vvti stuff work.
heres a picture on the rod sizes, you can swap the non vvti rods into a vvti engine but its more work than what i would want to do, i want this a reliable setup rather than a setup that is focused to achieve numbers
Lexus-Toyota-Rods
a huge reason i didnt want to even bother with a 2uz is the power/weight ratio (i dont want a iron block v8 if its not an LS/LT engine, it is a complete waste of time for the power gain), the rods are the smallest in thickness, the aftermarket support is a little more tricky to find, as you've seen a (few) 2uz swaps on these things, vs the amount of 1uz swaps people do on their vehicles & pickup chassis. a big argument is 2uz's have way more "low end power" but i dont need the low end power when i have a dual transfer case.. the power in lucy with the 37s is good enough, i want the mid to higher end power for towing with manual. the lower end power automatically comes with the swap of a v8 vs a garbage 300k mile 5vz so im not too worried. not to mention the better power/weight it evens out!! hope some of this info helped
T4Rchadly is offline   Reply With QuoteReply With Quote
Old 10-19-2022, 12:48 AM #228
T4Rchadly's Avatar
T4Rchadly's Avatar
progress is progress
my shoulder is healing good and have range of motion again so i can continue on with projects for lucy.. i sold the GS daily so now im stuck driving her for a little again.. heres 1uz and dual case updates. 1uz block all clean and ready for reseal. dual case ready to go in
IMG_7267
IMG_7269
IMG_7270
IMG_7273
IMG_7274
IMG_7448
IMG_7445
IMG_7449
IMG_7450
IMG_7452
putting vin of the engine for reference later on and so i can gget accurate mileage changes from the engine swap. i may or may not rollback the mileage with how much stuff ive already replaced and the fact im putting in a different rear end. its still on the fence but i wouldnt have crazy differences if i do rollback. the engine had 160k and i purchased lucy with 200,000 miles? with as much driving as i usually do 50k miles is pretty achievable in two-three years..
Old 10-22-2022, 03:08 PM #229
T4Rchadly's Avatar
T4Rchadly's Avatar
everything is clean and ready for reseal. rebuilt the alternator, rebuilding starter & power steering pump right now with OEM/denso parts. rebuilt throttle body and new OEM TPS, along with custom paint job in the intake plenum. i sprayed everything with aluminum colored engine enamel and then i ran a dark metallic to black fade job on those lines. i probably wont use the intake setup because theyre unusable after you supercharge, but i can probably sell them for a descent amount of money with not a lot of money put into it.
IMG_7506
IMG_7479
IMG_7480
i also sold the GS430 i had in attempt for looking to find a black LS430 as a daily, so i unfortunately have to daily lucy in the meantime. looking to do a VIP daily setup, nothing too crazy other than an OEM celsior kit and coilovers. dont really want to deal with bags. the GS was a super fun car so im excited to get back into another lexus
IMG_7043
IMG_7428
Old 11-06-2022, 08:25 PM #230
T4Rchadly's Avatar
T4Rchadly's Avatar
one of the biggest deals that needed to be fixed asap if i was going to drive this heffer again every day was it needs to drive without me wanting to commit.. (yes you know what im talking about) my rear lower links have been toast since my colorado trip and is TERRIFYING to drive with, hence i didnt drive it a single time up until i sold the GS. I went to the junkyard and talked the worker into saying these are swaybar links.. $9 later, i have two 350k mile lower links the old ones were HAMMERED, the bushings werent even connected, and one was bent. it atleast drives like it doesnt want to kill me now but you can still tell the truck shifts and is extyremely loose.. whatever.
IMG_7775
I have better stuff to do.. my fender has been screwed up from various events and cant really open my door, my lower portion keeps ripping the sheet metal screws, i was tired of being janky. fixed the fender to be "acceptable" and installed a plus nut on the bottom so i can go back to bolting it in. from my tub job i had to cut the OEM lower mount off so i sheet metal screwed it in, What are plus nuts?? this is the comparion to a standard rivnut. it provides far more clamping force, but is a little bit bigger in surface area.
IMG_7820
IMG_7815
Its clean... but somethings missing
IMG_7794
IMG_7808
IMG_7793
IMG_7832
I took all my lights off and sold other than the XL80's, theyll be back, just not as a ditch light. i wanted to go back to the grandpa look as i realized i hate how this thing has been looking lately, and it was never my intended goal, so i put my self back on track. no projector, i am going back to blinding people with LED's in reflector housing (o well, srry people)
also finally mounted my fire extinguisher after months (5/16 plus nuts to mount)
IMG_7827
as said, lucy drives fat better, but theres still wacky shifts when braking, harder acceleration. I had to go to the junkyard to get some corner light stuff because mine broke from the amber halos, etc, i wanted everything to be factory. i ended up finding a boned 4runner with poly bushing entire rear end. i snagged all pieces and it came out around $110 i think, that specific junkyard screws people on price, but at the same time just the lower bushings alone were like $80 and i dont have to spend the time pressing everything. im happy enough & my upper 300k mile links were completely smoked and completely loose. heres some before and afters of everything. dirves fantastic now
IMG_7867
IMG_7853
IMG_7857
IMG_7862
A really annoying issue ive been having is my suction cup for my garmin is almost useless and falls off super easy after about 3 years of use. i ened up making a RAM mount setup and a 19mm to 1 inch ball adapter to physically mount the garmin. everything is rock solid and im super content. i will be adding cigarette lighters and two quick USB chargers ontop of the dash to clean wiring up and have more USB outles (i seem to run out of all my outlets constantly somehow) i will do a pretty in depth tutorial on how i did everything when i get it done, i dont really see anyone doing this
IMG_7698
IMG_7699
IMG_7700
Old 11-08-2022, 03:34 PM #231
rickashay's Avatar
Real Name: Addison
rickashay's Avatar
Real Name: Addison
Stoked on the dual cases and motor swap updates.
How did you clean all the engine parts? Just good ol' wire brush and simple green or something more extreme? Taking notes...
Old 11-08-2022, 08:10 PM #232
T4Rchadly's Avatar
T4Rchadly's Avatar
i have been using a steam cleaner with all purpose degreaser. its not ideal but it does a descent job and gets everything clean. i wish i had a parts cleaner because the steam cleaner takes a very long time in comparison. its not terrible but its not ideal if that makes sense
Amazon.com - McCulloch MC1375 Canister Steam Cleaner with 20 Accessories, Extra-Long Power Cord, Chemical-Free Cleaning for Most Floors, Counters, Appliances, Windows, Autos, and More, 1-(Pack), Black - Carpet Steam Cleaners
this is the specific product i use. i have it for random car detailing stuff for personal use, and decided to try it on the car parts and it worked pretty good so ive been running it since
Old 11-10-2022, 12:28 AM #233
T4Rchadly's Avatar
T4Rchadly's Avatar
Dashboard USB/Cigarette outlets
I have been trying to do this project thats been in my head for a little now, and i figured id do another tutorial while im at it. I've been trying to change my power location and add more USB power for awhile, but didnt want to see form my cockpit. My power wire has been getting pinched and my shit boot always pops out from the pressure and i want access to the main cigarette lighter for awhile now, and you guys know i hate messy wiring by now.. lets see if this idea works out..
tools used
-calipers
-sharpie
-screw driver #2 phillips
-90 degree drill
-1 1/8" hole saw
-knife
IMG_7905
remove main dash bezel
IMG_7906
remove HVAC face vent
IMG_7909
IMG_7916
remove heating cable from the socket by pulling back, and then pull on the cable itself to give you slack to remove the actual hook. this will give you the room for your 90 degree drill and 1 1/8" holesaw bit
IMG_7918
looking inside out of the dash, theres a middle section thats flat, so i found the middle via calipers and ran a pilot bit and then the hole saw. this is just a test hit before i completely total out my dash
IMG_7919
Times for a second hole. i did this 1 1/4" to the side, eye to eye.
IMG_7928
At this point i have both outlets mounted, and im ready for wiring. my plan was splicing into the OEM cigarette lighter, and making a removable harness. so this is what i came up with. a main wire with a jumper to the other outlet. super clean
IMG_7932
I had to cut the vent so everything fite without bending. i dont notice and face vent loss of power, and i doubt it heats it enough to do damage.
IMG_7933
IMG_7923
IMG_7926
It turned out exactly how i imagined it. only has power on ignition, and i no longer see the wiring and have extra charge space now
Old 11-26-2022, 04:46 AM #234
T4Rchadly's Avatar
T4Rchadly's Avatar
more how-to stuff: rear hating
you guys know i have been on a tangent with "simplifying" lucy, deleting the most amount of stuff possible that i dont use or need, while still making everything comfortable. along with other things on the chopping block, lets just get this out of the way first. one time in moab alex, chase, hayden & i were messing around in the sand dunes one night and alex developed a weird leak.. we found that either his rear seating heater core or the line itself had cracked and was leaking coolant. we ended up bypassing the rear heating and got mroe coolant in the system. it spooked me out and ive seen it happen on a few different 4runners now. thus, another tutorial on how i completely deleted my rear heating. i do not have a lot of people sitting in the back, and i usually have the passenger seat blocked from my sleeping platform, so i dont think the rear heater does too much regardless. lets get on with it
1. these are your rear heating core lines, we'll name them O and G.
IMG_8357 2
2. you will remove the end of G where it mates to the heater core tube that goes underneath the vehicle. you will then remove O at the heater valve junction that is bolted to the firewall. remove the spring clamp and install into G. you will link G into that junction
IMG_8358
3. you now need to remove 3 10mm bolts. one half way down the firewall, one next to the catalytic converter, and one being the heater core "guard"
IMG_8360 2
IMG_8361
IMG_8362
4. you will remove O from the heater core. you will then remove G from the heater core tube, and link it into the heater core where O was. this will make a closed loop. remove heater core coolant tube (i cut the line in half to make removal fast)
IMG_8363 2
5. youve now removed the rear heating system of your 4runner. to take it to a further step, ive decided to remove the heater core and rear HVAC itself. i removed the seats, and center console. removed the 5 screws holding the HVAC in, and removed the grommet.
IMG_8364
6. take the control valve from center console out with the HVAC system
IMG_8365
7. OPTIONAL: install preferred sound deadening to decrease slight road noise decibel, and additional sound system acoustics.
Old 11-30-2022, 02:28 AM #235
T4Rchadly's Avatar
T4Rchadly's Avatar
dual transfer case
its been long overdue of getting this NWF case in, but i finally have everything done. i am super picky in terms of quality for parts, so lets see how this goes.
i decided to use 85-140 SAE gear oil to break things in for a couple thousand miles and then go to synthetic
IMG_8108
tom woods driveshatfs. both were the baddest units i could get in terms of tubing thickness. these things are hefty especially with the new 1310 joints
IMG_8129
getting the OEM case took approx 15 minutes or less. take out the outpu/input shaft adapter and install to new NWF input shaft
IMG_8172
heres when the first round of things gets frustrating.. you only hear the good things with these kits so far, and ill give my honest input. For $4,000, (including driveshafts) you get only what assembles the dual case kit, with the NWF case kit being around $3,000. you are given zinc coated hardware that rust over time, you are forced to ruin a 13mm wrench that they dont include ( you need to bend a wrench 90 degrees. my stubby wrenches and my snapon bent wrench set were too large ), the top two studs are near impossible to tighten, some of the shifters were pre-loose internally inside of the triple stick units (had to take them apart to loctite and tighten), my biggest gripe being you are given no gasket for the triple sticks and you are forced to use RTV. Inside one of the shifter plates, is a seal held in by a machined o-ring. NWF doesn't give you RTV, a gasket, and didnt machine an o ring to keep an oil seal onto of the shift plates. For $3,000, youd think you wouldnt have to use stone-age RTV when theres already machining done for o rings on other parts of that kit. theres more down the road but lets finish the install.
IMG_8194
IMG_8206
IMG_8205
IMG_8227
IMG_8244
i replaced a output seal they didnt include (again, im being whiney but for $3,000 i expected a little more) it was kind of weird the $25 oem seal was a different size than the original one that was in it. the space was SUPER hard to work with while the transfer case was clocked at 16 degrees, although you can see if pulls the drop pretty far up now. because of the casing fill and drain being parallel, i had to put lucy at a big angle to get all the gear oil in lol, i got a lil sketchy with it. at this point, first initial drive the transfer case smacks and vibrates on the trans tunnel immediately. i banged it with a hammer but wasnt good enough.
after about 20 minutes of driving, i took a double check on my work to find out it was PISSING oil out of 3 spots.. i dump oil, and take care of one. NWF doesnt state to use any sort of thread sealer on the lid, so i just tightened them down. i now know YOU NEED TO APPLY THREAD SEALANT on all thread ports of the lid. i find the second leak.. for some reason my RTV didnt work.. and lastly, the top right detent plug was leaking. i thread sealed the 19mm plug on the bottom, ill just do this top one. THE STUPID STUD IS BLOCKING IT.. super annoying, ill just take the stud out. THEY MADE IT TOO LONG and i cant remove the stud. so, time to drop the case again.
IMG_8402
taking the case out, 2 cups full of gear oil spills out. the seal i got from toyota wasnt correct. so a full day of running to parts stores, i found that the seal from toyota is a new super-seeded PN for a "newer case" they said. i found the correct seal, and installed it. i will give all length dimensions of shafts, same with part numbers i had to use to install this case. again, NWF couldve easily supplied this $7 seal with the kit. these are the differences
IMG_8415
old, front & new, on the rear. the new correct seal is 5mm tall while the old OEM one being 2mm, not even sealing the input shaft
IMG_8417
IMG_8419
the vibration with the transfer case clocked at 16 degrees was annoying so i changed it to 10 degrees. i also removed both stupid top studs. DO NOT INSTALL THE TOP TWO STUDS ON YOUR NWF CASE. serviceability is vital. i installed 2 Stainless steel torx bolts that are removable instead, it was a lot easier to install as well given theres no room. i also fixed the RTV leak on the rear-side triple stick unit. everything is finally fixed. man handled the beast back in and drove it.. ANOTHER LEAK from somewhere up top. super frustrated with how many leaks im having. my entire frame/ axle is soaked in gear oil
i know i am being very whiney and nitpicky. for a $4,000 install, id hope its a completely flawless setup in my mind. this is the most expensive case on the market, and i feel like they could've done more if im being honest in terms of serviceability and hardware. enough of the nagging
i am very insanely stoked on this dual case and 4 lo lo is ABSURD, it is awesome. my new crawl ratio is now at 123:1 ! this is something ive been wanting to do to lucy since ownership and im glad i finally got it done. i am trying to get a bunch of things done before one of my first trips set in april and this was the biggest piece i needed. the NWF lid/base setup is friggen BEEF and i have a lot of peace at mind with my input shaft being chromoly. it sounds like a lot of bigger tire people go thru input shafts with their marlin/TG setup.
Old 12-01-2022, 02:58 AM #236
T4Rchadly's Avatar
T4Rchadly's Avatar
asked a lot on instagram to post on here, these are my part numbers and dimensions used for the dual case swap. the national oil seal is the correct output shaft seal for the transmission. id prefer oem but national is a good brand. the "T type" seals are the front and rear output seals for the transfer case where it meets the companion flange, and lastly the hub transfer ring that i had broke during assembly. the driveshaft dimensions are circled red. but for your knowlegde, because the extension was 6.5", i got a 6.5 inch shorter rear shaft than oem, and added 6" to oem front shaft length. pretty simple
IMG_8471
IMG_8474
IMG_8472
Old 12-01-2022, 10:26 PM #237
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Is this the ecocrawler or something else? Have you got it buttoned up and no longer leaking or are you still fighting it?
I think I'd be well into the four letter word section of my vocabulary at this point too.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 12-04-2022, 12:19 PM #238
T4Rchadly's Avatar
T4Rchadly's Avatar
yes its the eco crawler !
i havent looked at the new leak yet. skiing has been more important now that my shoulder is finally good enough to "take it easy"
Old 12-04-2022, 12:41 PM #239
T4Rchadly's Avatar
T4Rchadly's Avatar
new bumper day
ive been tired of no cleareance, approach, how heavy the ARB was, and the fact that the winch housing was too small for me to use the 100 foot winch-line, making my winch useless pretty much. knowing EVERYONE wants an ARB for some reason, i present you
IMG_8441
sold it within 30 minutes posting for a pretty penny... i didnt really lose any money buying vs selling
at this point, ive been wanting tube front bumper for awhile. there wasnt many options and i dont own a tube bender. my only option was addicted offroad which ive heard good things about, other than approach angle. thus, my journey on achieving better approach angle
the orignal way youre supposed to mount this, is the same way for an ARB. bolt thru the frame horn, two bolts on the bottom. after a test fit, the approach wasnt great, as expected upon purchase
IMG_8445
first set of trimming: i kind of had a guideline from a friend on how he pushed it back 1.5", but i ended up being able to take advantage of 2" somehow. i forgot to take before measurement pictures unfortunately otherwise id include before and after measurements. i cut 1.75" off my frame horn, followed by cutting about 1.25" off the side of the addicted offroad mounting crossmember. i had to cut out my original skid plate mount to do this
chopped frame, untouched crossmember
IMG_8451
IMG_8459
IMG_8462
sucked back in. at this point the framehorn wasnt flush with the crossmember end, so i cut more crossmember and pushed it back the last approx. 1/4 inch. again ive failed and forgot to take pictures
IMG_8470
test fits with the new 2001-2002 grille
IMG_8490
IMG_8493
IMG_8491
IMG_8475
IMG_8476
kinda looks good like this welded the crossmember in along with a few gussets for bracing. i had to mount the skidplate to the bottom of the crossmember. i used two m10 bolts to secure the budbuilt crossmember. an issue is that its sucked really tight against the diff drop and its now spring-loaded. dont really know what to do about it i need to call some bigger offroad friends on ideas
IMG_8563
IMG_8562
IMG_8560
IMG_8551
winter mode back in plus new bumper!! really excited on the new look. i will be adding headlight hoops in and i need to put in my XL80's and my winch in still. lastly, the before and afters of approach angle of pushing the crossmember back
IMG_8445
IMG_8465
Old 12-06-2022, 02:33 PM #240
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
@T4Rchadly nice job on the bumper, looks great! I did the same thing with my hybrid AOR bumper. I think you got it sucked in just a tad bit more than I did though.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
4runner , build , pickup , runner , thread
2001 4runner long travel/rock crawler build $$20k in Buna TX zwalker16 For Sale: Vehicles 1 09-02-2022 12:58 PM
T4rchadly's '96 "RADRNR" build thread *pic heavy* T4Rchadly 3rd gen T4Rs 57 05-02-2021 03:57 PM
Rock make build thread. meRockboost 3rd gen T4Rs 33 11-26-2015 12:26 AM
Kraze's Mall Crawler build thread Kraze 3rd gen T4Rs 310 11-04-2015 11:11 AM
'06 XSP to Mall Crawler Build Thread (PICS) SellSwords 4th Gen T4Rs 11 03-15-2015 06:30 PM
