Old 03-26-2020, 11:27 AM #46
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about
Real Name: Ryan
Heal up the knee! I had ACL/MCL back in 2012 and 3 surgeries later it's still never been the same.
New wheels look great!
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
1999 BMW Z3M Roadster
2020 Super White ORP
Ryance39 is offline   Reply With QuoteReply With Quote
Old 03-26-2020, 05:52 PM #47
T4Rchadly's Avatar
T4Rchadly T4Rchadly is offline
Real Name: chad morrison
T4Rchadly is just really nice T4Rchadly is just really nice T4Rchadly is just really nice T4Rchadly is just really nice
T4Rchadly's Avatar
thanks ryance! trying to take it easy with the knee. thats not necessarily something im good at
T4Rchadly is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 09:17 PM #48
T4Rchadly's Avatar
T4Rchadly's Avatar
Fridge setup + small updates
small little update. i just got an 50QT ARB fridge/freezer. i knew my tiny redtop battery would get annihilated instantly. so, i forked the wallet out and did things the right way.
IMG_2788
IMG_2792
IMG_2799
IMG_2796
i upgraded to the Northstar 27F battery. for $400, it came in with a 5 year battery warranty so it gives me some hope- really hoping i dont run into issues down the road (mainly in wintertime when im skiing in the middle of absolute nowhere) luckily i did not need to install a custom battery tie-down as this barely fits and its going nowhere. please dont mind the very ugly 2 red wires.. ill sheath them soon. i installed the powersource to the ARB fridge using ARB's install kit with basic 10 gauge wire and a custom adapter that the fridges use for 12v source. i hard wired it directly to the battery and fished it through the cab and to the rear panel behind the seats- turned out very clean and professional as always (i love wiring)
on the second hand, snow wheeling in idaho left me with a blown line and broken fairlead.. replaced the line for some higher quality synthetic rope, and finally installed the fairlead after a couple of weeks. i had to find some square nuts to fit in the mounting plate of the x20 winch.
IMG_2786
IMG_2787
im still waiting on a lot of goodies due to carona virus but ill be SURE to post after i get everything sorted out and on heres a little sneakpeak
IMG_2794
lastly, i finally got around to installing my emkeith PCK kit. super easy to do. i plated the top mount and welded in the middle of the sides of plate for stress relieve when i get to JUMPING this bad girl you can really see the damage of what SLC winter had did to me. while in alaska, you could lick the frame and have a clean tongue afterwards! since SLC and the red clay of arizona really has made a difference to the frame, im going to address this soon..
IMG_2804
IMG_2801
Old 03-31-2020, 09:23 PM #49
T4Rchadly's Avatar
T4Rchadly's Avatar
i also started posting again on youtube. please take a look at my link if youd like to see some footage of wheeling broken arrow trailhead in sedona, arizona.
Old 04-07-2020, 12:52 AM #50
T4Rchadly's Avatar
T4Rchadly's Avatar
i did more investigating and found out that the 210's are similar to a 7.5 wrap that Sonoran steel uses, just i think 30lbs different in weight holding, and also not variable spring weight.. the part number Sonoran uses is (48131-6A570) and i assume if you use a stiffer shock it would help with carrying the load, thus a safe an known shock is the black tokico. (48531-69417) the end total for this setup online is $367.30 after shipping fees.. the only issue is that if im not mistaken it does have driver lean and need a 1/2" spacer for just the driver side.
i may just be pulling the trigger as i think im about to really add some weight in the next 2 weeks with a sleeping platform/drawer system..
1994 LC
Front right 48131-6A570 18.7 inches
Front left 48131-6A480 19.5 inches
91 LC without alumn wheel
Front right 48131-60230 20.5 inches
Front left 48131-60810 21 inches
91 LC with alumn wheel
Front right 48131-60260 20.9 inches
Front left 48131-60820 21.1 inches
dobinson 210V
475mm (one side) = 18.7inch
185mm (other side) = 19.1 inch
with that being said, theres a .4 inch difference (3/8s difference).. i have a lil skips gas tank skid so i think with the 55 lbs it should bring it down to atleast a 1/4 inch difference.. i think im going to pull the trigger and proceed with the 1994 LC springs
Old 04-16-2020, 03:04 AM #51
T4Rchadly's Avatar
T4Rchadly's Avatar
Drawer system, rock lights, and bumptops.
bit of a bigger post..
i installed some RGD rock lights specifically for camping and obviously if i go night wheeling.. i had a huge debate with myself whether or not to just get white LED only or the RGB's.. i never dealt with an RGB light so i figured why not and went on with it. installed 8 rock lights total facing the ground for actual ground visability rather than sticking them in my wheel wells.
IMG_2919
IMG_2916
IMG_2915
next up was that i had purchased a system ive been wanting for quite some time but never got around to. in order for me to get that done, i really wanted to get something out of the way first..
in phoenix, AZ i got my rear hatch tined 5% with ceramic coated tint to keep from people snooping in the back, and to darken up my rear section. i also been eying on a product and figured id go full send and completely wrap my rear quarter window with matte black 3M vinyl. this will also protect from light getting in the back of vehicle also deturring from people snooping around.
IMG_2944
IMG_2946
now that is all done, its time to run down to tuscon. i have been talking to a guy by the name of mike mckinsey that is in a few offroad groups that builds drawer systems for toyotas. his prices were insanely reasonable and super hard to beat compared to other systems so i figured supporting local businesses would be great. behold the mckinsey craft drawer system
IMG_2929
IMG_2939
IMG_2938
IMG_2933
IMG_2936
i stated i needed a cutting board and a sleeping platform because i live in the 4runner. he got me hooked up with a very clean and well built system. this thing is tough.. the platform is easily removable incase i need to put the seat back up or get the bottle jack.. Oh and remember that product ive been "eyeing on"?? this is what im talking about
IMG_2949
ive been also talking to brian with outbound nevada with a new version of rago's modular panels. these are a different design being shorter,closer to the panel, and with his logo. these are a lot cheaper than ragos along with not having ot wait 8 weeks.. i will be puting camping related stuff on this for more space..
Old 04-16-2020, 03:06 AM #52
T4Rchadly's Avatar
T4Rchadly's Avatar
lastly, i installed new durobump bumpstops. i just installed these today so no review yet. im also waiting on suspension stuff that has taken over a month to ship out.... thanks covid.
IMG_9295
Old 04-16-2020, 11:14 AM #53
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
wow that rear drawer and molle panel look great, do either of those guys have websites?
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 04-16-2020, 02:17 PM #54
T4Rchadly's Avatar
T4Rchadly's Avatar
i do not believe these guys offer an official website yet but i know theyre in the works of one. in the meantime to communicate to them their IG handles are
@pullingamikej
@outbound _nevada
theyd be more than happy for you to contact them for some products
Old 04-16-2020, 03:14 PM #55
@pullingamikej
@outbound _nevada
thank you!!!
IG: mesooohoppy
Old 04-16-2020, 11:00 PM #56
Chuckles89's Avatar
Chuckles89 Chuckles89 is offline
Real Name: Charlie
Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about
Chuckles89's Avatar
Real Name: Charlie
Nice build!
Originally Posted by STX4Runner View Post
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
Chuckles89 is offline   Reply With QuoteReply With Quote
Old 04-18-2020, 07:50 PM #57
T4Rchadly's Avatar
T4Rchadly's Avatar
Originally Posted by Chuckles89 View Post
Nice build!
thanks!!
Old 04-20-2020, 02:37 PM #58
T4Rchadly's Avatar
T4Rchadly's Avatar
Walk around video
hey guys! heres a video of an updated version walk around of my truck. this thread has more in depth goodies and a few mods i didnt mention in the video, but it gives some better perspective if i havent covered something on this thread.
Old 04-21-2020, 08:17 PM #59
T4Rchadly's Avatar
T4Rchadly's Avatar
window switch
Remote rear window button
this is just for my sake later when i get back from camping. need to do this
Old 04-22-2020, 10:12 PM #60
jeredcollins's Avatar
jeredcollins jeredcollins is offline
jeredcollins is on a distinguished road
@pullingamikej
@outbound _nevada
I can't find the name outbound_nevada on the search function. Do you have any other way of contacting him about his mod panels?
jeredcollins is offline   Reply With QuoteReply With Quote
4runner , build , pickup , runner , thread
2001 4runner long travel/rock crawler build $$20k in Buna TX zwalker16 For Sale: Vehicles 1 09-02-2022 12:58 PM
T4rchadly's '96 "RADRNR" build thread *pic heavy* T4Rchadly 3rd gen T4Rs 57 05-02-2021 03:57 PM
Rock make build thread. meRockboost 3rd gen T4Rs 33 11-26-2015 12:26 AM
Kraze's Mall Crawler build thread Kraze 3rd gen T4Rs 310 11-04-2015 11:11 AM
'06 XSP to Mall Crawler Build Thread (PICS) SellSwords 4th Gen T4Rs 11 03-15-2015 06:30 PM
