Old 05-27-2019, 08:53 PM #1
ir0nma1den ir0nma1den is offline
ir0nma1den is on a distinguished road
Question Big thunk when going from parked to drive
I have a 2000 4Runner that I installed tundra front brakes on. I also had to replace the transmission because it looks like they had a pink milkshake case two years before I bought it. When it's cold outside (below 40 or 30F) and I start the 4runner from cold I'm running into an issue where I will press on the accelerator and my truck won't budge, but then once I continue to add more pressure it "releases" and my car lurches forward with a big "thunk" sound. It's pretty jarring and something is clearly stuck.
The weird thing is, when it's slightly warmer, nothing happens. The truck will smoothly roll from a parked position to driving. If I put in in reverse, whether hot or cold, the truck will move fine. For some reason, forward driving from a cold start during cold weather will produce this issue.
ir0nma1den is offline   Reply With QuoteReply With Quote
Old 05-27-2019, 10:39 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I think your rear brake shoes are sticking. Time for a rear brake inspection.
Old 05-27-2019, 11:51 PM #3
tcbaklash's Avatar
tcbaklash tcbaklash is offline
tcbaklash is on a distinguished road
tcbaklash's Avatar
Agreed. I have sticky rear brakes from a leaking rear axle and it's just like OP described.
'00 4Runner SR5 (242,100 miles)
3" Toytec/Bilstein lift, 285/75r16 BFG KO2s
'16 Ford Fiesta ST, pushing more boost than I should be
tcbaklash is offline   Reply With QuoteReply With Quote
cold , driving , forward , thunk , truck
4wd thunk when spinning Black798 3rd gen T4Rs 4 12-14-2016 11:13 PM
!! Thunk !! ghs215 4th Gen T4Rs 2 10-23-2013 09:44 PM
Thunk thunk at end of braking? bigtimeweb 3rd gen T4Rs 17 08-18-2011 11:46 PM
I parked next to an SR5... FERAL 4R 5th gen T4Rs 3 07-24-2011 08:33 AM
Drive shaft thunk & clunk 007Runner 4th Gen T4Rs 6 12-27-2006 09:05 PM
