Old 05-28-2019, 12:41 PM #1
Temple90 Temple90 is offline
Temple90 is on a distinguished road
Best way to protect new rear axle
Like many others living in the northeast, my axle housing rusted out. I found a mint rust free replacement and plan on swapping everything over. I wanted to know what the best way to protect it from rust would be.
I don't know if I want to take a wire wheel to it considering the factory coating is still intact. Is there anything I can spray over the factory coating to protect it?
Thanks in advance!
Temple90 is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 02:14 PM #2
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Many products to choose from that will help protect it from the elements. I personally like LPS 3 but many on here like Fluid Film or even WD40, all will work good. Just coat it a couple times a year (and your frame , inside and out) and it will keep the rust at bay.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 03:47 PM #3
tvpierce's Avatar
tvpierce tvpierce is offline
tvpierce will become famous soon enough
tvpierce's Avatar
Boiled linseed oil.
tvpierce is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 04:43 PM #4
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
Thanks in advance!
Dont wire wheel it, use some 180 grit sand paper to rough it up. Then paint with something strong like roll bar & chassis paint.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 06:04 PM #5
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
Factory paint is garbage, it will rust at all welds. If it really is pristine with no rust I'd degrease it with POR degreaser then spray with rubbing alcohol to finish it off. Then spray with a black automotive spray paint. Don't use any of those tough monstaliner type paints since if they get compromised they will trap moisture and salt underneath and rust quickly. I saw a sad case of a cruiser with that. They thought they were protecting it from rust.
Then spray with an oil based coating of your choice. You could skip all the painting and go straight to the oil but since it's so clean it will be easy to paint.
Particularly pay attention to the diff pumpkin cover, that metal rusts really easy and it doesnt flake off. It just goes deeper and deeper.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 07:34 AM #6
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Regardless if the paint is mint or you repaint it with whatever......Do seasonal coatings of a weapon of your choice, you'll need to do it before every winter season. A true salt belt warrior doesn't have their rig rot out cause they prevent it with diligence. A seasonal spray down takes less than 30 minutes.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
axle , coating , factory , protect , rust
Rear Axle Seal: Axle Puller Tool Design nobb 3rd gen T4Rs 29 11-23-2019 07:39 AM
WTB: Philadelphia- Non rusty 3rd gen rear axle of rear axle cover 4:10 Temple90 Want to Buy/Trade 0 05-14-2019 12:34 PM
Rear axle/suspension problem-axle shifts when going on/off the gas Rusty Plum 3rd gen T4Rs 7 09-07-2014 09:46 PM
Where do I buy these things that protect the rear fender (1st Gen with Pics) GPEV Classic T4Rs 2 03-10-2009 05:11 PM
