Old 05-29-2019, 10:23 PM #16
Ehahn84's Avatar
Ehahn84 Ehahn84 is offline
Ehahn84 is on a distinguished road
Ehahn84's Avatar
This was happening to my 4Runner and got worse and worse. Ended up being a trashed HG that was opening up when cooled down and seeping coolant into cylinders 3 and 5. Ended up throwing a new motor in.
2017 TRD Off-Road Premium. Magnetic Grey. Dual Odyssey battery setup. Falken Wildpeak AT3W. Diode Dynamics SS3. Rigid Dually Spotties.
Ehahn84 is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 01:36 AM #17
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
I purchased a 97 with a bad head gasket the heads were still good sent them to the machine shop had them resurfaced and valves cut 350.00 at the machine shop, head gasket set bolts, water pump hoses ,timing belt. It's running great doing a full service going to be giving it to my brother and sister inlaw soon. Hoping it will treat them well. This part of the repair was about 1,000.00. I could have gone a JDM or other used engine but could have been back at the same place. I us higher end parts I get mine threw Rock Auto. There are a lot cheaper parts out there but would hate to have to redo work so I spent the money up front.
plcfcng is offline   Reply With QuoteReply With Quote
Old 07-16-2019, 11:44 PM #18
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend has a spectacular aura about 4runnerfiend has a spectacular aura about
update
took the rig into the shop and it failed the block test.
Ended up with 2 cracked heads.
Hope this helps someone diagnose in the future.
Seems like white smoke, running rough at start up is the tell tell sign
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
4runnerfiend is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 07:02 AM #19
That is how it was for me twice.
Old 07-17-2019, 10:55 AM #20
ouch! twice. yeah I hope this is it for me. I went with the shops recommendation rebuilding the top end with brand new heads. trying to get it right the first time.
Old 07-18-2019, 12:47 PM #21
PHGen3 PHGen3 is offline
PHGen3 is on a distinguished road
I bought the truck not knowing it was losing about 12 oz of coolant every 7-800 miles. It took pressure check to find out it blew out white smoke at start up. It had a cracked head.
PHGen3 is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 03:36 PM #22
The 97 limited Puppy Hauler started the ruff cold start with white vapor and coolant loss. My combustion gas tester went green and the valley between the heads was full of antifreeze. Then while she was driving mine, while I was doing her heads, mine started doing the same dam thing.
Mine was a corroded cylinder liner that eroded through and would flood the cylinder. I posted a thread on figuring out what caused it.
Old 07-18-2019, 10:07 PM #23
nissanh nissanh is offline
Clean the reservoir and the lid located on it (not the radiator cap). Probably the lid is clogged preventing the expanded coolant to enter the reservoir. When cold, radiator should pull coolant from the reservoir into the radiator.
cold , coolant , full , hot , low
V6- coolant not siphoning back from coolant overflow (not overheating) djtc 4th Gen T4Rs 32 08-27-2021 10:13 AM
Coolant: Rad is full, reservoir empty. Wut? zazzomicron 3rd gen T4Rs 16 11-25-2019 10:47 PM
Coolant Overflow Full bricew25 4th Gen T4Rs 1 05-19-2019 06:46 PM
Full Coolant Flush ? Co4Fun 3rd gen T4Rs 8 01-31-2017 03:05 PM
AC Full but still not cold, next steps? Rocky5000100 3rd gen T4Rs 6 07-26-2013 12:26 AM
