Old 05-29-2019, 12:14 AM #1
Runrunrunrun Runrunrunrun is offline
Runrunrunrun is on a distinguished road
Mysterious Leak Behind Transmission Dipstick
New owner, strange day.
After a seafoam treatment via gas tank / crank case / throttle body, I did an oil change. Smooth sailing.
Drove to the airport, parked, notice fluid on the rear bumper, look under the vehicle and see a big leak under the passenger side of the engine bay. It was mostly clear and didn't have any strong oder.
I think the source of the leak was this valve behind the transmission dipstick. I've been going through the manual and this forum trying to figure out what this valve is for, hoping I can get some help. What dumped out?
I had to hop on a plane 30 min after seeing this leak so hopefully when I land I can have someone meet me at the airport with fluids.
Thanks in advance!
Mysterious Leak Behind Transmission Dipstick-img_3520-jpg
Runrunrunrun is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 12:29 AM #2
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
Are you sure it's not the AC condensate drain?
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 12:40 AM #3
Looking into that, seems to be it! More fluid than I had ever seen before come out of the truck after driving with AC, but it's only been a week so learning as I go.
Thank you!
Old 05-29-2019, 08:43 AM #4
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
The AC drain may have been plugged up then it finally cleared up and drained all the water out at once. Are your carpets on the passenger side wet at all? I see you're in New Orleans so I'm assuming it's humid AF, everything is probably fine.
Thankfully your clear liquid was just water so you should be good to go.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 04:21 PM #5
Yup hot and humid season. Didn't get a chance to check the carpets. I did hear a clanking and I wonder if the metal elbow that usually sits on there fell off amidst the purge.
airport , dipstick , leak , transmission , valve
Need help with mysterious major oil leak Outrider 3rd gen T4Rs 152 12-03-2018 01:08 PM
Mysterious Coolant Leak... WheelinGypsy 3rd gen T4Rs 9 10-10-2018 12:40 AM
Mysterious water leak?.? Kotrin 3rd gen T4Rs 47 01-15-2018 01:34 AM
Mysterious Oil Leak stever1000 3rd gen T4Rs 11 04-11-2017 07:12 PM
HELP Needed - Mysterious Oil Leak Dylan 4th Gen T4Rs 22 07-27-2014 12:04 PM
