Old 05-29-2019, 02:29 PM #1
Dezerts10 Dezerts10 is offline
Dezerts10 is on a distinguished road
5/8th wheel stud upgrade
Has anyone ever changed their 12 x 1.5mm front hub wheel studds to something larger?
I’m in the process of buying a 9” rearend with full floater hubs and they have 5/8th studs in them and want front and rear to match.
Is it possible?
Dezerts10 is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 03:46 PM #2
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
Is it possible?
What bolt pattern? If it's a 5x5 bolt pattern there are wheel spacer adapters you can buy but I wouldn't get anywhere near one of those.
You should talk to Brian at Front Range Offroad, he has a wealth of knowledge about these things and should be able to point you in the right direction.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 06:44 PM #3
3rd gen 4runners are 6 x 5.5 I am not interested in wheel spacers that’s for sure
Old 05-29-2019, 06:49 PM #4
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
I think he was asking if 5 lug because it’s a Ford 9”. How easy is it to convert one to 6x5.5?
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 06:51 PM #5
Quantumkiwi's Avatar
Quantumkiwi Quantumkiwi is offline
Quantumkiwi will become famous soon enough
Is it possible?
I don't think I've seen anyone do it, but if you just want the studs to match, you could probably pull the hubs, and get a machine shop to drill the stud holes (oh that sounds dirty!) out to the right size for 5/8ths, then put some new studs in.
2000 SR5 - Build Thread
Quantumkiwi is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 08:37 PM #6
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
5/8ths is a huge stud. 2mm bigger than a Silverado 3500. Why do you need this? Are you into extreme wheeling? No American full sized 1 ton dump trucks use wheel studs that big.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 09:00 PM #7
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
modify the rear to match?
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 09:04 PM #8
det107 det107 is offline
det107 is on a distinguished road
So he can do sweet jumps & drive home-
det107 is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 09:43 PM #9
Custom rearend. Look up camburg off road race rearends and hubs. That’s what I have
Old 05-29-2019, 09:45 PM #10
I work at a machine shop so that’s the plan it’s fairly straight forward I just don’t want to do something to my drivers hubs and it not work.
Old 05-29-2019, 09:45 PM #11
Off road racing hubs, 5/8th is just basically standard
Old 05-29-2019, 09:47 PM #12
That is also a possibility I may look into cause I would then not have to drill out my wheels for 5/8. Only thing is I dunno how easy it would be to find a 12mm with the knurled section the same size and the 5/8 studs.
Just another issue in the world of building a toy
Old 05-29-2019, 10:06 PM #13
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
can you just clock the pattern in the flange? (apologies, I have no visual of what you're working with)
keith
eimkeith.com
Old 05-29-2019, 10:17 PM #14
Camburg 2.25 Rear Hub Kit [6 on 5.5 x 35 spline] | Camburg Engineering
There pictures is of a 5 lug hub but these are the rear hubs for the rearend.
Old 05-29-2019, 10:19 PM #15
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
if they're 5 on 5.5 I'd think you could re-drill the pattern, clocked, no?
- it's a thought.
keith
eimkeith.com
5/8th , front , full , studs , wheel
Rear Wheel Stud theiting 3rd gen T4Rs 16 06-09-2017 11:37 AM
Wheel Lug Nut Stud Replacement mtbtim 3rd gen T4Rs 8 05-25-2017 10:53 AM
Wheel Stud Issue!! Franky_Dabbs 3rd gen T4Rs 3 04-15-2015 06:34 PM
Broken Wheel Stud laxbro19 Classic T4Rs 2 05-16-2014 04:04 PM
wheel stud broke Toyboomer 4th Gen T4Rs 4 08-20-2011 11:36 PM
