Old 05-30-2019, 06:46 PM #1
Jack Wruff Jack Wruff is offline
Jack Wruff is on a distinguished road
2002 4Runner Wandering Steering Fixed......and how !!
Big Fix on 2002 Toyota 4Runner.
Steering has wandered ever since buying 15 months ago and yesterday I found a thread that contained the solution. Required pulling steering column out and welding the slip link solid. Such a silly design feature. All other threads had a need to replace just about all items connected to steering. This fix is magic, takes all the random aspects of this car away and allows me to relax so much more which means more brain cells focusing on the simple act of driving. Very happy.
More driving and the detail increases. Because I don't have to chase the steering, the whole chassis is now so much more stable. In chasing the steering, the sway content is increased. I didn't realize how much !! 15 months of dissatisfaction is washed away. It's not a Volvo but is now a drivable car. Our first trip had it that at 300 miles, I was pooped out. Just reckoned I was getting too old for high mileage runs. Rubbish, this car will roll many miles without fatigue setting in and we have 3000 miles to do in Aug/Sept so I think the daunting aspect has gone. Just amazed at the change.
Jack Wruff is offline   Reply With QuoteReply With Quote
Old 05-31-2019, 12:24 AM #2
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
Glad to hear you solved it. Could the same results be achieved if you replaced the slip joint?
I replaced my steering rack bushings, but there is still some marginal play in the wheel. I have new Toyota tie rods I'll be installing to see if it helps any.
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 05-31-2019, 12:48 AM #3
AZBub's Avatar
AZBub AZBub is offline
Real Name: Chris
AZBub will become famous soon enough AZBub will become famous soon enough
AZBub's Avatar
Real Name: Chris
The power of the search function helps another member. I used a roll pin, worked great, been there for years now.
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
AZBub is offline   Reply With QuoteReply With Quote
Old 05-31-2019, 02:49 AM #4
silver4est silver4est is offline
silver4est is on a distinguished road
Yes you can attain the same result by replacing the slip joint, but this way saves lots of dollars.
My question is, can a pre 98 steering shaft be used on a 99+? those did not have the slip joint correct? I have not been able to find anyone local that will allow me to do this, not even farmer friends that weld and jerry rid their equipment.
I don't see much difference between this fix and using a non collapsing shaft, except this "may" still collapse in the event of accident
can seek out a 98ish steering shaft from junkyard and swap it in?
silver4est is offline   Reply With QuoteReply With Quote
Old 05-31-2019, 10:23 AM #5
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
The 98s certainly still have the slip joint. A friend of mine welded his 98 slip joint for the same fix.
He also had to do the "spacer" mod shown in Timmy's video here, which reduces the slop in the plastic ball hinge joint: YouTube
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
4runner , car , driving , miles , steering
255/75R17 and spacers-- Wandering/Loose Steering ecufishbowl 4th Gen T4Rs 9 09-14-2016 01:34 PM
Wandering,sloppy, scary steering jreask 3rd gen T4Rs 12 09-02-2010 08:28 PM
85 T4R steering problem fixed garey Classic T4Rs 0 05-06-2007 06:54 PM
