Old 06-01-2019, 02:29 PM #1
ReconcileUs ReconcileUs is offline
ReconcileUs is on a distinguished road
Question 2004 17" GX470 rims on 99 SR5 w/ Tundra brakes? Did I mess up?
So, I wanted to get rid of my wheel spacers, so I saw a set of used 17" 2004 GX470 rims with 265/65/r17 tires.
I took my 16 inch stock off, took the wheel spacer off. I put on the Lexus rim described above and now it looks like there's an off set issue? These don't fit? Did I waste my money man...
ReconcileUs is offline   Reply With QuoteReply With Quote
Old 06-01-2019, 03:13 PM #2
sogoood's Avatar
sogoood sogoood is offline
sogoood will become famous soon enough
sogoood's Avatar
lol tighten them up. it'll center.
might want to use toyota lugs. not sure if those lugs are long enough for the thread???
example;
2002 Dorado Gold 4runner SR5 fully loaded/leather/JDM goodies
OME 882 fronts.LC 8 wrap rears/SCS Ray10 17x9" -38 Copper/Falken 285.70.17 P-rated/1.25" Spidertrax/TBU/JDM Hilux Surf Window Visors+LED Spoiler+Power Fold Mirrors/Hilux Surf Corners+Headlights D2S 5.0 x Panamera 2.0/Jaos Mud Flaps/Viper 5901/Blackvue dr750s 2ch/quarter tank of gas
Awaiting install of TrueNorthFab plate bumper and useless cool jdm parts
sogoood is offline   Reply With QuoteReply With Quote
Old 06-01-2019, 08:06 PM #3
example;
Is that the truck from your signature? Do you have spacers on, cause that's what your sig says? I'm wondering whether or not these clear the first gen Tundra brake upgrade without spacers.
I'll put the Toyota lugs back on, but these lugs worked fine with the oem 16's.
Old 06-01-2019, 08:16 PM #4
crazydubman's Avatar
crazydubman crazydubman is offline
crazydubman is on a distinguished road
You will need to use OEM lug nuts on the wheels. Those aftermarket conical seat lugs will not seat on the wheel correctly.
Like these.
Todd:
2007 Lexus GX470 - Grocery getter
1997 4runner limited - crawling/camping
http://www.toyota-4runner.org/3rd-ge...ner-build.html
crazydubman is offline   Reply With QuoteReply With Quote
Old 06-01-2019, 11:23 PM #5
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C is just really nice Ed_C is just really nice Ed_C is just really nice Ed_C is just really nice
Ed_C's Avatar
Real Name: Ed
Definitely the wrong lugs, those black conical lugs are for aftermarket wheels. Like @crazydubman said, you need the OEM style.
Those GX wheels should clear Tundra calipers without spacers, GX470s use larger front brake calipers that require a minimum 17" diameter wheel to clear.
Old 06-02-2019, 04:39 PM #6
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble will become famous soon enough Scramble will become famous soon enough
Scramble's Avatar
Real Name: Scramble
Talking
LOL, You need Toyota MAG lugs.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 06-03-2019, 10:40 AM #7
busmup808's Avatar
busmup808 busmup808 is offline
busmup808 will become famous soon enough
busmup808's Avatar
U need to run OEM lugs to run OEM rims. Those black lugs will not seat your rims correctly.
Busmup808 all day, all night!
busmup808 is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 11:35 PM #8
mna415 mna415 is offline
mna415 is on a distinguished road
Newbie here...interested in this setup
Hey guys - newbie here to the 3rd gen forum. I have a 1998 4runner SR5 and got ahold of 2003 GX470 wheels. Would love to partner them up. But sounds like I need to upgrade my brakes to Tundras and also get longer wheel nuts? For the wheel nuts, do any of you have the lock type?
Sorry, I know these questions are probably second nature to you all. Looking to up mine to all your standards!!
mna415 is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 11:52 PM #9
Skulking Skulking is offline
Skulking will become famous soon enough
Tundra brake calipers are larger than 4Runner calipers, and so can have problems clearing stock (15" or 16") 4Runner wheels if you upgrade to Tundra brakes. But if the GX470 wheels are 16", then you shouldn't have any issues clearing the standard 4Runner brakes.
As far as the lug nuts are concerned, take a look at the pictures posted above showing the OEM style lugs. As long as that is the style on your 4Runner, then you don't need to worry about the lug nuts. If yours don't look like the OEM lugs, then they probably won't fit the GX470 wheels.
Skulking is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 11:57 PM #10
FD7683 FD7683 is offline
FD7683 is on a distinguished road
Hey guys - newbie here to the 3rd gen forum. I have a 1998 4runner SR5 and got ahold of 2003 t wheels. Would love to partner them up. But sounds like I need to upgrade my brakes to Tundras and also get longer wheel nuts? For the wheel nuts, do any of you have the lock type?
The Tundra brake upgrade will make the front brakes bigger to avoid disc warping - this is not needed if you want to fit the Lexus wheels. Use OEM style lug nuts so they center correctly.
2000 Toyota 4Runner 4x4 Limited Sport Edition V6
Old 01-11-2021, 11:08 AM #11
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light
Real Name: Patrick
You do not need to upgrade front brakes to use those wheels
2000 Limited V6 Auto E-Locker
gx470 , rims , set , spacer , wheel
Tundra Brakes with Pro Comp 5001 Rims 96TrailSurfer 3rd gen T4Rs 0 10-23-2017 12:48 PM
Tundra Brakes.. And 16" 5-star rims Merninater 3rd gen T4Rs 4 09-06-2016 09:42 AM
2003 Tacoma Prerunner Rims - compatible w/Tundra brakes? Kung 3rd gen T4Rs 0 12-04-2012 11:03 AM
Will these stock '00 rims fit Tundra 231mm 13WL Brakes Ride_Red 3rd gen T4Rs 4 04-28-2012 06:58 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
