Old 06-04-2019, 10:05 AM #16
jeredcollins's Avatar
jeredcollins jeredcollins is offline
jeredcollins is on a distinguished road
Guess I bought a lemon or something... here is the list of items I've had to repair/replace under 125,000 miles. Originally purchased my 2000 4Runner with 98,000 miles two years ago.
Transmission (whole transmission breaks going 45mph one day)
CV axles (popping constantly)
inner and outer tie rods (can't keep the 4runner in alignment)
lower control arm bushings (popping and alignment issues)
radiator (driving on interstate and it just starts pouring out the bottom)
rack and pinion bushings (steering very loose)
Now my brakes are shuddering very bad when I brake hard. Guess I'll have to replace those next including the wheel bearings. Also my exhaust has a leak now. Eventually, the whole 4Runner will be new parts at this rate. I regret ever buying this POS.
jeredcollins is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 12:50 PM #17
Mr. Goodkat's Avatar
Mr. Goodkat Mr. Goodkat is offline
Mr. Goodkat is on a distinguished road
Lemon? possible. Or it was poorly maintained and driven in rough conditions. I guess we would need to know more about the area and conditions the vehicle was driven in and and I don't think off-road is the only type of driving that hard on a vehicle. Cities with tons of traffic and poorly maintained roads can be just as hard with 1-2 feet diameter potholes, gigantic seems in the concrete, tons of idle time in traffic with poor airflow, constantly flooring it to merge off of off-ramps or to the next light, hammering on the brakes once they reach said light or the next traffic jam.
Driving around Chicago comes to mind for me. I looked at one that needed tons of work and seemingly was only used "highway" or "no off-road, only Urban settings." That means nothing.
Does your area dump a lot of salt on the roads? What specifically broke in the transmission? The brakes are known to be weak but even then again, if it's driven properly or maintained properly considering the conditions they should still function fine. Pulsing brakes is usually driver error (I'm not blaming you).
2000 Limited natural white w/rear locker 204,xxx
Eibach Pro-Truck lift kit, Geolandar AT 275/70R16, debadged
2001 Camry LE V6 113,000 antique sage metallic, runs like new
Mr. Goodkat is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 01:53 PM #18
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
Those are some of the problems with a low mileage vehicle. ALL of the bushings in your front end have probably dried out & should be replaced. Coolant probably was never changed. Front disks can warp especially when using cheap pads & rotors & is common on A/T's. Happened to my limited. Never had an issue on my M/T because of downshifting. My limited had 217K when I bought it & it drove like a dream. But it was one owner dealer serviced it's whole life. We bought a low mile (2004 31k) Subaru 4 years ago, one owner & dealer serviced it whole life. Its in great shape but I've replaced all of the things you've mentioned above except the trans. 3rd gen trans are notoriously strong. Did you get service records when you bought it?
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 04:27 PM #19
Yes, a binder of receipts and invoices. Was the #1 reason I bought it... well that and the fact it only had 98,000 miles.
Old 06-05-2019, 01:45 PM #20
Scramble's Avatar
Real Name: Scramble
Scramble's Avatar
Real Name: Scramble
Well it sounds like you did the right thing. Good luck with her.
____________
Old 06-06-2019, 10:39 AM #21
ironman27 ironman27 is offline
ironman27 is on a distinguished road
My rig is owned by me for about a year and a half, and I got it at like 195k miles (it was the first good condition v6 M/T I came across so I snagged it!), but I have had to have the rack and pinion replaced - with lower control arms at the same time - but one of the lower control arms crapped out of me within a month or two after that so I finally got OEM, learned my lesson.
Been skeptical to really put a ton into it, even though I know they run forever, just a skeptic I guess. This has been an encouraging thread and now my rig is gonna get some extra loving!
Fun to hear everyones stories! Jealous of the low-mileage find for sure.
ironman27 is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 05:07 PM #22
JLStout JLStout is offline
JLStout is on a distinguished road
205,000 on my 1999. We've owned it since it was a year old. Just rebuilt the front end and installed new front struts and rear shocks. Haven't done the timing belt or water pump yet.
JLStout is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 06:51 PM #23
cleanrunner's Avatar
cleanrunner cleanrunner is offline
cleanrunner is on a distinguished road
i bought my 3rd gen in 2009 with 100k on it. it was a one owner dealer maintained prior to my purchase. i now have 200k on it and other than normal maintenance and random upgrades of my own, the only parts ive had to replace was a Alternator and a throttle position sensor and those were roughly 5 years ago. by far the best vehicle i have ever owned and im a sprts car nut thats had Supras prior.
Don't Text And Drive
cleanrunner is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 07:38 PM #24
efinkens1 efinkens1 is offline
efinkens1 is on a distinguished road
I had 265M on mine when someone piled in the back of it. Insurance gave my $5 grand.
efinkens1 is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 01:38 AM #25
bo4osu's Avatar
bo4osu bo4osu is offline
Real Name: Alex
bo4osu is on a distinguished road
bo4osu's Avatar
Real Name: Alex
3rd Gen
Me and my wife moved to our current house a little over a year ago. I noticed a 3rd gen 4runner in a back yard of a house a couple miles down the street. I finally saw a guy out in the yard a couple months bk and i stopped and talked to him. He hit a dear over a year ago and the fuel pump is out he thinks. I asked if he would sell it and said he wanted $900. I told him i would get bk to him. I didnt have $900 to spoend. I have a one year old and money is tight. So i offered the guy $400 the other day. He declined and said $750. Me and my wife agreed no higher than $650. I text him the next day and he said it had been sold. I was heartbroken. About a week later my wife woke me up and asked if i would help get some stuff out of the Highlander. So i got up and walked out side and behold there sat THE 98 4RUNNER in my driveway! She paid $650 for it. Besides the front end it is mint! 186k on it. Jut wanted to share. I finally got a 4Runner!!
bo4osu is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 09:39 AM #26
DocMike38 DocMike38 is offline
DocMike38 is on a distinguished road
Just got mine yesterday with 240K... not worried at all.... now the fun begins....
2002 4Runner SR5
DocMike38 is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 10:48 AM #27
Smog-guy707's Avatar
Smog-guy707 Smog-guy707 is offline
Smog-guy707 has a spectacular aura about Smog-guy707 has a spectacular aura about Smog-guy707 has a spectacular aura about
^^ pictures or it didn’t happen
Loading....
Smog-guy707 is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 10:49 AM #28
REX_T4R REX_T4R is offline
REX_T4R is on a distinguished road
I bought my 2000 5 speed 4x4 in January. Needed rear axle seals and bearings, valve cover gaskets, output shaft seal, brakes and a change of fluids. No regrets. It runs perfectly and with all the maintenance, it was still cheaper than buying new since I did most the work myself. I plan on changing the swaybar bushings, UBJ, LBJ and suspension when time permits. Such a fun rig.
REX_T4R is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 02:27 PM #29
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
I hope you realize how fortunate you are to have such a wife! Congrats on the 4runner, sounds like a good deal.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 02:40 PM #30
daYoda daYoda is offline
daYoda is on a distinguished road
I've owned mine for about a year. Has 221k mi on the clock. '99 4wd SR5.
Runs great. First thing I did was the Tundra break upgrade, then mounted an external tranny cooler (autoMagic tranny) to prevent the dreaded strawberry milkshake.
Gotta do some frame resto -> being in Ohio has obviously been rough on the frame. Got a small patch of the lower frame rail the exact size of the block of wood I used to jack it up doing an oil change. But, I also lucked out in that I was able to pick up a low miles '96 with a rotted frame for $800. SR5 w/ locking rear diff, manual trans and a strong motor.
I know people who's ODO's went out at 200k miles, 4 years ago, and they still routinely put 10k miles on it a year and have had 0 issues.
Truly bullet-proof, unless you don't wash the frame off and protect it from the elements.
daYoda is offline   Reply With QuoteReply With Quote
3rd , great , harder , original , t4r
Question on Longevity feddeytx 4th Gen T4Rs 20 07-19-2019 05:41 PM
Something unreal just struck me! Ron4RNevada 5th gen T4Rs 23 07-08-2015 01:23 PM
Toyota Longevity popashot Off Topic 0 04-09-2015 02:50 PM
Longevity Report. TacticalSR5 3rd gen T4Rs 10 04-28-2011 08:52 PM
Ebay car sellers. unreal! check this out! T4Fun Off Topic 1 08-12-2010 04:02 AM
