Old 06-03-2019, 01:03 PM #1
Maddog1337 Maddog1337 is offline
Maddog1337 is on a distinguished road
Is This Rust Worth Purchasing?
Hello,
I'm in the market for a 3rd gen T4R. I'm located in Chicago and have had a very difficult time sourcing one. The demand on these things is crazy - I've contacted sellers that have posted an ad within the last 24 hours and was told I'm behind a dozen people in line. I've also nearly purchased two, but later found the odometer was rolled back.
Anyway, here's one I'm currently looking at, a '00 with 178K. Is this a complete skip? Keep in mind I'm thinking this is as good as it gets for the Midwest.
Seems to be concentrated towards the rear, but a lot of it looks deeper than surface rust... I'm not sure what an angle grinder and Fluid Film could do, or if it's too far gone.
I could probably get this around ~$2K. Thoughts?
[IMG]
[/IMG]
Maddog1337 is offline   Reply With QuoteReply With Quote
Old 06-03-2019, 01:15 PM #2
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
I don't see anything that is immediately alarming but it is certainly beyond the point of surface rust from what I can tell. It also looks like there was an attempt to paint or even sandblast the rust in the first picture (looks silver).
The lower rear control arm mount is generally the first spot to completely rot out on these so check those out carefully.
Keep in mind fluid film is really great when starting with clean metal. It does not convert or treat rust. It repels the contaminants that cause the rust to form from the beginning. It wont be much help at this point other than slowing the spread of the existing rust.
For 2k it might be worth getting a little bit of use out of it if everything else checks out but that is your call. Good luck! I grew up and live in the NE so I am sympathetic to the rust issues (also lived in MI).
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
raKnizek is offline   Reply With QuoteReply With Quote
Old 06-03-2019, 01:16 PM #3
Treyall Treyall is offline
Treyall is on a distinguished road
I would stay away. That’s more than surface rust. If something breaks at freeway speed. It’s gonna be ugly!
Shop in a state that doesn’t snow. Our California cars have NO rust!!!
But the cost of Toyota’s out here are a premium
Treyall is offline   Reply With QuoteReply With Quote
Old 06-03-2019, 04:18 PM #4
pokeyman pokeyman is offline
pokeyman is on a distinguished road
too much rust for me
pokeyman is offline   Reply With QuoteReply With Quote
Old 06-03-2019, 04:59 PM #5
MStudt's Avatar
MStudt MStudt is online now
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Has less rust than mine.
Mike
MStudt is online now   Reply With QuoteReply With Quote
Old 06-03-2019, 10:54 PM #6
Js'00imited4runner's Avatar
Js'00imited4runner Js'00imited4runner is offline
Js'00imited4runner will become famous soon enough
Where did you end up finding this? Craigslist? Also whats your budget?
I can help you out if you end up finding something I'm somewhat local.
It took me almost a year in a half to find mine and the rust wasn't to bad..
Keep looking you'll find the right one. If not you can always look in the southern states. I've started looking down in tennessee for one. Good luck!
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
Js'00imited4runner is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 02:10 AM #7
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
Only pay attention to advise from rust belt owners. LOL For 2 grand it doesn't look bad but I bet the frame is rotting from the inside. You'll get many years out of her. Nothing is gonna break off while driving. You gotta sand & paint that axle housing before it starts leaking. Or replace it with an e-locked one. LOL Good luck!
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 08:31 AM #8
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Doesn't look too bad, especially for $2K. Check around the rear lower control arm mounts real well.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 08:03 PM #9
Hey man, thanks for the offer, and words of encouragement. I am started to get discouraged in my search. I check Craigslist and Facebook Marketplace daily. Autotrader, not so much, prices are too inflated. If you have any ideas for sourcing one I'm all ears.
I guess I can't expect perfection, but was hoping for something around $5K.... That had some semblance of service history, a verifiable odometer, didn't have stolen wheels on it, a recent timing belt change, and... big ask...limited rust. Perhaps this doesn't exist at my budget but I don't need anything fancy on it. It would just be a Home Depot errand runner and most importantly, would spare my '17 Mustang from its third winter.
Old 06-05-2019, 06:55 AM #10
BostonJon BostonJon is offline
BostonJon will become famous soon enough
In this case, I’d check those rear control arm mounts and if they check out, go for it. Will be a good car for what you need.
BostonJon is offline   Reply With QuoteReply With Quote
178k , concentrated , lot , rear , rust
Worth fixing? (Rust) Neil_R 3rd gen T4Rs 16 01-30-2023 03:32 PM
Undercoating/Rust inhibitor worth it? Signess General Discussions 10 02-18-2018 04:51 PM
Killer deal on T4R with rust: worth it? hawkmanjr 3rd gen T4Rs 14 03-10-2016 07:26 PM
Rust worth worrying about? Jc12 3rd gen T4Rs 7 07-17-2014 04:03 PM
Shock boots worth purchasing? cbielat 5th gen T4Rs 11 01-30-2012 11:13 PM
