06-04-2019, 03:03 PM
Location: Southern California (please don't hold it against me)
Real Name: michael
Real Name: michael
Wrecking yard
If you were going to a wrecking yard aside from the specific item your looking for what might you pull to keep onhand. Also include other model from Toyota other than 4Runner that might offer a treasure.
06-04-2019, 03:07 PM
Evap canister, extra timing cover (in case I ever cut mine for TRD supercharger), little clips and screws that would be annoying to order otherwise, shifter knobs, brake pedals (stuff that wears out over time, good to have spares in good shape)
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
06-04-2019, 03:53 PM
If you have an 01 or 02, might be worthwhile to proactively source a brake booster assembly and throttle body, since both are ridiculously expensive new.
2002 Limited 4Runner
2001 Jeep Cherokee
06-05-2019, 04:12 PM
Real Name: Jerod
Real Name: Jerod
Center console lid if in good shape. Cheap ones are hard to find.
06-05-2019, 04:25 PM
^yeah for sure, still looking for one.
OE axles and driveshafts, newer vac lines
– 96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
06-05-2019, 04:58 PM
96-00 blue interior pieces. Literally take the whole interior. I have resorted to junkyards in asia just to get some parts.
06-05-2019, 09:31 PM
Real Name: michael
Real Name: michael
Keep the good ideas coming I have 2 2001 one for me one for the wife and I working on a 97 for my sister inlaw.
06-06-2019, 07:55 AM
Spare ICM, spare throttle body assembly complete with the IAC and TPS.
Spare ABS module.
Spare multi-function switch. AKA the thing with the turn signal and windshield stalks on them.
Spare complete instrument cluster.
If you are one of those guys that almost run your vehicle out of gas....get a tank sending unit and spend the money on a quality fuel pump to put in it.
Spare ignition coils
This is a start.
06-06-2019, 10:13 AM
Real Name: Daniel
Real Name: Daniel
I'd get the relatively expensive (new OEM) but small things that can completely kill you dead in the water or make it dangerous for you to drive. Things you can keep in the glove box or where ever without hurting for space. Things that the dealers don't keep in stock and the parts houses might not either, so you'll be waiting on something shipped, possibly after a tow home.
Get:
-All the 'special' relays from the fuse boxes
-Brake Booster Check Valve
-Mass Airflow Sensor (MAF)
-Throttle Position Sensor (TPS)
-O2 sensors (possibly, if you can prove they're good)
-Ignition coils
A bit harder to fix on the fly, but:
-Fuel Pressure Regulator (FPR)
Cosmetics:
-Stock up on little clips, etc
-bulbs (brake light, reverse, dome light, etc) If you can score bulbs from someone whose done an LED upgrade, all the better
-plastic seat 'feet' covers
-If it's a Limited with power seats, get the driver's side plastic seat cover. There's a clip here that breaks off so the whole cover pops off, adjuster lever with it
Someone mentioned vac lines and that's a good idea. Nothing is a bigger pain in the ass than working on the truck and putting it all back together only to have a 20 year old perfectly bent/molded vac line just snap in half on you. Then you have to make another parts house run (possible in another vehicle) just to get the new line.
'Treasure' from other Toyotas: I know that the MAF from a 2003 Rav4 is the exact same one as the 1999+ 4runner (I think the MAF style changed in '98?). I think I heard that the Avalon fits also.
06-06-2019, 11:54 AM
Real Name: Justin
Real Name: Justin
I find it cheaper to just buy a entire wreck and strip it down and scrap everything else for $500 u can typically get some amazing stuff
06-06-2019, 03:30 PM
I kept the 96 when it got T-Boned for that reason. Everything crosses over to the two 97’s I ended up with
06-06-2019, 04:48 PM
Door light switches.
'00 4Runner SR5 (242,100 miles)
3" Toytec/Bilstein lift, 285/75r16 BFG KO2s
'16 Ford Fiesta ST, pushing more boost than I should be
06-06-2019, 05:06 PM
For the 97 get the 99-02 center console with cup holders (if they have one in the right interior color).
Be sure to get all the required parts according to Timmy the Toolman Center Console Sic Mod - YouTube
- center console
- hand brake (e-brake)
- tub that e-brake attaches bolts into
- bracket that mounts the center console
06-06-2019, 05:17 PM
Hood scoop inserts, whether its off a 4runner or Rav-4 lol
Check out my website https://69thstreetgarage.com/
06-06-2019, 06:42 PM
I have a blue leather interior did'nt know they where hard to find?
