01-08-2018, 08:21 PM
Squishmitten's 02 Sport Edition Build
I've been lurking here for a little while and figured I would share some of my progress. I don't get much opportunity to go out and hit the trails due to work full time and school so this isn't going to be as awesome as some of the build threads on here.
I picked this bad boy up late August of 2017. At the time it had the Baja Utility rack and some PIAA halogens on it. Other than that it was stock. There will definitely be more to come.
02 Sport Edition w/ approx 180xxx on the clock
As of today, here’s what’s on it:
Armor/Recovery:
RPMFab plate front bumper
XRC 9500 winch w/synthetic rope
Factor55 1.0" hawse fairlead
Factor55 Flatlink w/rope guard
4xInnovations DIY sliders
Savage Offroad front skids
4xInnovations rear bumper
Tire carrier swing out
Jerry can mount (single)
Hi Lift mount
Fold out table
Lighting:
Baja Designs Squadron Pros (Driving Combo) (w/security hardware)
Opt7 LED Headlight bulbs
Suspension:
Front
Bilstein 6112 (removed)
King OEM ext travel w/650 lb springs
Mstudt front sway bar extended links (Thank you for an awesome product!)
Sonoran Steel diff drop
SPC UCA
Rear
OME890 (removed)
OME861
Bilstein 5100
Mstudt rear sway bar extended links
eimkeith panhard brackets (Super easy install, thank you for an awesome product!)
Wheels/Tires:
16x8 SCS Ray 10 (matte gray)
285/75/16 BFG K02’s
SCS ET lug nuts
Exterior:
SRQ Fabrications flush mount grill
Weathertech Bug deflector
JDM Hilux clear corners (Thank you Rhyi)
Baja Racks Utility rack
23Zero Litchfield RTT
Engine:
HKS Super Hybrid Filters (still a JDM fanboy)
Sonoran Steel windshield fluid reservoir relocation
Odyssey Extreme Battery
Big 3
Transmission:
B&M 70268 SuperCooler Automatic Transmission Cooler
AndyMod 2.0 w/OEM Sequoia TRAC Off switch
Interior:
LED bulb conversion for map/dome lights
Kenwood Deck
Garmin
Scanguage II
Cobra CB (installed in ashtray)
The day I got her
And a more current shot
01-08-2018, 08:25 PM
I already had some of the lift components from an older 97 that I had previously. That one was too rusted to do anything with. I got rid of it and used the funds to pick up some wheels and tires, as well as the rest of the lift components.
Lift:
Bilstein 6112
OME 890's/Bilstein 5100's
Extended sway bar links
Panhard brackets
Sonoran Steel diff drop and windshield fluid reservoir relocation
Wheels:
16x8 SCS Ray10 (matte gray)
285/75/16 BFG K02's
SCS ET lug nuts
01-08-2018, 08:31 PM
Shortly after the lift was installed, my SRQ grill and my 4x Innovations sliders arrived.
The grill looks amazing, although it was a bit of a hassle to install. We had to trim the mounting tabs on the grill itself for them to fit correctly. One of the corners to this day won't mount all the way, but it's not going anywhere so I'm not worried.
My buddy Ryan is much better at welding than I am, so he helped me get the sliders welded up. All in all happy with the end result.
01-08-2018, 08:38 PM
Took a trip out to the desert to plink some steel with my buddy and his Yukon.
Scratched up my paint a little bit and broke my antenna.
01-08-2018, 08:48 PM
I ordered a bumper on Black Friday from the local guys at RPMFab. Super friendly dudes, easy to work with, and the bumper fitment was amazing! It was a really easy install (with the help of my roommate). I would recommend. I'll need to pull it back off when I get a winch, but that will be a few months down the road.
I also ordered some amber Baja Designs Squadron Pros to mount in the bumper, but there was a mix up with my order and they sent the clear lenses. They were super easy to work with and fixed it right away. These things are bright! The photo below from in the truck is with just the pods on. Don't mind the filthy armrests on the lawn chair.
01-10-2018, 10:03 AM
How do you like those PIAA lights? Are they the super amber/yellow or whatever? I saw a set or two online for like $150 basically new in box. Was considering those or some LED ditch lights. Do you have pics of those lights in the nighttime?
2001 SR5 Sport 3.4L 4x4 199K
01-10-2018, 12:15 PM
Real Name: Blake
Real Name: Blake
I hope your powdercoat holds up better than mine. After 6 months I'm getting some pretty bad cracking on and around the D-rings. And now that I moved back up north, it's starting to rust underneath.
2006 Tundra DC 4x4 - Daily Driver
2002 Ford Focus ZTS - Toy (Vortech Supercharger, Ksport Coilovers, Team Dynamics Wheels etc etc etc)
01-10-2018, 12:31 PM
Real Name: Christian
4Runner is looking great! Hard to beat a clean black truck.
01-10-2018, 01:40 PM
To be honest I was not a big fan of them. They were very yellow, so they cut through dust well, but my issue with them was how shaky they were on the trails. I think that if they were mounted to a steel bumper, maybe it wouldn't have been so bad, but with them mounted to a stock/plastic bumper, they had very visible vibrations in the beams, thought I was gonna have a seizure half the time they were on.
I'm hoping it does, but I keep some bed liner in my truck anyways from when we spayed my sliders. Any plans for a visit back to AZ?
Thanks man! It's tough to keep clean in AZ but it's worth it
Instagram: korean__kevin (two underscores)
Squishmiten's 02 Sport Edition Build
01-10-2018, 02:52 PM
Real Name: Blake
Real Name: Blake
Yessir! I will be back March 2-12. No truck though, I'm flying in.
01-10-2018, 04:09 PM
Such a nice looking 4Runner!! I'm in Gilbert, we should meet up sometime.
1998 Limited 4x4 | SS 7.2 | Addicted off-road front bumper/4xInnovations rear | 285 75 16 BFG K02 | SCS Ray10
01-10-2018, 04:21 PM
I think I've seen you driving down Elliot a couple times on my way to work. You have a NICE truck man.
RPMFab is having a "Grand Opening" at their shop this Saturday, I'll be there, you should come out
01-10-2018, 06:40 PM
thanks!
I thought that was you. haha
oh cool! i will try and make it. thanks!
01-17-2018, 07:46 PM
Went out to RPMFab for their grand re opening at their new shop last weekend. Had a great time, lots of 4Runners and a lot of Jeeps.
They raised close to $8,000 for the AZ Neurological Society through their raffle, it was a good time. Plus I got to see a 23Zero RTT in person, and I'm definitely going to be picking one of those up ASAP. AZ 4x4 Recovery came out as well, that dude is really cool.
01-17-2018, 07:54 PM
sick Rig
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
