Originally Posted by JBorras
I found a D70 local to me for only like 400. Is there something specific I should be looking for when I go to check it out?
Before hand you could try to get the BOM number from the seller and look it up on this website
Dana Expert It will tell you everything about the axle. As long as it has 35 spline axles and is in good shape you should be golden. If you're looking for a certain width ask about that too. They came in a lot of different widths for different vehicle applications. You could always just pull an axle shaft to check the splines when you get there too.
2000 4Runner:Kings, 37s, lockers
2018 TRD OR:stock and staying that way
