Made a few phonecalls, heres what Yukon says:
The 29 ¼” measurement is measured on a diagonal from the outside of the flange, to the tip of the shaft, not parallel to the shaft as you show.
The shaft should work fine in that application, the factory axle protrudes thru the spline slightly. This will still have full spline engagement.
For reference here are some part numbers:
#YA T35350 is Yukons 1541H shaft, 29.25" long
#YAW T8-30-29.0 is Yukons 4340 Chromoly shaft, 29.125" long
#AXT34060 is Nitro's 4140 Chromoly shaft, 32.125" long (cut to length), made in USA.
Im going to gove the Nitro shaft a try. I'll post some pics of the Yukons, Nitro's, and Stock.
