Old 06-12-2019, 11:00 PM #46
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Originally Posted by mforce View Post
I think it’s linked to security. It’s a rss-210 Toyota key fob that we use. I’m hunting everywhere for a test button, the panic button on remote works! Lol we tried it then climbed in to start it after we turned it off. No click no sound!
It may be linked to security. The bypass trick I mentioned in my last post should at least isolate it to that. If you bypass the starter relay with a wire it should try to turn over. This will confirm that something upstream of the starter wire is the issue. I don't have a wiring diagram of the factory security system unfortunately, nor does the rig I drive have one. Just the simple remote lock/unlock fob (with rear window roll down and red panic button).
weekendclimber is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 05:54 AM #47
mforce mforce is offline
mforce is on a distinguished road
That is all my key fob is "unlock,lock, rear window roll down, then red panic button on the back of the fob". My key fob on the back is RSS-210. So I am not sure its a security type system. I did the wire from starter to hot on battery terminal before and it did not work. Do I need to remove the wire on the starter that has a nut on it then attach it or can I just leave the starter wired?
Sold; 98 4Runner Limited, OME 883's w/Bilstein 5100, Downey 3" rear springs w/Doetch Tech & Daystar 1.25" spacer, Cornfed 1" diff drop, Tundra 231mm brake upgrade, Tundra wheels/tires, Tinted windows, more goodies being added. Not quite to 200,000 miles club yet!
mforce is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 10:31 AM #48
Went back through every fuse AGAIN... blown 7.5 amp fuse under dash. Swapped the fuse, bumped the key, she fired right up. Praise God! Thank you for all the advise. Now to make sure all system check out! Will give final update after I pull it out of garage.
Old 06-13-2019, 10:38 AM #49
Real Name: Scott
Real Name: Scott
Nice! Figured it had to be something simple like that! Cheers!
Old 06-13-2019, 11:31 AM #50
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
What fuse did it end up being?
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 11:44 AM #51
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
I would bet its the 7.5 ignition, mine blew when trying to deal with the aftermarket alarm in my 4R, ended up leaving it for now
glad you got this figured out! i know how frustrating it is to have a swap not start
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 06:23 PM #52
Bingo! 7.5
engine , pulled , starter , thought , work
Has anyone pulled V6 engine from 4th Gen 4Runner? ysrsquid Problems & Warranty Issues 123 07-07-2020 01:37 PM
Engine bog, then stalling at stop signs, now engine won't start Smiley52 3rd gen T4Rs 32 05-05-2017 05:15 PM
Fluttering engine start when engine is cool. trail_runner 3rd gen T4Rs 1 07-17-2013 09:24 AM
4runner' 99 won't start for 1st,2nd,3rd but eventually will start the engine tm1579 3rd gen T4Rs 5 04-16-2013 01:14 PM
engine start up 4Evr4RunN3R 3rd gen T4Rs 3 04-16-2008 12:32 PM
