Old 06-10-2019, 12:25 PM #1
mforce mforce is offline
mforce is on a distinguished road
Question Pulled engine won't start
I have a 2000 3rd gen and we pulled the engine to install the timing belt kit with water pump, torque convert seal, new valve cover gaskets, oil pan gasket, radiator and hoses. We reinstalled the engine and hooked it all back up and now we are getting nothing. Battery shows good from the charger. Light work, windshield wipers work, horn blow, radio comes on, but no starter turns over at all. We have traced down the grounds again. Checked and rechecked them. It has the factory alarm no aftermarket on it. I am lost as I thought it was ready to go. I followed the timing install to the T and it lined up perfectly with the Toyota kit. We can turn the key and hear what sounds like fuel pump but no starter to engage. It was running great before we pulled the motor. I have looked at the forums, googled till my fingers hurt and I feel silly. I have built motors before and thought it was starter but it looked newer.
Sold; 98 4Runner Limited, OME 883's w/Bilstein 5100, Downey 3" rear springs w/Doetch Tech & Daystar 1.25" spacer, Cornfed 1" diff drop, Tundra 231mm brake upgrade, Tundra wheels/tires, Tinted windows, more goodies being added. Not quite to 200,000 miles club yet!
mforce is offline   Reply With QuoteReply With Quote
Old 06-10-2019, 01:02 PM #2
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Double check the starter relay first. Do you here a "click" when you turn the key to start it? If you've got a power probe, you can give it power to the connector on the starter to see if you get a click (red circle). You could even turn the ignition to the "On" position, and power that plug and see if it turns over and starts up.
Also, could be the park/neutral position switch (red arrow)
Here's a diagram to get you started:
weekendclimber is offline   Reply With QuoteReply With Quote
Old 06-10-2019, 01:05 PM #3
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
this may not be the right next step but when mine didnt start i tried jumping the starter solenoid to see make sure the starter would function. Both were working and it ended up being the stupid aftermarket alarm but thats where i started.
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 06-10-2019, 01:23 PM #4
How do you jump the starter solenoid?
Old 06-10-2019, 01:33 PM #5
Real Name: Scott
Real Name: Scott
Get a jumper cable and attach it to the bolt that has the starter wire coming from the battery and then attach the other end to the positive post on the battery. You'll still need to the try and turn it over with the key, so if your starter relay is bad in the engine bay fuse panel this won't help.
If it then starts with this method, you have a bad starter wire coming from the battery to the starter.
Old 06-10-2019, 02:13 PM #6
We have power from the test light we used at the starter. We noticed that when we turn the key the dash clock goes out. Not sure if that’s normal? If we hook the site and it starts will it continue to spin the starter?
Old 06-10-2019, 02:20 PM #7
Real Name: Scott
Real Name: Scott
Sounds to me like a bad starter wire.
It won't. You'll still have to turn the key over in order to engage the starter relay, which then engages the starter solenoid on the starter itself. What you are essentially doing is bypassing the starter wire that goes from the battery to the starter to test if it's bad. Basically bypassing the Blue-Black (B-L) wire in the diagram I posted (lower left-hand corner of image).
Old 06-10-2019, 03:18 PM #8
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
1st thing i would do is go back and make sure all the wiring connectors r fully seated into their assigned locations... especially at the ECU. While ur doing said make sure all ur grounds r good, get ur hands on a volt meter if u dont have 1.
clearock is offline   Reply With QuoteReply With Quote
Old 06-10-2019, 03:42 PM #9
Real Name: Scott
Real Name: Scott
Do you have a Factory Service Manual? There's a great diagnostic check list you can go down that should get your problem solved. It's most certainly an issue with the starter. The dimming lights when trying to crank screams starter wire to me. PM me if you need a copy of the FSM.
Old 06-10-2019, 05:32 PM #10
Ran the wire from starter to battery and still nothing. Checked the ECU wires again. Put in a new battery and still nothing. I’m not getting even a click click click on starter.
Old 06-10-2019, 06:14 PM #11
Real Name: Scott
Real Name: Scott
If you go into the fuse panel in the engine bay, locate the starter relay (purple relay in my picture) and try connecting a wire from pin 5 and 3. This should cause the solenoid to click and then turn the starter over. This is effectively bypassing the ignition switches and all the stuff upstream in my previous wiring diagram. If you have the key turned to the "On" position, and your starter is good, it should fire up. This would indicate a bad starter relay if it indeed turns over/starts up.
Old 06-10-2019, 06:22 PM #12
Real Name: Scott
Real Name: Scott
Just so you or anyone else understands what we're doing (not that you don't), it sounds like we've tested the starter wire by using jumper cables to bypass that wire (circled in red). It's something that caused me and several others issues. Looks like this is not your culprit:
Now, we're going to test if the starter relay is bad by circumventing it with a jumper wire.
Old 06-11-2019, 06:20 AM #13
We put a loop wire into the 5 slot and into the 3 slot to create a connection between them and tried the key still nothing... not even a click. Could the door lock unlock feature be stopping it? I still have the hood off as well.
Old 06-11-2019, 10:46 AM #14
Real Name: Scott
Real Name: Scott
This is starting to sound like potentially a bad starter or bad ground. At this point I would remove the starter and bench test it to make sure everything is working. Do you have a powerprobe? If not, you'll need some wires and jumper cables. It might be worth the time to pull your battery out to use it on the bench to the test with as well.
You're going to test whether the solenoid plunger engages when providing power to the plug and then whether the starter turns when providing power to the starter motor.
Here's a link with some more troubleshooting: Toyota/Chrysler/Mitsubishi - Nippon Denso Starter Solenoid Repair
Old 06-11-2019, 10:48 AM #15
Real Name: Scott
Real Name: Scott
Also, that wiring diagram for the starting and ignition is for a 2002, so it might not be pin 3 and 5. When you use the jumper wire you will hear the click of the solenoid and the starter turning the motor over if everything is in order.
@TheDurk
engine , pulled , starter , thought , work
Has anyone pulled V6 engine from 4th Gen 4Runner? ysrsquid Problems & Warranty Issues 123 07-07-2020 01:37 PM
Engine bog, then stalling at stop signs, now engine won't start Smiley52 3rd gen T4Rs 32 05-05-2017 05:15 PM
Fluttering engine start when engine is cool. trail_runner 3rd gen T4Rs 1 07-17-2013 09:24 AM
4runner' 99 won't start for 1st,2nd,3rd but eventually will start the engine tm1579 3rd gen T4Rs 5 04-16-2013 01:14 PM
engine start up 4Evr4RunN3R 3rd gen T4Rs 3 04-16-2008 12:32 PM
