Originally Posted by phattyduck
I'm assuming you also added the OEM fog light relay and fuse in the engine bay fuse box? If you remove the relay, does everything return to normal?
Does your truck have daytime running lights? (assuming not, unless you are in Canada)
Are you running a special harness for the HID retrofit? Assuming you have bi-xenon projectors with a shield that moves for high beams?
Does your high beam indicator work normally? (full brightness when on, fully off when off)
There's a good chance that the combination switch is just fine and it has something to do with the way the wiring is done on your HID retrofit. (not necessary a problem, just an issue with how the stock wiring and the HID wiring interact). It should be fixable with a diode or load resistor or both...
Charlie, thanks for taking the time to reply.
Yes, I added in a relay for the fog lights, but no it was not OEM. I'll try to pull the relay tonight and see if the issue still exists.
No, I do not have DRLs.
Yes, I am using MotoControl Bixenon: H4/9003 wiring harness, and yes I am running bi-xenon projectors, D2S 5.0s from Morimoto.
High beam indicator no longer works, but I believe it was working fine before I put the fog lights and stalk in.
I'm going to to try to pull the fog light fuse as you mentioned earlier and see if that resolves the issue. If not I'll put in the old stalk with the fuse removed and see if it all works and move on from there.
Really appreciate your input.
