Old 06-11-2019, 10:55 AM #1
mc813's Avatar
mc813 mc813 is offline
mc813 is on a distinguished road
mc813's Avatar
No sound from speakers after head unit/speaker install?
EDIT: This is on a 2000 4Runner
Ok, at a loss for what's wrong here. I'll start off by saying I'm a noob and don't have a multimeter (may be buying one later today though).
I ordered a new head unit, component speakers for front and rear doors, and tweeters from Crutchfield. I spent ~6 hours yesterday wrangling with installing all the items, only to find that once I was done, I have no sound coming from any speakers. I tested partway through (after new head unit and front passenger speaker and tweeter were installed) and everything worked as expected. Note: Since I've seen it asked inother audio problem threads, I did bypass the factory amp using the metra harnesses from Crutchfield.
I then proceeded to install the speakers in the remaining 3 doors, and after reconnecting the negative terminal, I tried starting the car and it wouldn't start...it would crank, but then die when releasing the key. I tried again and this time gave it a little gas, and the car came back to life with a pop (fuse?). I noticed this morning I have no turn signals, so I'm assuming at the least that fuse is blown and could've been the source of the pop when revving it to start (currently at work and didn't have pliers to pull the fuse in the parking lot this morning).
Has anyone ever had anything like this happen or can anyone provide any sort of guidance as to where to start? A multimeter from Amazon won't be here until tomorrow if I order, and I'm about to give up and take it to people who know what they're doing so I don't screw things up further
2019 TRD OR | Front Runner rack | Shrockworks sliders
Gone
2015 Trail
2000 SR5
mc813 is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 11:33 AM #2
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Sounds like you've got the power connected to the ground or something. Confirm when you can that a fuse has popped. Popping fuses indicates a short somewhere.
If it's the ACC fuse in the engine bay or the dome fuse in the drivers side kick panel, then you're radio power is somehow being grounded and popping the fuse:
weekendclimber is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 01:26 PM #3
mc813's Avatar
mc813's Avatar
Just checked now at lunch and all fuses seem to be fine. The turn signals are now working also, because I plugged the center trim/hazards plug back in. I didn't realize that needed to be connected for the turn signals to work. I'd left off all trim pieces to make it easier for someone to access/diagnose
Gone
2015 Trail
2000 SR5
Old 06-11-2019, 01:31 PM #4
Real Name: Scott
Real Name: Scott
Radio working and all?
Old 06-11-2019, 01:36 PM #5
mc813's Avatar
mc813's Avatar
For now I actually just unplugged the head unit altogether. I reached out to a friend at work who's an audiophile and we're going to meet up tomorrow after work to take a look and hopefully diagnose the problem
Gone
2015 Trail
2000 SR5
Old 06-12-2019, 08:56 AM #6
mc813's Avatar
mc813's Avatar
To update/close out this thread: the issue is fixed. After work yesterday I went through (with the help of Crutchfield) and disconnected all speakers and tested them one by one. Turns out the orientation of one of the rear speakers had the positive/negative terminal coming into contact with the foil backing of some sound deadening material I'd applied to the door, so after changing it's position, everything works as intended!
Gone
2015 Trail
2000 SR5
Old 06-12-2019, 10:46 AM #7
Real Name: Scott
Real Name: Scott
Awesome! Rock some Van Halen in celebration
Old 06-12-2019, 01:54 PM #8
zaplipzach zaplipzach is offline
zaplipzach is on a distinguished road
When I installed an aftermarket head-unit, both rear speakers stopped working, but the fronts still play. I was hoping to find a similar solution, but I can't see any way for the contacts to have broken as I didn't replace any speakers.
zaplipzach is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 09:08 PM #9
GefesT GefesT is offline
Real Name: Nick
GefesT is on a distinguished road
Real Name: Nick
Thank you for your information about installing speakers in car doors. It was useful when I did the same operation, I replaced my old speakers for new one's Pioneer TS A6970F model.
My old speakers had a very bad sound quality and i decided to change them. I'm not really good at sound systems, so I decided to find good source with recommendations about 6x9 speakers to decide which speakers I can buy. In the end, I found this top Best 6x9 Speakers | Audio Direct. At this website, you can find detailed info about sound systems, and recommendations with choosing good speakers/microphone/headset/etc. Maybe I will help someone with this info. Best wishes.
GefesT is offline   Reply With QuoteReply With Quote
fuse , head , sound , speakers , start
Center speaker/surround sound with aftermarket head unit? Fanman47 4th Gen T4Rs 14 02-28-2014 10:12 PM
Rear speakers inop. after head unit install cmitch 5th gen T4Rs 2 10-18-2013 09:11 PM
Question on my head unit and speakers walrus Engines / Suspension / Wheels / Tires / Audio / Accessories 3 07-23-2009 05:02 PM
PA speaker/head unit imryannn 3rd gen T4Rs 2 03-14-2009 03:56 PM
Which Speakers to get with SCION Head Unit kimboy Engines / Suspension / Wheels / Tires / Audio / Accessories 3 07-01-2004 07:47 AM
