Old 06-11-2019, 05:53 PM #1
Ser1clymb's Avatar
Ser1clymb Ser1clymb is offline
Ser1clymb is on a distinguished road
Ser1clymb's Avatar
Combining King or Icon Coils with Bilstein 5100?
I have been looking for a little bit at upgrading my front suspension and am torn between the Tundra coil/5100, the toytec coilover, and a few others.
I couldn't find any information, and was curious if anyone has used the Tundra 5100 with a King or Icon coil for the front and what their experience was with it. Setup, maintenance, handling, etc.
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
Ser1clymb is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 07:57 PM #2
turbo8's Avatar
turbo8 turbo8 is offline
turbo8 will become famous soon enough
turbo8's Avatar
Get matching king or icon rear shocks. Problem solved
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
turbo8 is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 12:11 AM #3
Ser1clymb's Avatar
Ser1clymb's Avatar
I already have extended rear Bilstein and ome 890 in the rear so I am just looking for options for the front
Old 06-12-2019, 12:30 AM #4
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner will become famous soon enough Dezert4Runner will become famous soon enough
Real Name: Evan
5100’s are a 2” shock body and most Icon and King shocks are a 2.5” body, so they use different sized coils. A 2” shock body uses a 2.5” coil, and a 2.5” shock body uses a 3” coil. The Icon and King coils that do fit the smaller 2” shock bodies are different than the ones that for Bilstein 5100’s because they are flat on both ends. The OEM Toyota coils, OME, Toytec Eibach etc have a pigtail on one end, so they are the only type that are compatible with 5100’s.
2000 Black Sport 4WD 5spd-2.5" SAW • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 285/75/17 BFG KO2 on 5th gen SR5 wheels / Spidertrax • 231mm TBU / Wheelers SS lines • MStudt extended quick disco links • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 fab gas tank skid • @Assburns custom tube front bumper
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 01:38 PM #5
Ser1clymb's Avatar
Ser1clymb's Avatar
Why do the coils have to have the pigtail to be compatible with the 5100? Is it the top hat of the shock or for the clip towards the bottom of the shock body? It doesn't seem like it would matter.
Old 06-12-2019, 01:53 PM #6
Real Name: Evan
Real Name: Evan
The bottom spring perch on an OEM shock and on 5100’s are set up for the pigtail, and upper top hat is set up for the flat end of that same coil. Aftermarket coilovers like Icon and King have lower and upper spring perches set up for a flat ended coil on both sides.
Old 06-13-2019, 02:12 PM #7
Ser1clymb's Avatar
Ser1clymb's Avatar
Thanks that's helpful. Now I'm considering Eibach coils with Tundra 5100 shocks for the front. Any experience with this setup?
Old 06-14-2019, 11:16 AM #8
fourfive's Avatar
fourfive fourfive is offline
fourfive has a spectacular aura about fourfive has a spectacular aura about
fourfive's Avatar
Have you considered using the tundra trd coils with the tundra 5100 shocks?
Sonoran Steel has good info on it. I don't have personal experience with that set up but from what I've read that pairing seems to be well liked.
http://www.sonoransteel.com/index.ph...&products_id=1
I do have experience with eibach/5100. Ride quality is very similar to toytec eibach/boss which I've been happy with. I went with toytec boss for ease of adjustability & fine tuning ride height. My experience with the few different set ups I've driven is that as long as your front ride height doesn't exceed 22.5" center hub to fender, the commonly offered coilover pairings for 3rd gens will handle similarly. I haven't tried the higher end stuff like king, icon, etc.
•Black 2002 SR5 4x4 3.4L V6
Suspension: Front: Toytec Boss coilovers/eibach 600#, SPC UCA, durobumps Rear: Bilstein/Superflex, SS adjustable panhard, durobumps Body Lift: 2" 4crawler Tires: 315/75/16 General Grabber AT2 Wheels: SCS F5 Matte black 16x8 3.5bs Armor: Custom bolt on rock sliders (no frame drilling)
•Black 2018 TRD Pro (wife’s)
Armor: Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 06-14-2019, 11:40 AM #9
Ser1clymb's Avatar
Ser1clymb's Avatar
1996-2002 - Classic System 1.2 [96-02_complete] - $1,575.15 : Sonoran Steel Fabrication LLC, Toyota Truck Parts
Thanks for the insight. That is helpful and I think I am going to go with the Tundra 5100 and Eibach coils.
I was initially looking at the Tundra 5100/TRD coil setup but when pricing new TRD coils, 5100 shocks, tophat, etc. its about the same as the boss coilover. I don't have that kind of discretionary spending right now and am just looking to get the best "bang for my buck" to get rid of the spacer lift that my truck came with while keeping the 3" lift and improving the ride.
front , icon , information , king , tundra
Icon 2.5 coilovers (parts), King 700lbs coils, Sway Away shaft and rebuild kit justinh For Sale: Suspension/Wheels/Tires 3 10-15-2015 10:23 AM
WTB: TRD tundra coils/Bilstein 5100/OME coils natedogr For Sale: Suspension/Wheels/Tires 2 02-24-2015 01:44 PM
FS: 3rd gen Bilstein 5100 w/ Eibach Coils & Bilstein 5125 Rears - Honolulu - $425 +S awpsome For Sale: Suspension/Wheels/Tires 4 08-21-2014 10:47 PM
Icon VS 2.0 - Bilstein 5100 wkeryder4 4th Gen T4Rs 20 07-15-2014 02:46 PM
Combining a 2.5" Truxxx spacer lift with Bilstein 5100 adjustable front shocks Trem720 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-22-2013 11:35 AM
