Old 06-11-2019, 06:24 PM #1
FuggetitRunner FuggetitRunner is offline
FuggetitRunner is on a distinguished road
Help! Hydraulic tensioner bolt stripped
Vehicle: 1997 4Runner SR5 - 5VZ-FE (162K miles)
Hello everyone. I've lurked here for years and have learned a lot - but I think I done messed up this time.
So while doing my timing belt in the driveway I ended up stripping the front bolt to the Hydraulic Tensioner to the timing belt before I realized what was happening. I doused it with PB blaster. Before the bolt got completely rounded (probably 20% of the head still in tact), I had my friend pull me down to my mechanic who said he'd try to get it out - but doubted his ability with this one himself.
So, question 1: What is the part number for this bolt? I can't seem to find it anywhere. Waiting for Toyota to reply to me as we speak.
Question 2: Worst case scenario the bolt is done for. What course of action should I take? That bolt is holding in the old tensioner - thus I cant cut the old belt off because I wont have any way to get the new one on. After the tensioner was out I just gotta replace the belt, seals, etc and put her back together. This really f*ed my day up.
Oh, and the back 12mm bolt that takes an extension, an angle attachment, and a hail mary backed right out. What gives?
Thanks
Help! Hydraulic tensioner bolt stripped-4runner-bolt-jpg
FuggetitRunner is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 07:54 PM #2
turbo8's Avatar
turbo8 turbo8 is offline
turbo8 will become famous soon enough turbo8 will become famous soon enough
turbo8's Avatar
This tool works great for compressing the tensioner, so you don't need to remove it.
https://www.amazon.com/CTA-Tools-267.../dp/B00VX0ODAY
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
turbo8 is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 08:03 PM #3
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
The bolt is 8mm-1.25X about 50mm. The original has a 12mm head, anything you replace it with from the parts or hardware store will have a 13mm head. If your mechanic knows what he's doing he should be able to get that right out with an extractor socket and some heat or by welding a nut onto the stripped 12mm bolt head.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 08:13 PM #4
Update: Mechanic was able to somehow cut the head of the bolt and get the rest of it out. Tomorrow have to just pull out the actual bearing piece of the tensioner assembly and all should be well. Going to go to a hardware store and see if they can match a new bolt. Will update tomorrow.
Help! Hydraulic tensioner bolt stripped-4runner-bolt-1-jpg  Help! Hydraulic tensioner bolt stripped-4runner-bolt-2-jpg
Old 06-11-2019, 08:15 PM #5
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
We just had another member deal with this - Timing belt HELPP!!!!!
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 08:16 PM #6
Yeah, I was thinking of that route, but then whenever the tensioner finally does go bad - that would just be another job and a half to figure out then. Trying to get her to 400k so I dont want to skimp.
But thanks!
Old 06-12-2019, 09:23 AM #7
JohnMc JohnMc is online now
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Just take it slow. The tensioner has hydraulic damping - if you try to go too fast the hydraulic resistance will end up breaking the aluminum arm between it and the pulley.
JohnMc is online now   Reply With QuoteReply With Quote
Old 06-12-2019, 12:10 PM #8
When I did my timing belt a couple years ago, I found that one of those bolts had already been replaced when the timing belt was done the first time:
The part number for that bolt is 90105-08156, though I just found one in my cache of Toyota bolts that worked (had to cut a few mm's off of the end so it didn't get in the way of anything) so I could just keep working.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-12-2019, 12:22 PM #9
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Thanks for the part number. I try to keep track of Toyota bolt part numbers because I prefer using them when I can.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
back , belt , bolt , hydraulic , tensioner
Stripped timing belt tensioner pulley bolt stonnie 4th Gen T4Rs 5 07-28-2016 04:20 PM
Timing Belt change- Tensioner and idler bearings? Hydraulic tensioner? DiskDoctr Maintenance/Detailing 10 09-13-2015 09:01 PM
Top hat bolt stripped help! Chubbs22 3rd gen T4Rs 3 09-30-2014 02:41 PM
Hydraulic pulley tensioner isuue 4runnerlife General Discussions 3 04-15-2012 01:29 AM
Stripped bolt chunderboy Off Topic 7 06-04-2005 01:23 PM
