Old 11-01-2019, 06:31 PM #31
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by phattyduck View Post
No, that's no problem. You will notice the lack of brakes... The 16" wheel trucks have bigger front rotors and calipers and bigger rear wheel cylinders. I still need to upgrade my brakes, especially since my wife daily drives the 4Runner sometimes...
It is also possible somebody swapped a rear diff and not the front. Do you get any binding in 4WD on hard surfaces driving in a straight line?
Swapping out at 3.9 and putting in a 3.73? I suppose it's possible but would be highly unlikely. Not sure what the benefit would be if someone did that, unless it was done accidentally.
326WHP 347TQ
Old 11-01-2019, 10:01 PM #32
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Meh. I have had multiple trucks with the stock "small" brakes and 35" tires, it's not the huge difference that people make it out to be. Difference in pad engagement is something like an extra quarter inch. Never had a problem stopping my 4runner weighing in at 4200 lbs and a 90 lb wheel and tire on each corner.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 11-27-2019, 11:52 AM #33
nm_alien nm_alien is offline
Real Name: Marc
nm_alien is on a distinguished road
Real Name: Marc
I just picked up an '02 V6 4WD SR5 for $1,500. Rear diff is howling. Looking at options and I'm already getting confused and conflicting information on gear ratios. The stock tire size is a 225/75-15, on the door sticker. The axle code is A02A. After Googling and reading a crap ton of posts, it's steering me to think the ratio is 3.90. But then I asked for a quote from Just Differentials/Nitro and they responded that I have 3.73 gears. And then a few posts up I see another person with the same year/engine/drive/trim is reporting a 3.73. Looks like I need to do the tire spin and driveshaft count thing to be sure.
nm_alien is offline   Reply With QuoteReply With Quote
Old 11-27-2019, 12:19 PM #34
The door sticker on almost all 3rd gen 4Runners says the tire size is 225/75-15. There is a good chance your truck is actually a 16" wheel truck despite the door sticker. I say that because my 4Runner actually was a 2WD 15" wheel truck and has an A01A axle code, verified to be 3.73's.
I expect you have a 16" wheel truck and 3.90 gears - do the spin test to verify.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-27-2019, 12:42 PM #35
Real Name: Marc
Real Name: Marc
They're definitely 15" wheels because I just looked at the tires and replaced the spare on it that was 18 years old. The original Firestone spare was a 225/75-15. the PO put some Michelin LTX M/S 235/75-15 on it. Only a 2% size difference so I'm not too worried about changing the gear ratio.
I live at 7,000 ft elevation in the mountains east of Albuquerque, NM and needed something with 4WD for my son to get to/from school at University of NM, on the other side of the mountain, in town. So it's just for paved road use. I've got a '99 Land Cruiser for the off-road stuff. I don't plan to change the tires or the gearing. Just need to replace/repair the rear diff so it will stop howling and wanted to attempt to figure out the ratio without having to pull it out and count teeth.
Old 11-27-2019, 12:45 PM #36
Real Name: Marc
Real Name: Marc
Tires and door sticker.
Gear Ratio-2002-4runner-tires-jpeg  Gear Ratio-2002-4runner-door-label-jpeg
Old 11-27-2019, 06:07 PM #37
rallypoint_1's Avatar
rallypoint_1 rallypoint_1 is offline
Real Name: Bill
rallypoint_1 is on a distinguished road
Real Name: Bill
That should coincide with a 3.91 ratio.
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
rallypoint_1 is offline   Reply With QuoteReply With Quote
Old 11-28-2019, 09:42 AM #38
The Cold War Kid's Avatar
The Cold War Kid The Cold War Kid is offline
The Cold War Kid is on a distinguished road
Sorry to break in but on a similar subject, did any of these trucks have a positrack rear end? Now that I have disabled my abs that would be a mod I would consider for my 2wd.
2001 Sr5 V6 2WD
"...The closer you get, to the meaning, the sooner you know, that you're DREAMING..." (Black Sabbath - HEAVEN AND HELL)
The Cold War Kid is offline   Reply With QuoteReply With Quote
Old 11-28-2019, 10:16 AM #39
spartacus's Avatar
spartacus's Avatar
I don't think any 4runner came with LSD. Only option was a center locking Atrac or rear locker. Some Rav4 models have auto lsd.
Old 11-28-2019, 01:26 PM #40
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This may help you in your quest for a limited slip differential.
are their limited slips available for a 3rd gen 4x4
You may have to go the route of Detroit Truetrac differential if you want to have limited slip. :-(
determine , front , gear , ratio , rear
Gear ratio? alejo2112 4th Gen T4Rs 6 12-05-2019 03:32 PM
Gear Ratio Sickoreo 4th Gen T4Rs 4 05-23-2015 09:03 PM
gear ratio Daniel0013 3rd gen T4Rs 6 09-24-2013 01:15 PM
what gear ratio smkd13 3rd gen T4Rs 17 11-22-2012 06:36 PM
gear ratio JUGADOR15 4th Gen T4Rs 1 02-20-2012 02:26 PM
