06-12-2019, 10:41 AM
Location: Southern California (please don't hold it against me)
Real Name: michael
Real Name: michael
Gear Ratio
How do you determine what the Rear or Front Axle gear Ratio.
06-12-2019, 10:54 AM
Do you mean how do you identify which gear you have, or what gear you want to upgrade too?
And you realize you need front and rear gears to be the same right?
Mark
04 V8 SE, RST Twin stick conversion. 4x4 Labs rear bumper, SW Sliders & Bullbar, ARB Locked F&R, 5.39’s, Smittybilt 10,000lb winch, 1.5 4Crawler BL, Flowmaster, CB and 2m/70cm Ham, Sat. Radio, CO2 system, Lightforce, African Outback Rack, Budbuilt, Front Runner RTT. Rock Solid Toys Solid axles, Atlas Crawl Case, 40" Cooper STT Pro's on Fuel Anza D116 beadlocks, 5:38 gear set, ADS Coilovers.
06-12-2019, 04:37 PM
Real Name: Patrick
Real Name: Patrick
GOOGLE is your friend
https://www.google.com/search?newwin...iz.UFtWrO_0kMo
06-12-2019, 09:02 PM
Call the dealer with VIN, get the axle code and decode it, or mark the driveshaft and count how many times it rotates to one revolution of of the tire rolling or driving the vehicle in a straight line.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
06-13-2019, 12:44 AM
Real Name: michael
Real Name: michael
thanks for all the help I may have to replace a third ember in a 97 limited. Still evaluating.
06-13-2019, 08:22 AM
If it's a 97 limited without an Elocker, most likely, it's 4.10 but you need to do the spin test to be absolutely sure. Even the "codes" are unreliable.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
06-13-2019, 09:02 AM
Real Name: Keith
Real Name: Keith
Check your vin sticker, get gear code, and thats the ratio. Heres mine an "03" code shows as 4.10 gears. You can double check with a spin test, and also count the gear teeth. Heres a gear chart I grabbed off the net a while back, not sure where I found it.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
06-13-2019, 10:13 AM
Real Name: Mark
Real Name: Mark
Spin test never lie's.
Have heard of the sticker codes being unreliable for couple decades. In the couple decades have messed with dozen or so Runners knowing they were as left the factory, stickers were correct. Have always wondered what situation got the "unreliable" statement going. With the carnage mismatched gears can cause def worth knowing.
06-13-2019, 11:34 AM
Yeah that's what I've read on here for a few years now is to never trust the sticker. The spin test never lies but the instances where the sticker didn't match the actual gears could have been due them being re-geared at some point? Hard to know for sure.
When I swapped the 3rd member from my 99 parts truck into my 97 (previous owner had a trutrac LSD installed in the 99 that I wanted), I didn't want to trust the stickers so I just did the spin test. 10 minutes of my time and I knew both were 4.10 so I was GTG.
2011 Camry SE V6
06-13-2019, 02:20 PM
Real Name: Jerod
Real Name: Jerod
Whoa whoa whoa, back up. There's a 4Runner than came with 4.56 gears??? Any idea which ones? I would LOVE to swap those into mine.
06-13-2019, 02:28 PM
Real Name: Keith
Real Name: Keith
For 3rd gens, I think 4.56 only came on 4cyl/5spd
06-13-2019, 06:03 PM
Real Name: Scramble
Real Name: Scramble
Mine does ya freak! 3RZ - 5 Speed. I even swapped them out of my old axle housing into my 2000 e-locker housing. All of my teeth were in perfect condition.
20170902_121132 by Mike Campbell, on Flickr
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
06-13-2019, 06:29 PM
I think that's why everyone says 5-speed, 4cyl, 4WD with E-locker is a unicorn...
06-14-2019, 09:42 AM
Real Name: Mark
Real Name: Mark
Whoa I would LOVE to swap those into mine.
Good luck finding one, found a 4.56 front pretty quick, never did find 4.56 locker rear in 8 yr., was on used parts want list kept
search/want current up to date. 5-speed, 4cyl, 4WD with E-locker is a unicorn... Has to be the least available version in US seems like..
I finally put the front to use after adding Harrop locker, finding a 2k E-locker axle swapped to 4.56 in the 01 that replaced 96Red. Break in miles finished last month, for how I use it 4.56's with dual lockers is sweet.
06-14-2019, 09:05 PM
Real Name: Robert');DROP TABLE Students;
What size tires? I'm on 285s and am debating 4.56s or 4.88.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Gear ratio?
alejo2112 |
4th Gen T4Rs |
6 |
12-05-2019 03:32 PM |
Gear Ratio
Sickoreo |
4th Gen T4Rs |
4 |
05-23-2015 09:03 PM |
gear ratio
Daniel0013 |
3rd gen T4Rs |
6 |
09-24-2013 01:15 PM |
what gear ratio
smkd13 |
3rd gen T4Rs |
17 |
11-22-2012 06:36 PM |
gear ratio
JUGADOR15 |
4th Gen T4Rs |
1 |
02-20-2012 02:26 PM |
