Old 03-15-2021, 09:48 PM #16
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
I’d go after some of the other typical maintenance items before redoing the timing belt service... you’ve likely a few in the front end... TBU... the rabbit hole is deep if you let it be
While I wouldn’t go the o’reilly route, those parts should last a while at least... 70k though???
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 03-16-2021, 11:22 AM #17
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by ATX4Yota View Post
Breathing life into an old thread. I bought my Runner with 236k miles from a used car lot. Having done some pre-purchase research on 3rd gen 4Runners, I knew the TB/WP needed replacement every 90k miles. I asked if they knew when the service had last been done, since I didn't see a sticker in the engine bay, and was told the car lot's mechanic had done it a couple weeks prior. I asked for a copy of the receipts and they handed me an O'Reilly's receipt for: Import Direct Water Pump, Gates PowerGrip Timing Belt, Murray Plus Straight Thermostat, some outlet seal and a copper seal. The date on the receipt was about a month before I bought the Runner and the part#'s on the receipt are listed for an '02 Runner.
Currently sitting at 268k miles, should I just do the service when normally scheduled at 270k (with OEM kit listed in previous posts) or trust that the currently installed parts will last another 70k miles??
Gates is okay for a timing belt, but they definitely cheaped out with the other parts. Doesn't sound like they replaced the timing belt tensioner or idler pulley either. I would do the timing belt/water pump/thermostat again, but after the rest of the maintenance is done.
belt , brand , oem , parts , timing
Which Timing belt (with water pump) kit? mavrick1903 4th Gen T4Rs 8 08-27-2015 12:34 PM
Timing belt/water pump uaskd4it 4th Gen T4Rs 8 07-01-2011 11:59 AM
Help! New timing belt, water pump, and spark plugs = higher water temps??? vthokie 3rd gen T4Rs 15 05-16-2011 10:59 PM
Best Water Pump and Timing Belt? uncmph00 Maintenance/Detailing 2 10-05-2007 05:51 PM
