Old 06-13-2019, 07:29 PM #1
Capnemo Capnemo is offline
Capnemo will become famous soon enough
How does the plastic seat shield that holds the power seat buttons attach?
Mine was all apart when I bought the truck and I cannot find a DIY video or figure how to snap it back ....prior iwner drilled a hole and had a sheet rock screw
Capnemo is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 09:55 PM #2
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
When I reupholstered my seat, I took that cover off. It was a pain to get off. I think I weakened the built in clips that snap into the rail on the side of the seat. I got it on but it wouldn't stay in place and sometimes when I sat on the seat it would pop out a little and push the seat button off its stem. I did something creative with a zip tie and haven't messed with it for years.
If I remember right there's 2 clips (like plastic hooks) opposite each other (molded part of the trim piece. They clip into the metal rail somehow. I think mine were spreading apart and allowing it to pop outward. I took a few wire ties linked together and when around the two clips once they were inserted and they keep the clips "squeezed" together. There's also a lateral clip in the end that you have to insert underneath the metal rail (or another trim piece, can't remember) before you push it on. Then I believe there's a small screw on the back. So all in all I think there's 3 molded clips and a screw in the back.
Sorry for the vague description. Going off of memory of about 2 years ago. Just make sure all the clips are there and not broken off or bent. When the plastic is bent it turns white where is was bent back or forth and usually is not as strong as it was.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 10:05 PM #3
There is (missing on mine) screw at the back of the plastic piece. On minr
evthe two hooks hold the power switch module, I do not see how they can grab anything else. Above the rear screw and forward a bit near the top is a fliange ir tab, I do not see what it dies as mine is broken and flopping around.
Old 06-13-2019, 10:51 PM #4
Slobo's Avatar
Slobo Slobo is offline
Slobo is on a distinguished road
Slobo's Avatar
1998 4Runner 3RZ 2WD Auto #671
RIP 2003 4Runner V8 Limited
RIP 1990 Celica GT
https://imgur.com/a/z8yIGRf?grid
Slobo is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 11:09 PM #5
Slobo's Avatar
Slobo's Avatar
RIP 1990 Celica GT
Old 06-13-2019, 11:12 PM #6
Slobo's Avatar
Slobo's Avatar
RIP 1990 Celica GT
Old 06-13-2019, 11:32 PM #7
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
I just took mine apart and am reupholstering the seats..... so you get pix !
Slide the front on 1st( the arrow around the X), then the 2 tan clips push into the white piece around the switches, then the screw in the back.
How does the plastic seat shield that holds the power seat buttons attach?-thumbnail-63-jpg  How does the plastic seat shield that holds the power seat buttons attach?-thumbnail-64-jpg  How does the plastic seat shield that holds the power seat buttons attach?-thumbnail-65-jpg  How does the plastic seat shield that holds the power seat buttons attach?-thumbnail-66-jpg
Wedgy is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 11:40 PM #8
Slobo's Avatar
Slobo's Avatar
I have a 98 base model with no power seat, but yeah there is a hook/pocket thing that fits onto the seat track towards the front of the plastic cover and the on the track on the side towards the front, and then screws toward to the side/back to secure it.
RIP 1990 Celica GT
Old 06-14-2019, 11:37 AM #9
Slobo and Wedgie you guys rule! I thought the lastic shield held the power switch module, now I see that the module is screwed to something on the seat and the shield is hled by the power module!
And thanks for the photos showing the slide on front part first.
I can likely figure it out fom here.
Now if I can just find a 2001-2002 shield and lumbar switch so I can relocate the lumbar swith down from the seatback...
Still not sure what the tab at the top mear the back fits on, mine is bent and floppy, will post a photo later when I get home.
Old 06-14-2019, 12:31 PM #10
Dim photo but the tab where my thumb is, where does it go?
How does the plastic seat shield that holds the power seat buttons attach?-442e2a71-20bb-4bd4-a435-919c7e89df9e-jpg
Old 06-14-2019, 03:49 PM #11
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
That's the hot ticket! The '96-00 lumbar switch always falls out. I upgraded my '97 lumbar switch to the '01 setup, and it works great.
I've removed a number of these panels, and I think no matter how careful you are, one of the two tabs almost always breaks off. Fortunately one tab (plus the screw in the back) is usually enough to keep the piece in place.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 08-24-2021, 09:54 PM #12
G-C@T's Avatar
G-C@T G-C@T is offline
G-C@T is on a distinguished road
G-C@T's Avatar
Ughhh…PO had the seats recovered and the shop ground off the male metal piece towards the front of the rail (they had the harness running along the outside and the male “hook” was in the way).
With the front all floppy, a pant leg grabs it and pops all of the control buttons off and out of the truck.
There is a hole on the metal rail in the area of the ground-off hook…I plan to drill the plastic cover and use a small bolt, nut and 2 washers to secure.
1989 SR5
1996 LTD
1998 SR5
1999 UZJ-100
1977 FJ-40
G-C@T is offline   Reply With QuoteReply With Quote
back , figure , seat , shield , snap
Driver Seat Cushion Shield Broken- DIY or Pay for Fix? Kenny Powers 5th gen T4Rs 3 05-21-2019 08:59 PM
Wiring diagram for 2000 power seat - manual to power seat conversion calnhob 3rd gen T4Rs 3 04-30-2018 01:03 PM
WTB: Drivers seat plastic trim for manual adjustment seat. RPTFE00 For Sale: T4R Items 0 08-19-2015 10:41 PM
WTB 3rd GEN Tan/Oak driver seat shield cover SummerallGuard04 Want to Buy/Trade 3 08-15-2012 08:05 PM
Need help: Yellow Plastic SNAP for seat junk yard dog 4th Gen T4Rs 3 07-24-2006 06:05 AM
