Old 06-15-2019, 02:42 PM #16
DaMonkey's Avatar
DaMonkey DaMonkey is offline
DaMonkey will become famous soon enough DaMonkey will become famous soon enough
DaMonkey's Avatar
Originally Posted by jross20 View Post
I just dropped her off to have the front lower ball joints swapped and to have the AC recharged. We are going to summit racing to buy gear oil and then once I get her back I will take the photos. I'll ask the gf to remind me...haha
Just checked her last this morning with torque pro, no codes.
How hot should the cat be?
By chance do you know the OEM numbers for the upstream o2?
Warm up to temp. If front and back of cat are real hot and same temp = bad. Rear of cat may even be lower than front on bad cat. Rear hotter by at least 25f is good. Up to 100f hotter. Expect to see about 270 inlet cat and over 300 outlet when engine has had a chance to get up to full temp.
Try this link for your o2 PN. 3rd gens are not all the same. Might need to determine if Cali emissions truck or not. Maybe w vin or door sticker. I’m Not sure. google tell you. Find My Part
DaMonkey is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 06:49 PM #17
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Whoa, okay I'll need to read this again when I go to check.
And I'll check that link! Thanks man.
Old 06-15-2019, 09:18 PM #18
NissanTechJake NissanTechJake is offline
Real Name: Jake
NissanTechJake is on a distinguished road
Real Name: Jake
Does your scanner show live data?
If your scanner shows live data, post your STFT, LTFT, or ALPHA readings here when the engine is warm. Don’t sit here and throw parts at it if your corrections are perfect you need to look elsewhere.
DO NOT put WS in your transmission. The Toyota fluid you need is: 00279-000T4 it’s backward compatible to DEX II and III. You will also notice MOST Toyota specialty online shops recommend it as wellZ
Let me know if you can do that.
NissanTechJake is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 12:28 AM #19
jross20's Avatar
jross20's Avatar
Alright guys
Today did NOT go as planned... Nothing bad, it all just took damn near forever.
I did get the AC recharged (good god it is amazing), got the drive belts replaced, and I got the lower ball joints replaced. (OEM BJ's).
So now I feel much safer driving it, the gf and I took it on a gentle first time offroad test run. Just a 300-400 foot rough dirt pathway, nothing crazy, pretty gentle I am sure in comparison to true offroading.. haha.
Felt good to take her on the dirt for the first time, didn't even need 4x4!
Old 06-16-2019, 04:13 PM #20
hamsandwiches hamsandwiches is offline
hamsandwiches is on a distinguished road
You could just be feeling the effects of the gas gauge being wildly inaccurate which is common on 3rd gens. Do you have a live data/bluetooth OBD readout? To get the true fuel level
zoinks! there's scoob
hamsandwiches is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 08:04 PM #21
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
If you suspect the cats; this might be a plan B to the Cataclean product.
YouTube
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 11:02 PM #22
jross20's Avatar
jross20's Avatar
No worries I was leaning towards MaxLife...but I am weary about using a non-OEM ATF. Thank's for the part number, I'll look it up.
STFT, LTFT, or ALPHA. Okay will I need to load a custom PID into Torque for these?
Wait... Short and long Term Fuel Trim right? I just figured that out AS I was typing..haha!
I'll make a note to check after driving to the office tomorrow.
What is Alpha? I do not recall seeing that one.
I do have a Bluetooth adapter and torque pro. I've actually always wanted to try to pull a live read of the fuel tank but it only shows "estimated" which is always WILDLY inaccurate.
YouTube
I guess I will go that route if we figure out that I need to.
Also, general update. I reached half a tank at 100 miles, no idea if that is good or not. Going to fill her up tomorrow and see if she really is slurping gas-o-hal or if the gauge is just bonkers.
Old 06-16-2019, 11:10 PM #23
Real Name: Jake
Real Name: Jake
ALPHA is just another version of fuel trims read out in 100% being perfect. A lot of higher end scanners and dealer level scanners use ALPHA.
If you got them let me know.
Old 06-16-2019, 11:19 PM #24
jross20's Avatar
jross20's Avatar
Ah I gotcha! Okay I'll check during the drive tomorrow.
Old 06-17-2019, 09:40 AM #25
jross20's Avatar
jross20's Avatar
Okay here are some screenshots showing the fuel trim. I know this probably isn't what you were looking for, but for some reason I cannot get it to let me log or export data.
in the meantime I will say that in my second gen Tacoma I've never seen the fuel trim on either gauge move that much.
Recently purchased my first 3rd gen, maintenance woes..-screenshot_20190617-092806-jpg  Recently purchased my first 3rd gen, maintenance woes..-screenshot_20190617-093308-jpg  Recently purchased my first 3rd gen, maintenance woes..-screenshot_20190617-093332-jpg  Recently purchased my first 3rd gen, maintenance woes..-screenshot_20190617-093342-jpg
Old 06-17-2019, 09:25 PM #26
jross20's Avatar
jross20's Avatar
Alright so I filled her up tonight at a half tank and she is getting 17.5 mpg. PHEW. So I guess the gauge just isn't all that accurate?
And I have confirmed the rear brakes are grabbing and holding from time to time.
Old 06-18-2019, 09:17 AM #27
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Okay, so Dexron IV it is then.
Thanks all
Dexron VI not Dexron IV
Old 06-18-2019, 10:48 AM #28
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
By the way, I notice your engine temps are a bit high. Mine also used to be 200-205F pretty consistently. I'd bet $5 your thermostat is in upside down, with the "jiggle valve" at 12 oclock instead of 6 oclock. After replacing mine and installing at 6 oclock, my temps are now rock steady at 186F.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 01:03 PM #29
jross20's Avatar
jross20's Avatar
Whoops, VI it is!
I though they seemed high, is this an easy fix? I've only ever swapped a thermo on a 93 Honda Accord. Is 200 dangerous or just non favorable?
Old 06-18-2019, 04:50 PM #30
Real Name: Patrick
Real Name: Patrick
Whoops, VI it is!
Toyota T-IV is another option like others have said, but I work at a GM dealership so Dexron VI was cheaper for me (read free). As far as I know T-IV is synthetic as well and backwards compatible, but don't quote me on that.
I did the timing belt/water pump/thermostat shortly after buying my runner. The first thermostat I used was some aftermarket cheapie that even though it was clocked at 6 o'clock per fsm ran over 200 degrees with 50 degree ambient temps. I swapped that out with a new toyota thermostat when I replaced the lower radiator hose and temps have gone down to 190 degrees even now that it's in the 90's. Just some food for thought there for you.
fluid , oem , parts , proper , purchased
Recently purchased 2005 V6 4runner and have a few questions indaclear 4th Gen T4Rs 5 03-18-2015 09:41 PM
Recently purchased 1991 T4R molonlabe64 Classic T4Rs 5 11-02-2014 11:12 PM
New member from Texas - Recently purchased BLUE RUNNER SURF RUNNER 3rd gen T4Rs 9 12-16-2013 04:58 PM
Recently purchased robbjo1691 Classic T4Rs 3 10-02-2012 04:14 PM
Recently Purchased: $400runner rustyrazor Classic T4Rs 12 07-27-2006 02:48 PM
