Old 06-14-2019, 01:01 PM #1
Wakko Wakko is offline
Wakko is on a distinguished road
Brake booster or master cylinder
Have a 99 limited, trying to diagnose a hard brake pedal. Thought it was the booster so I got that replaced under warranty and it's still giving me the same issue. I don't see any leaks on the master cylinder, anything else I should be checking?
Wakko is offline   Reply With QuoteReply With Quote
Old 06-14-2019, 04:49 PM #2
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
test the vacuum going to the booster. you may need to buy/rent a gauge if you don't already have one.
another test. press the pedal a few times with the engine off to bleed off all the vacuum. then press and hold the pedal when you start it. it should drop .5-.75" once the engine starts.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 08:57 PM #3
ambush ambush is offline
ambush will become famous soon enough
We need more information. Are the brakes going to the floor, hard brake when pressure build, etc? I too am having an issue after changing booster (2x) and Master Cylinder (2x). Same symptoms of a hard brake aka bad master cylinder.
When I have hard brake, I can fix it by removing the vacuum line for about 3 secs and put back while the engine is on then I have brakes. I do not know what to do at all. It is so annoying that I cannot drive this damn truck just because the ABS system wants to engage on its own.
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
ambush is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 07:42 PM #4
i think it was a faulty booster that they gave me as a replacement. Went back got another one and it works fine now. I was getting hard pedal all the time, not intermittent.
From the intermittent issues, i think people were saying bad vacuum check valve. Hope you get it fixed!
Old 06-26-2019, 07:55 PM #5
AWESOME you got it fixed. For me, I think it was the combination of me replacing the MC and creating a gasket that goes behind the MC in front of the brake booster. I have BRAKES!!!!!! YES!
Old 06-26-2019, 07:56 PM #6
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
Start at 10 rarely is it 9 but possible if it's been replaced
SaulG is offline   Reply With QuoteReply With Quote
booster , brake , cylinder , issue , master
Brake Booster/Accumulator/Master Cylinder Assembly Replacement eng208 4th Gen T4Rs 32 07-25-2021 02:55 AM
Master cylinder/brake booster problems and bleed question dncrowell 3rd gen T4Rs 10 01-20-2018 12:46 PM
Electric Brake Booster or Master Cylinder going bad? judogti 4th Gen T4Rs 8 04-28-2017 05:07 AM
3rd Gen Brake Booster/ Master Cylinder Question. UnderFire 3rd gen T4Rs 15 03-02-2015 06:58 PM
brake booster or master cylinder oaknapa098 3rd gen T4Rs 4 11-27-2011 07:42 PM
