Old 06-15-2019, 04:16 AM #1
skillbill skillbill is offline
skillbill is on a distinguished road
A/c problems
I have a 96 limited. My A/C works most of the time but every once in a while it just stops. Any ideas what it might b?
skillbill is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 12:00 PM #2
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Define 'just stops.' No blower, too? Or just stops blowing cold.
If the latter, first thing to do is look to see if the compressor is turning. Second, is check your refrigerant pressure.
My Backyard Frame Swap
Old 06-15-2019, 08:07 PM #3
Just stops getting cold. Blower still working.
Old 06-15-2019, 09:23 PM #4
NissanTechJake NissanTechJake is offline
Real Name: Jake
NissanTechJake is on a distinguished road
Real Name: Jake
Blowing hot air
Like theDurk said.
If it’s blowing air but it’s not cold, the compressor is likely not running. Look at the compressor clutch (center of pulley) and see if it’s spinning when the air is warm, it’s likely not.
If that’s the case take a volt meter or test light and check for power at the compressor wire, if you have power the clutch is bad, no power indicates the ECM is shutting the compressor off. This could be for a couple reasons.
Low Freon
Pressure switch
Etc.
Generally the first thing I would do is evacuate the system and put a vacuum on it to make sure there are no leaks. Then charge it to the proper levels and go from there.
NissanTechJake is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 11:04 AM #5
nissanh nissanh is offline
Have you cleaned the AC condenser located in front of the radiator? If it is clogged, hot freon will be hot and the high side pressure switch finds high pressure and may shut off the compressor. If the Idle up does not work ECU can shut power to AC compressor too (it happened to my 92 corolla).
Also check the AC drive belt. Clean the gap between AC clutch and pulley with some compressed air.
Old 06-17-2019, 01:53 PM #6
azrex azrex is offline
azrex is on a distinguished road
It could also be the expansion valve sticking. If you have gauges hooked up when the A/C quits blowing cold, you'll see the low-side pressure go very low or into a vacuum.
azrex is offline   Reply With QuoteReply With Quote
a/c , ideas , iphone , problems , stops
problems, problems, just about in tears venusdelovely 4th Gen T4Rs 3 07-30-2015 11:55 PM
o2 sensor problems and alignment problems jjlemus1 Classic T4Rs 34 06-01-2011 02:35 PM
A/C Problems Mark86 Problems & Warranty Issues 3 08-22-2009 02:49 AM
problems wit my 84 bpmatt Problems & Warranty Issues 2 08-30-2005 11:54 PM
problems wit my 84 bpmatt Maintenance/Detailing 0 08-23-2005 07:44 PM
