Old 06-15-2019, 03:14 PM #1
grokglock grokglock is offline
grokglock is on a distinguished road
What is this? Unidentified brake spring
I am doing a brake job and it came with new hardware including this little spring which my truck did not have when I removed my pads. Where does it go?
Sent from my LG-H932 using Tapatalk
grokglock is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 07:47 PM #2
spartacus's Avatar
spartacus's Avatar
it holds the pins for the pads in place.
What is this? Unidentified brake spring-screenshot_2019-06-15-17-47-56-jpg
Old 06-16-2019, 12:41 AM #3
That looks like a different setup from mine. I have a big metal shim that goes over the entire rotor vent
Old 06-16-2019, 01:49 AM #4
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
That W shaped spring doesn’t hold the pins in place. It rides on one pin and pushes out against the pads to keep them from squeaking. It’s just an anti-rattle clip.
JZiggy is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 01:52 AM #5
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
You'll want to put it in. Without it the pads could potentially create more noise.
326WHP 347TQ
Old 06-16-2019, 03:09 AM #6
RotaryDreamz's Avatar
RotaryDreamz RotaryDreamz is offline
Real Name: Sean
RotaryDreamz will become famous soon enough
Real Name: Sean
The picture above is of Tundra brakes. An easy upgrade you have the option to do on our 3rd gens, which is why it may look different than what you have.
When I took off my OEM calipers and pads for the upgrade, none of them had those clips installed. I didnt have any extra noise, but I would just install them if it came in your new replacements.
RotaryDreamz is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 11:40 AM #7
thanks for the ID. I ended up leaving them off because mine pads have a piece that goes in between both pads that seems to do the same function and I didn't think it would be necessary to use both.
brake , lg-h932 , pads , removed , spring
brake pedal spring location mike_m 3rd gen T4Rs 0 11-17-2018 11:56 PM
Brake caliper spring came off Mighty Buffalo 3rd gen T4Rs 1 07-21-2015 07:42 PM
1999 4Runner Unidentified Problem. Advice? RyanMcCarthy 3rd gen T4Rs 9 06-25-2013 10:04 AM
Help? Unidentified wire/3-prong plug in front end. Jbahr 5th gen T4Rs 12 08-28-2011 08:58 PM
VIN unidentified?... 4R_in_Uzb 4th Gen T4Rs 1 06-21-2007 05:43 PM
