Old 06-15-2019, 08:46 PM #1
NissanTechJake NissanTechJake is offline
Real Name: Jake
NissanTechJake is on a distinguished road
Real Name: Jake
Magnetic transmission plug
Anybody know if these will fit our transmission?
I serviced my trans today and accidentally left my magnets on the bench lol. I am not pulling it back off and cleaning those gasket surfaces again over some magnets.
Thanks.
Magnetic transmission plug-e64f26cc-7882-463a-8dff-46975e6c96c7-jpg
NissanTechJake is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 01:53 AM #2
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Thanks.
Is the transmission pan steel? (I’m ignorant since I have a manual) If so you could slap some power magnets on the outside and they will pull filings and keep them there just the same.
JZiggy is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 01:55 AM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
One single magnet is not enough to catch all of the metal shavings that come off. There's a reason why there's 4 magnets in the bottom of the pan.
I highly recommend dropping the pan and replacing the magnets. I also recommend using a cork gasket that you can usually pick up from the auto parts stores for around $10. It's cleaner, easier to install and does not leak. I've had mine for 4 years, and re-used it a few times in between and not a drop comes through. And I don't have to mess with the goop!
326WHP 347TQ
Old 06-16-2019, 07:24 AM #4
Real Name: Jake
Real Name: Jake
Yes, the pan is steel and the magnets are small enough you could likely push them back in the hole just not place them back in there exact locations. The magnets basically prevent the mastic paste of fine shavings from clogging the filter which will not be an issue at my 30k mike drain and fill intervals.
Was really just hoping someone knew off the top their head of the trans and engine oil pan plugs were same size and thread?
Old 06-16-2019, 07:49 AM #5
The trans drain plug is 10mm 1.5 pitch. I’m sure the engine drain plug is bigger.
I have magnafine in-line filter in the trans cooler line. It’s got a big magnet in it.
Old 06-16-2019, 09:52 AM #6
RS Dude's Avatar
RS Dude RS Dude is offline
RS Dude is on a distinguished road
RS Dude's Avatar
A Magnefine inline filter is a good idea for anyone because it has a big magnet inside to collect the filings also.
'96 T4R SR5 V6 Auto 2WD 329,000 miles
RS Dude is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 02:47 PM #7
Real Name: Jake
Real Name: Jake
Thanks you! That’s exactly what I needed. I had ordered the magnefine filter as well since I can put that online in about 10 minutes.
Old 06-16-2019, 03:09 PM #8
I have mine zip tied to the power steering lines under the engine. If you run the factory skid it is protected.
Old 06-16-2019, 04:27 PM #9
hamsandwiches hamsandwiches is offline
hamsandwiches is on a distinguished road
Yea why does the magnet have to be on the plug? Just stick magnets all over the pan if your service involves dropping the pan anyway
zoinks! there's scoob
hamsandwiches is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 11:03 PM #10
Real Name: Jake
Real Name: Jake
My “regular service” is a drain and fill.
I ONLY dropped the pan to check the filter and magnets since I just purchased this and am unaware of the service history. I left the magnets out accidentally when cleaning the pan and noticed it when cleaning up.
The point was pan magnets are great for when fluid is sitting in the pan (vehicle parked) but not entirely necessary with good maintenance intervals. I’m not pulling the pan again over the little magnets when there are alternatives that are easier and better at this point (magnefine and drain plug magnet).
I JUST had no clue what the transmission BOLT SIZE and thread pitch was, but if you read up it was provided so I am good to go.
Thanks again.
Old 06-16-2019, 11:22 PM #11
JMat's Avatar
JMat JMat is offline
JMat will become famous soon enough
JMat's Avatar
Harbor Freight has some really strong magnets for pretty cheap I would stick a few on the outside bottom of the pan, install a Magnefine Filter and you should be good.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
JMat is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 08:21 AM #12
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
They also make a rubber gasket that is reusable. I had my old tranny's pan off probably a half dozen times when I was having tranny issues. It never leaked a drop and I never had to clean up the FIPG/RTV mess ever again.
Slap some super strong magnets on the outside and install the magnefine filter on the line and call it a day.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
cleaning , gasket , magnets , surfaces , transmission
Auto Trans Magnetic Drain Plug tx_shooter 3rd gen T4Rs 17 08-11-2017 07:59 AM
recommend: magnetic drain plug davester00 5th gen T4Rs 0 03-08-2015 09:51 AM
Just Stripped my Transmission plug! Maxil 3rd gen T4Rs 4 09-24-2011 08:30 PM
2011 Magnetic Drain Plug huskyrunner8 5th gen T4Rs 5 03-29-2011 04:45 AM
Transfer case magnetic drain plug? coldbivy Maintenance/Detailing 5 11-02-2005 03:37 PM
