Old 06-15-2019, 09:36 PM #1
hdoggie24 hdoggie24 is offline
hdoggie24 is on a distinguished road
OME trim packers on rear 5th gen springs?
Not sure if anyone has tried this or knows the answer. I am putting a set of rear 5th gen springs on my 97 4runner soon. People seem to use the OME trim packers to lift a little bit more. The OME trim packers are different for 3rd and 5th gen 4runners. So if I did add these I am not sure which ones I would use with the 5th gen springs???? If anybody has any idea that would be great. Thanks,
hdoggie24 is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 01:57 PM #2
I used the 3rd gen ones on my springs.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-17-2019, 05:40 PM #3
Thanks for that info. Just to clarify. So the 2nd picture shows the rear 5th gen springs being used with 3rd gen trim packers? Also, did you use 1 or 2 trim packers on each side? Thanks for posting this info too. Sweet, I have the same wheels as you too.
Ryan
Old 06-17-2019, 07:21 PM #4
Ryan
Yes, correct. 5th gen springs (2014), 3rd gen spring packers, one on each side. Your springs may be a tiny bit loose at full droop still, but there is no way they would fall out. Ride height is right at 22" center of hub to fender lip.
5th gen springs are slightly larger in diameter than the stockers, but they have been working fine so far (though, I'm still considering getting 2906's when I have the chance).
Old 06-17-2019, 07:34 PM #5
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
I have the same setup (5th gen rear springs in a '97), and I like the height and the ride.
One thing that bothers me is that like said above, the 5th gen spring is somewhat bigger in diameter than the 3rd gen, so it does not automatically get centered on the seat during installation. I tried to centered it as best I could, but I am sure it moved a little. And with the spring not centered, a portion of it sort of hangs off the spring seat. I don't think it's going to outright fail, but I would like to find a way to center the spring on the seat.
Would the trim packers do that, or are they only for increasing ride height?
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 06-19-2019, 04:18 AM #6
Thanks for the info. I plan to add a trim packers to the 5th gen coils when I install them. And 4runner4Leon, when I do this Ill let you know what I find out if it helps center the springs a bit
Old 06-25-2019, 06:15 PM #7
Real Name: Leon
Real Name: Leon
Awesome, thanks!
Old 02-24-2020, 04:54 PM #8
NegroTundra NegroTundra is offline
NegroTundra is on a distinguished road
The trim packers don't help center the 5th gen springs; when you install the TP's, you take the bumpstop cone out of the spring, slide the cone through the TP's, then reinsert the cone into the spring. So when your done, the cone is still the commonality between the spring and frame. I just did this btw and its a great setup. If I ever decide to move my 5100's up a notch I will add another TP to the rear.
00 T4R 3.4L Sc'd Locked 4x4 (140k)
98 T4R 3.4L 5-Speed Locked 4x4 (280k)
16 Dodge Ram 2500 6.7L Cummins fully deleted
NegroTundra is offline   Reply With QuoteReply With Quote
5th , gen , ome , packers , springs
OME rear trim packers....how many is too many GX4SEVEND 5th gen T4Rs 5 04-30-2019 11:47 AM
SOLD FS: TRD Pro rear springs & OME rear spacers/trim packers - Chi, IL $60/$40 little_titan For Sale: Suspension/Wheels/Tires 6 04-19-2019 06:54 PM
Trim packers for rear springs momo.75 4th Gen T4Rs 5 10-06-2016 12:16 AM
4th gen rear trim packers michaelreed 4th Gen T4Rs 10 03-29-2012 09:13 AM
