Old 06-17-2019, 04:21 PM #16
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by 19963.4lsr5 View Post
This is the shell and tube trans cooler for a 94-98 12v Cummins. It’s got antifreeze on one side of the tubes (through the tubes) and trans fluid on the other side (outside the tubes.
but the point of keeping the engine coolant and trans fluid separate is so you can avoid pink milk shake and have independent control over cooling rates.
Old 06-17-2019, 04:51 PM #17
This is not a cooler with aluminum parts. It will not fail and mix the fluids. I get what you mean about the antifreeze adding unnecessary heat into the ATF however it’s on the cold side of the rad and withmy driving habits my trans pan temps are not above 160. I don’t wheel with mine.
Old 06-17-2019, 06:14 PM #18
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Derale Fluid Control Thermostats 13011
Fluid Control Thermostats : 3/8" NPT Fluid Control Thermostat Kit
Bypasses cooler until fluid temperature reaches 180°F
Can be rotated 180° to switch flow direction
Flows up to 20 gallons per minute
Rated up to 200 psi
you can see it right here
YouTube
it's kind of beefy but I found a good spot to hide it.
Thanks sd. That one in particular caught my eye some time back. If you wanted to install an auxiliary fan and have it thermostatically triggered, like let's say at 200F, how would you do that with your current set-up? Maybe split the return and add one of these...
https://smile.amazon.com/American-Vo...ay&sr=8-3&th=1
Member @octanejunkie introduced this to me a while ago, and I'm still thinking about it, or something like it...
Earls 2077ERL Earl's Billet Remote Oil Filter Mount
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 08:45 PM #19
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
That @octanejunkie is trouble
yea sure you could add a trigger into the runs someplace for sure. it's a good idea and maybe at some point I will do it.
setup #1 with just using the hayden external cooler temps would run 130-140
setup #2 in series with the radiator temps would run 140-150
with this setup I run 165-185
IMO the A340F shift and runs the smoothest at 170-180 deg
when my temps were low I noticed clunky shifting. I have just come to believe running at the higher temps(170-180) is actually a good thing. sure you will have to change the ATF more often but... it's ok. I used to think it was too hot but I have come around.
that hayden cooler specs... way more cooling than I needed.
Class "A" motor homes, large travel trailers, 5th wheel trailers
GVWR up to 30,000 pounds, towing up to 10,000 pounds
disclaimer I don't tow with my rig so I might feel differently if I did. towing makes a lot of heat. I feel like I have the capacity to handle the spikes in temps and still keep the temp in range so the ATF is doing it's job and keeping the trans lubed up.
I was never really happy with my external cooler until now.
Old 06-17-2019, 09:11 PM #20
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Trouble is as trouble does Anyone running the Tru-Cool 4589?  What temps do you see?
For what it's worth, the B&M thermostaticly controlled oil cooler I put on my Chevy pickup has a switch that turns on the dedicated cooling fan at 175° via a ground interrupt switch. I wired it to an ignition-switched relay with a full-time battery hot.
You could easily accomplish the same thing installing that thermostatic plug in that external filter thingies you claim I told you about.
NB
I ended up replacing the radiator on that truck with an internal oil cooler because the transmission simply ran too hot with an air cooler only. Your mileage may vary
Sent from my Pixel XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 07-03-2019, 08:31 AM #21
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Update time guys.
Two for the past couple of times that I've tested it, my temps seemed to hover between 140 to 175. The very rarely I will see the number spike to 350-400 for about 1 second. I'm assuming this is just some kind of a glitch or blip?
Old 07-03-2019, 08:44 AM #22
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by jross20 View Post
Update time guys.
The flash point of Dexron 3 is 400 degrees Fahrenheit. I'm going to assume its a glitch. You probably have an intermittent bad sensor or possibly a wiring issue on that circuit. It could also be a poor connection at the sensor if you're lucky.
Edit: I'm running a Tru-Cool 4589 on my 2000 and monitor trans temp via Ultra-Gauge. I have yet to get over 190 degrees. City driving is definitely higher temps than highway driving. Mine is mounted on the passenger side of the condenser with the pass through zip ties that came with it. FYI there is a thermostatic bypass (functions similar to a thermostat) built into this model. I'm entirely bypassing the radiator.
Old 07-03-2019, 10:19 AM #23
TonyB66's Avatar
TonyB66's Avatar
FWIW, I have another make bar & plate of the same dimensions (8x11x1.5) and have and I've seen about the same, highest around 180 or so and that was momentarily. I'd say 90% of the time has been 140-170, the remaining time is the warming-up period to those temps.
My ATF has seen markedly lower temperature peaks and more so overall average temps. This should greatly help with the quality and life of the fluid. I also added a Magnefine filter at the time, so I'm feeling pretty good about the tranny these days...
Old 07-04-2019, 08:28 AM #24
jross20's Avatar
jross20's Avatar
Strangely enough the temperature is the highest on the highway, and drops during city driving.
I also noticed that the a340 becomes butter smooth at 170-175° F. Now it's definitely not rough or jerky below that temperature, but you can really feel the shifts. I'm not sure if this is fine or if I need to let her stay around 170° F.
cool , running , temps , tru-cool , worried
My trans temps and 70264 to 4589 swap 4racer 3rd gen T4Rs 40 07-01-2016 11:54 PM
3rd gen Tru Cool 4589 install???? Link12 3rd gen T4Rs 1 02-07-2015 10:58 PM
temps, air intake, and coolant temps on a stock runner the great him 3rd gen T4Rs 13 07-15-2014 10:18 PM
Anyone Notice Their Tranny Temps Running Higher With Budbuilts? brian2sun 3rd gen T4Rs 2 08-25-2011 07:16 PM
Drastically different running temps with 2 different thermostats COShadow 3rd gen T4Rs 15 06-27-2011 07:40 PM
