Old 06-17-2019, 11:50 AM #1
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Annoying brake pedal creaking noise
I went to lube the brake pedal but once I looked at it wasn't sure where to lube. Cant tell where exactly the noise is coming from, maybe something behind the boot (which I didn't want to start pulling apart)? It does it when I let off the pedal. And is white lithium grease ok to use on it?
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 01:53 AM #2
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I don't think Toyota intended any of these parts to be greased, but an itch has got to be scratched.
There's the hinge, the contact points for the push rod into the master, the spring attachment points, and maybe a few other pivot points. The hinge didn't look very greasable on mine, but it might be oilable. I would try something like Tri-flow that sprays in, (or some molybdenum disulfide grease mixed with oil?) and leaves some dry lube stuff behind if/when it evaporates.
The other points conceivably could be greased; I suggest molybdenum disulfide grease, again because it leaves a dry lube behind if/when the oil evaporates.
I used moly-diS grease(Sta Lube)CV joint grease on the spring attachmant points for my clutch pedal and it has worked very well. Good luck.
pluton is offline   Reply With QuoteReply With Quote
annoying , brake , lube , noise , pedal
Brake pedal noise Flaminghawk 5th gen T4Rs 37 02-18-2020 11:14 PM
Brake pedal noise...? 08medic4x4 4th Gen T4Rs 8 03-03-2010 10:33 AM
Brake Pedal Noise T4RVA 4th Gen T4Rs 3 12-21-2009 10:49 PM
brake pedal noise crosby87 Problems & Warranty Issues 3 11-10-2008 12:18 AM
brake pedal noise crosby87 4th Gen T4Rs 2 09-26-2008 06:30 AM
