Old 06-17-2019, 05:28 PM #1
hoksibish hoksibish is offline
hoksibish is on a distinguished road
Exclamation What in the ROCKS? 3rd Gen noise
So my 3rd gen sounds like a rock is rattling around in the bell-housing. However it only rattles when the truck in gear. Park and neutral the sound goes away. The noise also takes a bit to start after a cold start. I took a stethoscope and poked around and cannot find the noise anywhere! The newest thing is now when the motor stops it sounds like the rock is still rattling around for a couple seconds. This doesn't sound consistent like a flex plate crack but maybe??
Thought I would reach out to see if anyone has heard this before.
Link to a video.
hoksibish is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 10:28 PM #2
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
Sounds like it could be the cat heat shields. Bang on them a bit, you’ll quickly know if that’s the source of your noise
BrianK14 is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 11:08 AM #3
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Check the heat shields on the exhaust. There is a small one that is barely spot welded on, and another that is held on by 2 bolts. 1 bolt was missing, and the welded one fell off when I touched it.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 04:22 PM #4
thank you for the suggestions. Just checked and the exhaust is solid. No missing nuts or bolts. Started the truck and it was quite till it warmed up and I put it in drive and reverse. That's the only time the noise appears.
Old 06-19-2019, 02:29 AM #5
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Check the dampner behind the center diff (metal plate w/chunk of rubber attached), it can get loose and rattle at idle or other times. Luck and enjoy the runner.
Old 06-22-2019, 10:34 PM #6
Checked the dampener as well. Thanks for the suggestions. I can't seem to find it anywhere. The fact that it only makes the rattle when the truck is in a gear, torque converter maybe?
Old 06-23-2019, 01:23 AM #7
nc-grayson's Avatar
nc-grayson nc-grayson is offline
nc-grayson is on a distinguished road
nc-grayson's Avatar
Have someone sitting in the drivers seat mashing the brake with e brake on and in gear, narrow down location
2000 4Runner SR5 Sport
1998 Lexus LX470
nc-grayson is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 10:08 AM #8
sandracer33 sandracer33 is offline
Real Name: Lee
sandracer33 is on a distinguished road
Real Name: Lee
That's how mine sounded when the flexplate started to fail. I chased every heat shield, bracket and clamp on the truck. Even looked at the drive belt idler bearings & a/c clutch. Got progressively worse over 3 months until I was able to confirm what it was.
Sent from my Pixel 3 XL using Tapatalk
"Mongo only pawn in game of life..."
sandracer33 is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 12:13 PM #9
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
There is a black cover you can remove on the front of the bellhousing and look inside (with a mirror, super awkward). The flex plate is somewhat open to the enviroment so you could actually have a small pebble rattling around in there. I replaced the cover's gasket thing on mine a while ago which had disintgrated, the bellhousing was full of crud.
Or the flex plate could be cracked. I just replaced mine as PM not too long ago while the transmission was pulled to do the torque converter seal. Did the rear main seal as PM too. Wasn't cheap the flex plate is about $300. You should do the rear main seal, transfer shifter seat and starter contacts/plunger as PM while the transmission is pulled.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 07:40 PM #10
So I pulled the inspection plate. It's very hard to see. If it was cracked at all I should be able to see something right? Most interwebs pictures of a cracked one has the cracks towards the center.
Old 06-25-2019, 12:33 AM #11
Real Name: Lee
Real Name: Lee
I couldn't see the cracks on mine until it was almost totally broken in two pieces. It broke the morning I was going to replace it in the driveway at home.
Old 06-25-2019, 04:01 PM #12
Thats lucky. Thanks for the pointers. Looks like i will pull the tranny and go from there.
thanks again all
Old 09-05-2019, 07:15 PM #13
So it turns out it was the TC giving up to ghost. replaced the tc and the rock tumbler is no more.
noise , rattling , rock , sound , start
Nah nah nah... lil skips rocks! calicojax 3rd gen T4Rs 0 06-20-2017 11:57 PM
whitebeauty Rocks AKFatBoy Feedback on Sellers & Buyers 1 12-07-2015 06:39 AM
2nd Gen on the Rocks redux BucknutBob Classic T4Rs 7 06-24-2012 07:49 PM
2nd Gen on the rocks BucknutBob Classic T4Rs 39 04-09-2012 03:59 PM
New Katemcy Rocks (K2) JeremyH Off-Roading 0 01-25-2010 04:25 PM
