Old 06-18-2019, 01:09 PM #1
ølaf ølaf is offline
ølaf is on a distinguished road
Intermittent Brake Fade
Hi all.
New pads, new rotors, Tundra calipers. Last brake bleed about 2 years ago (who I installed the tundra calipers). Brakes feel very strong right after start-up, but every once in a while, I get a hard pedal and the braking power feels very weak. Is this a sign of trapped air, or could the booster or master cylinder be on the way out. Both are original. Any other ideas?
Thanks for any ideas!
1999
240k.
ølaf is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 02:39 PM #2
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Originally Posted by ølaf View Post
Hi all.
1999
240k.
a hard pedal and weak braking would be a sign of a booster failing. possibly the check valve, but at that mileage I would suspect the booster itself.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 03:46 PM #3
Kyngfish Kyngfish is offline
Kyngfish is on a distinguished road
I'd try a re-bleed as well though. I actually had the same exact issue after the Tundra upgrade.
It certainly could be the booster failing or (according to what I've read) it also could be the master cylinder letting some fluid seep by. But in my case, I didn't have any problems before the TBU and I got the occasional problem only after the upgrade. I re-bled the brakes and I haven't had the problem at all in months.
Anyway, worth a try.
1998 Toyota 4Runner Limited 4x4 - Black
1986 Porsche Carrera 3.2 Coupe - Guard's Red
2015 GTI SE - Tornado Red
Kyngfish is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 04:07 PM #4
Thanks guys! ills tart with a bleed. Far to near, correct?
As far as the booster ... any way to check it?
Thanks!
- olaf
Old 06-18-2019, 04:39 PM #5
Thanks!
- olaf
I believe the best approach is passenger rear - driver rear - passenger front, driver front. No idea on the booster. I'll let others sound off.
I hope you check back in once you find a solution though and let us know what it was.
Good luck
Old 06-18-2019, 04:54 PM #6
nevada's Avatar
nevada's Avatar
Thanks!
- olaf
with the engine off, pump the pedal a few times to drain all the vacuum. then while holding the pedal down, start the engine. the pedal should sink about 3/4" or so. that is a sign its working.
but, if as you said the pedal gets hard, the booster is not working.
air in the system would give you the opposite symptoms. you would have a soft or low pedal.
Old 06-18-2019, 05:20 PM #7
pokeyman pokeyman is offline
pokeyman is on a distinguished road
Sounds like a master cylinder to me.
pokeyman is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 06:13 PM #8
Interesting ... I can't feel a failing booster or air in the system in the parking lot / firing up the engine type of scenario, since this will only happen about once a day or every other day.
How would I diagnose a leaking master cylinder?
How are the symptoms different than a failing booster?
Thanks!!!!
Old 06-18-2019, 06:43 PM #9
A bad master would be the pedal sinking slowly with your foot on the pedal . Everytime you pump on the pedal the pedal would rise and then slowly go down again.
air , brake , calipers , ideas , tundra
Intermittent Brake Booster JBurt 3rd gen T4Rs 12 03-19-2020 04:00 PM
Intermittent brake pedal issue Kyngfish 3rd gen T4Rs 6 03-20-2019 08:51 PM
Stuck E-Brake and brake fade calithirteen 3rd gen T4Rs 8 04-20-2016 03:39 PM
Brake fade after new brake pads and rotors tjhaf2007 4th Gen T4Rs 4 07-21-2014 12:05 PM
Intermittent Brake Problems B084R 4th Gen T4Rs 10 10-27-2008 10:43 PM
