Originally Posted by ølaf
Thanks guys! ills tart with a bleed. Far to near, correct?
As far as the booster ... any way to check it?
Thanks!
- olaf
with the engine off, pump the pedal a few times to drain all the vacuum. then while holding the pedal down, start the engine. the pedal should sink about 3/4" or so. that is a sign its working.
but, if as you said the pedal gets hard, the booster is not working.
air in the system would give you the opposite symptoms. you would have a soft or low pedal.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
