Old 07-21-2019, 02:25 PM #16
I also have the magnifine in the hot line coming from the trans in both 97’s
Old 07-22-2019, 01:46 PM #17
214K_02T4R's Avatar
214K_02T4R 214K_02T4R is offline
214K_02T4R is on a distinguished road
214K_02T4R's Avatar
Originally Posted by LittleCaesar View Post
Think of it as more of a strainer than a mesh filter. I’d drop the pan more to see what material the magnets are holding. But if you do drop the pan, then by all means change it.
I’d also consider one of these while installing the cooler. It keeps all the unwanted gunk out of the valve body. I personally can recommend them again now that they have gone back to an aluminum housing:
Thanks for the reminder, I had forgotten about that, I've seen it suggested in pretty much every trans cooler install video regardless of vehicle.
ORDERED!
Thank you, I appreciate it!
Where is a good place to order the Toyota Trans Filter? I've been reading that Camelback Toyota is not the low-cost option they used to be. Also, if I get it from them I pay sales tax because I'm in state.
Suggestions?
Thanks again fellas, I really appreciate the help!
214K_02T4R is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 02:22 PM #18
Originally Posted by 214K_02T4R View Post
Ambient temps here in Arizona are 100-116-degrees daytime. Its the summer.
Coolant temps are pretty static, between 195.8 and 199.6, averaging 197.6.
Transmission temps (after engine warmup) range from 176.0 to 226.4, averaging between 198 and 219. Still way too high in my opinion.
What do you think IS ideal for trans temps? Most are designed to run optimally around 180*F. Most will get less efficient below maybe 140*F. You really only need about 20*F 'extra' cooling for your truck is running now - which for Arizona summer is pretty good.
It still looks like your coolant temps are on the high side, but nothing critical. A coolant change shouldn't change temps, that is controlled by the thermostat. Also, water is much better at heat transfer than coolant - coolant is in the system to raise the boiling temp, lower the freezing temp and to inhibit corrosion.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-22-2019, 03:06 PM #19
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Transmission temps (after engine warmup) range from 176.0 to 226.4, averaging between 198 and 219. Still way too high in my opinion.... Suggestions?
An electric fan in front of your New trans cooler will lower temps about 25-35 degrees, both sitting at a light and driving down the road.
Ask me how I know.....
Old 07-22-2019, 07:55 PM #20
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
I would try Fleabay, just type in Toyota 35330-30020. Some members have used a gasket when reinstalling, thought I used the designated Toyota tranny FIPG.
Good luck with everything. Post the ATF numbers you are seeing afterwards. Then sometime later you can do a full ATF drain and fill.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 10:01 PM #21
Toy2play Toy2play is offline
Toy2play will become famous soon enough
Not sure how you get that much cooling from a fan. I too have a pusher fan on my in line tranny cooler and it doesn't do jack. I really wish it did. Im regularly over 200 right now in the summer months. Currently 100 degrees outside and was pushing 210. I almost feel like I need another cooler. I've already got the bigger one.
97 Charged, lifted, armored, geared, locked SR5.
Toy2play is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 02:41 AM #22
AZBub's Avatar
AZBub AZBub is offline
Real Name: Chris
AZBub will become famous soon enough AZBub will become famous soon enough
AZBub's Avatar
Real Name: Chris
I’m in AZ, several months ago I suffered from high transmission temps. My issue ended up being the lock up solenoid. Unfortunately the consistent high temps resulted in a new transmission.
Even after installing a new transmission and a cooler i was still seeing 200-210 in AZ summer. Swapped out the fan clutch and added a different radiator and now i’m what would be considered “normal”
this is pre and post.
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
AZBub is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 02:54 PM #23
jgue467's Avatar
jgue467's Avatar
Originally Posted by Toy2play View Post
Not sure how you get that much cooling from a fan. ...
When I first used it I thought it didn't do much but then I noticied I have to wait a little while, maybe 5-8 mins before the cooling really takes affect. It is a 10" fan, one with curved blades, 80watt, something like 2300 CFM I believe, just a cheapo off ebay, came with 2 fans yet just installed one. Luck.
215-f , cooler , temps , time , transmission
Trans Temps with Bypassing and Using External Cooler mtbtim 3rd gen T4Rs 84 10-06-2017 09:28 AM
broke trans cooler line loose from radiator. how do i flush the transmission homeinspector 3rd gen T4Rs 6 12-01-2014 06:51 PM
Transmission temps - with / without external cooler when towing footy14 3rd gen T4Rs 22 01-29-2014 10:09 PM
TOYOTA OEM TRANSMISSION COOLER Trans Cooler nissanh For Sale: T4R Items 1 03-30-2013 10:24 PM
Transmission Cooler/V8 - which one bolts up? How to refill Trans? webby 4th Gen T4Rs 3 06-17-2012 10:00 AM
