Old 06-22-2019, 11:25 PM #16
NissanTechJake NissanTechJake is offline
Real Name: Jake
NissanTechJake is on a distinguished road
Real Name: Jake
Haha
Originally Posted by thezentree View Post
....I just put 6 qts of T-IV in mine. Am I going to die?
Nope, your good to go ;)
NissanTechJake is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 09:16 AM #17
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Originally Posted by T4R2014 View Post
You made a good choice. I think changing the fluid matters more than worrying about spec. That said most businesses tend to stick to OEM ATFs. Toyota Dexron is out there but hard to find, so most local dealers supply them with Type IV. Similar to OEM coolants most shops use them for liability reasons. Much safer to use that than an unlicensed Dexron. Can't blame the mechanic's choice in fluid if the transmission fails after a drain and fill or flush.
Well I do need to take some kind of print out or something to the shop because originally they were just going to use WS. They are some really cool dudes but I think maybe they were misinformed by Toyota or something. I think I need to bring them something that shows WS is a no no on older Toyotas.
I hope not!!!
Old 06-23-2019, 02:29 PM #18
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Originally Posted by NissanTechJake View Post
Toyota ATF Type T-IV
This is backwards compatible with DEX II and III
4Runner compatible years. 1984-2005
You must be referring to WS that’s NOT compatible.
You will notice this is what most Toyota specialty shops sell and recommend.
What is WS?
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 02:33 PM #19
BoomerBob's Avatar
BoomerBob's Avatar
Originally Posted by jross20 View Post
I read a lot where people say it's good, but I've also read some things where people had issues and also explained said issues. And the problem mainly was because the fluid was too thin compared to true dexron III. That's why I'm leaning towards Valvoline dex/Merc since its' thicker.
Any idea what the viscosity is? I did get a Tru cool, an oem filter and a magnefine. My goal is to do it all at the same time so she is totally refreshed.
I don't think I've ever seen trans fluid listed in viscosity. It's basically Dextron III.
Old 06-23-2019, 03:43 PM #20
jross20's Avatar
jross20's Avatar
Originally Posted by BoomerBob View Post
What is WS?
Toyota WS stands for World Standard I believe.
You can look up the viscosity index and other levels at specific temperatures. Real Dex III is like 207 I think, and the one I went with is 176. MaxLife and other new ones are like sub 150.
Old 06-23-2019, 04:04 PM #21
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Where are you guys buying Toyota Type T-IV? Would Aisin Type T-IV be as good? It seems to be cheaper. I mean Aisin made the transmissions in the first place so it should be right?
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 04:40 PM #22
Real Name: Jake
Real Name: Jake
I buy mine off amazon
TOYOTA Genuine Lexus ATF Type... https://www.amazon.com/dp/B00EV5A5NC...p_mob_ap_share
Old 06-23-2019, 05:19 PM #23
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
I got mine from the Toyota dealer for about $7/qt.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 06:50 PM #24
pokeyman pokeyman is offline
pokeyman is on a distinguished road
I think synthetic fluid is the way to go with any type of oil.
pokeyman is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 07:05 PM #25
skepticninja85 skepticninja85 is offline
Real Name: Tony
skepticninja85 is on a distinguished road
Real Name: Tony
Resealed the tranmission pan with new FIPG and did a transmission fluid flush as well since I replaced the radiator earlier this year from the original as preventative maintenance. When i did the flush from the tranmission cooler lines i used valvoline maxlife atf synthetic. Tranny shifts fine, to finish it off ill be adding the magnafine inline transmission filter soon on the output/going back to transmission line...mainly because i forgot to put the magnets in after i cleaned them when i had to pan off.
skepticninja85 is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 09:33 PM #26
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
It's likely just an Aisin sticker on someone else's fluid. T-IV is nothing special, even when compared to Dexron 3. Tons of Euro and Japanese cars use it under the spec of JWS 3309. When I had a Volvo 850 T5 the original spec fluid for that bulletproof aisin box was Dexron, but eventually Volvo replaced that original spec with 3309. Actually stayed red longer than with plain jane Dexron as well.
But yeah WS in an A340 is way too thin. You never know something can go wrong in communication.
Old 06-25-2019, 02:29 AM #27
FunBobby's Avatar
FunBobby FunBobby is offline
FunBobby is on a distinguished road
FunBobby's Avatar
I just replaced mine with MaxLife this weekend, can't tell a difference
FunBobby is offline   Reply With QuoteReply With Quote
Old 06-25-2019, 07:33 AM #28
I would put the inline filter in the line going to the cooler.
Old 06-27-2019, 04:38 PM #29
jross20's Avatar
jross20's Avatar
Everything I read said to put it after the cooler... ?
Old 06-27-2019, 04:52 PM #30
OrRunner's Avatar
OrRunner OrRunner is offline
OrRunner is on a distinguished road
OrRunner's Avatar
The directions say to put the filter before the cooler if it's a new transmission, and after the cooler if the trans has already been run without a filter
OrRunner is offline   Reply With QuoteReply With Quote
atf , good , guy , maxlife , thin
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 11 12-18-2023 05:21 AM
Transmission flush vs. transmission fluid drain and refill... Bad_Influence 5th gen T4Rs 18 03-08-2022 12:03 AM
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
Recomended body shops in So Bay, CA? Krazynative 4th Gen T4Rs 0 01-21-2011 11:44 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
