Old 06-28-2019, 09:31 AM #31
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Originally Posted by OrRunner View Post
The directions say to put the filter before the cooler if it's a new transmission, and after the cooler if the trans has already been run without a filter
That's the way I install them.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 06-28-2019, 10:08 AM #32
Mr. Goodkat's Avatar
Mr. Goodkat Mr. Goodkat is offline
Mr. Goodkat is on a distinguished road
Has anyone used Castrol Import Multi Vehicle? I used it in our 01 Camry and I'm planning on using it in the 4R.
2000 Limited natural white w/rear locker 204,xxx
Eibach Pro-Truck lift kit, Geolandar AT 275/70R16, debadged
2001 Camry LE V6 113,000 antique sage metallic, runs like new
Mr. Goodkat is offline   Reply With QuoteReply With Quote
Old 06-28-2019, 05:14 PM #33
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
OH okay, phew I am good then!
atf , good , guy , maxlife , thin
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 11 12-18-2023 05:21 AM
Transmission flush vs. transmission fluid drain and refill... Bad_Influence 5th gen T4Rs 18 03-08-2022 12:03 AM
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
Recomended body shops in So Bay, CA? Krazynative 4th Gen T4Rs 0 01-21-2011 11:44 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
