Old 06-20-2019, 11:45 PM #1
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
As of 2019, what is the recomended Transmission Fluid?
I've spent hours for the past two days reading all over the forums and other sites and I am STILL totally un-confident on which ATF to get....
What I have learned is...
-MaxLife is thin
-Mobile 1 Full Synth changed their formula and apparently it isn't good now?
-Pennzoil Dex/Merc... found one guy who liked it, no other info
-Valvoline Dex/Merx (NOT maxlife) has a higher Viscosity index, so that is good. Can't find much else on it.
Super thin ATF doesn't sound good to me... but... what are you all using as of 2019?
Old 06-21-2019, 12:15 AM #2
RotaryDreamz's Avatar
RotaryDreamz RotaryDreamz is offline
Real Name: Sean
RotaryDreamz will become famous soon enough
Real Name: Sean
Is this the 1st time you're changing your ATF fluid? If not, just keep using what you were using before. Im using Toyota T4 ATF fluid. My transmission has only seen Toyota ATF from the start. I have over 300k mi on it, and it's still running.
RotaryDreamz is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 12:22 AM #3
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
This ^
If not that then I am using Redline D4. Also dumped the Maxlife in my other A340F for Castrol High Mileage. Hard shifts in this high mile, towing history transmission are gone!
Old 06-21-2019, 01:24 AM #4
jross20's Avatar
jross20's Avatar
No this will be the first time to me knowledge. I looked at the Toyota fluid but read several things talking about how it was not a replacement for dexron III. Apparently there's a TSB for it.
Originally Posted by T4R2014 View Post
This ^
Castrol , I'll try to read more about that one.
Leaning towards the Valvoline sex/Merc I think.
Old 06-21-2019, 11:24 AM #5
pokeyman pokeyman is offline
pokeyman is on a distinguished road
I use Valvoline Max life with no problem at all for over 100000 miles
pokeyman is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 11:58 AM #6
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
I used the Walmart brand 'Super Tech' Dexron III ATF to completely change the fluid in mine just yesterday it seems to like it just fine. Smoother shifts and I think I was getting a vibration I no longer get. Yes, it's really too early to tell much at this point, but so far the T4R and I like it. Took 3.5 gallons. I think I pumped out some of the new stuff too. I did the electric pump trick and the return line off the trans radiator to change the fluid. Since I didn't drop the pan, replace the filter, and clean the magnet I also installed a Magnafine in line trans filter.
https://www.walmart.com/ip/Super-Tec...allon/20573820
https://amazon.com/dp/B0787KWZPS/ref..._t1_B07MBF4X26
Alternate filter: https://amazon.com/dp/B07MBF4X26/ref...5-97e82f798254
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 12:10 PM #7
jross20's Avatar
jross20's Avatar
I read a lot where people say it's good, but I've also read some things where people had issues and also explained said issues. And the problem mainly was because the fluid was too thin compared to true dexron III. That's why I'm leaning towards Valvoline dex/Merc since its' thicker.
Any idea what the viscosity is? I did get a Tru cool, an oem filter and a magnefine. My goal is to do it all at the same time so she is totally refreshed.
Old 06-21-2019, 12:36 PM #8
RS Dude's Avatar
RS Dude RS Dude is offline
RS Dude is on a distinguished road
RS Dude's Avatar
If you don't use AMSOIL your trans will blow up immediately! Hee, Hee, Hee.
'96 T4R SR5 V6 Auto 2WD 329,000 miles
RS Dude is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 11:54 PM #9
Mighty Buffalo's Avatar
Mighty Buffalo Mighty Buffalo is offline
Real Name: Greg
Mighty Buffalo is on a distinguished road
Real Name: Greg
I used the Walmart Valvoline synthetic, and it's been running well.
Mighty Buffalo is offline   Reply With QuoteReply With Quote
Old 06-22-2019, 09:58 AM #10
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
The correct fluid is Dexron III. Dexron is the trade name for the formula of ATF licensed by GM no matter who manufactures it. You can buy Toyota brand Dexron ATF if you can find it. Dexron VI synthetic ATF supersedes Dexron III, is compatible with it and can be used to top off transmissions with Dexron III already in them. I think brand is a matter of personal preference, but you should use fluid that is labeled Dexron III or Dexron VI, not "compatible with".
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 06-22-2019, 02:20 PM #11
T4R2014's Avatar
T4R2014's Avatar
Not much to read. One person just grows a pair and tries something new, posts about it, then the rest follow and preach it. Hasn't been done with Castrol High Mileage yet. I just bought it out of the blue. Read the back and noticed it meets Dexron and Type IV, but not WS. Sold!
Old 06-22-2019, 03:09 PM #12
NissanTechJake NissanTechJake is offline
Real Name: Jake
NissanTechJake is on a distinguished road
Real Name: Jake
Toyota ATF Type T-IV
This is backwards compatible with DEX II and III
4Runner compatible years. 1984-2005
You must be referring to WS that’s NOT compatible.
You will notice this is what most Toyota specialty shops sell and recommend.
NissanTechJake is offline   Reply With QuoteReply With Quote
Old 06-22-2019, 10:06 PM #13
jross20's Avatar
jross20's Avatar
I actually was looking at Dex VI but when I learned about the who viscosity thing with newer fluids I decided against it.
I will say though I do not think you can find actual Dexron III anymore since they don't license it anymore.
Yeah I try to keep in mind about people preaching. But when you see a ton of it followed up with logical sounding explanations it still sticks in my mind.
Really? That's what I was going to do when i first started researching but I found a ton of threads (across here and other sites) that were like "PSA, DO NOT USE T-IV!!!" with explanations and pictures of the bottles. So I was like well shit...
Alright, for everyone! I ended up using Valvoline Dex/Merc and so far she has basically been butter smooth today. My fingers are crossed that things will stay this way, at least until the next flush.
Old 06-22-2019, 10:17 PM #14
T4R2014's Avatar
T4R2014's Avatar
You made a good choice. I think changing the fluid matters more than worrying about spec. That said most businesses tend to stick to OEM ATFs. Toyota Dexron is out there but hard to find, so most local dealers supply them with Type IV. Similar to OEM coolants most shops use them for liability reasons. Much safer to use that than an unlicensed Dexron. Can't blame the mechanic's choice in fluid if the transmission fails after a drain and fill or flush.
Old 06-22-2019, 11:20 PM #15
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
....I just put 6 qts of T-IV in mine. Am I going to die?
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
atf , good , guy , maxlife , thin
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 11 12-18-2023 05:21 AM
Transmission flush vs. transmission fluid drain and refill... Bad_Influence 5th gen T4Rs 18 03-08-2022 12:03 AM
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
Recomended body shops in So Bay, CA? Krazynative 4th Gen T4Rs 0 01-21-2011 11:44 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
