Old 06-21-2019, 04:41 AM #1
AL B. AL B. is offline
AL B. is on a distinguished road
Cool Another “Name That Sound(s)” thread
First of all thanks in advance. I hope this issue I am having can be solved with others experiences and knowledge.
2001 4WD Limited
Revving in park or neutral will not summons the noise. Its only when its in drive and rolling under load (clue?). Once it starts rolling I hear a vibration type noise but ONLY under load. From 5mph up is a click, click, click and faster as rpm increase. Its very loud up to about 45mph. Then it seems to be “quieter” or just not as loud but still present. While fwy or street driving I can let off the gas pedal and the noise is 100% gone. Then as I give it gas (now under load) the sound is present.
** Things that I have changed within the last 5k miles. Sound was present before and after new parts/maintenance. **
Both front CV axles (OEM ones)
Front diff fluid
Transfer case fluid
Rear diff fluid
Rear driveshaft u joint
Lubed driveshaft
** Things I think could be the issue **
** Transfer case
** Transmission
** Torque converter
** Front UJoint
** Front diff
** Transmission
I have tried getting the rear wheels off the ground and putting it in drive to hear the noise from under but the dang traction control engages and wont allow that area of troubleshooting. Open for suggestions. The main clue here is it only is present under load. Thanks!!
• 2001 LTD 4WD • Bilstein 6112’s up front • Tundra Bilstein 5100 + OME 890 in the rear ig: socal4runna
AL B. is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 09:33 AM #2
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
My two guesses are:
Ujoints (check for play in them)
Rear differential (carrier/pinion bearing, they generally only make noise under load but it's a groaning sound and not a click click click)
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 06-21-2019, 04:06 PM #3
JMat's Avatar
JMat JMat is offline
JMat will become famous soon enough
JMat's Avatar
My guess would be Ujoints, too. I had the same type of issue and there wasn't any play so I pulled the driveline and took it to a shop and sure enough... Ujoint.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
JMat is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 10:02 PM #4
Ok so hear is the sound that I was complaining about. What yall think?
3rd gen 4Runner noisy transfer case 4x4 4WD 2001 - YouTube
Old 06-28-2019, 03:15 PM #5
gamefreakgc's Avatar
gamefreakgc gamefreakgc is online now
Real Name: Jerod
Real Name: Jerod
I'm not a transfer case expert so I don't have any input but THANK YOU for posting a photo/video, so many people post on here with very little info and it's hard to help. Someone with more experience than I should be able to tell you what's wrong.
326WHP 347TQ
gamefreakgc is online now   Reply With QuoteReply With Quote
front , load , noise , present , rear
V8 Exhaust Sound and Video Clip Compilation Thread bigwebb83 4th Gen T4Rs 70 09-22-2018 02:47 AM
Another JBL Sound System thread... help? Strider 4th Gen T4Rs 3 09-10-2018 11:07 PM
Another "What's That Sound Thread"... FatTiresRollin 5th gen T4Rs 7 07-08-2013 08:07 PM
Does this sound acceptable? (another headlights thread! yay!) Awynt 5th gen T4Rs 15 07-27-2012 11:44 AM
Veteran's Day Thread - sound off, vets! Kung Off Topic 15 11-26-2011 10:02 PM
